One question regarding magnetism/electricity
  • Thread starter shanktank
In summary, the sources of electric fields, magnetic fields, and gravitational fields are electric charges, moving charges or currents, and massive objects, respectively. These fields exert forces on charged objects, have energy density, and can be accompanied by a magnetic field, energy flow, and photons. Newton's law of universal gravitation explains the tendency of objects to accelerate towards each other, with the strength of the gravitational field dependent on the mass of the objects.
shanktank
hey,
can anyone tell me what the sources of electric fields, magnetic fields, and gravitational fields are? i can't find it anywhere in my textbook.
Thanks a bunch in advance.
Shane
Sources of Magnetic Field
((Stolen from for time saving purposes http://theory.uwinnipeg.ca/physics/mag/node6.html) )
When we introduced the electric field it was apparent that electric charges were the source of such a field. Experiments in the 19th century showed that the source of a magnetic field was a moving charge, or current. A detailed mathematical relation between a charge moving at velocity and the associated magnetic field is known as Ampère's law or, in another form, the Biot-Savart law.
Electric Field((Stolen from for time saving purposes Wikipedia))
In physics, an electric field or E-field is an effect produced by an electric charge (or a time-varying magnetic field) that exerts a force on charged objects in the field. The SI units of the electric field are Newtons per coulomb or volts per meter (both are equivalent). Electric fields contain electrical energy with energy density proportional to the square of the field intensity. Electric fields exist around all charges; the direction of field lines at a point is defined by the direction of the electric force exerted on a positive test charge placed at that point. The strength of the field is defined by the ratio of the electric force on a charge at a point to the magnitude of the charge placed at that point. In the dynamic case the electric field is accompanied by a magnetic field, by a flow of energy, and by real photons.
Not sure about your question about gravitational fields. Gravity is the tendency of objects to accelerate toward each other(which applies to all objects but only the massive ones have a field large enough to field).
Newtons law of Universal gravitation(wikipedia...lol)
Sure, I'd be happy to help answer your question about the sources of electric fields, magnetic fields, and gravitational fields. Electric fields are created by the presence of electric charges, either positive or negative. These charges can be stationary, as in the case of a charged object, or they can be moving, as in the case of an electric current. Magnetic fields, on the other hand, are created by moving electric charges, such as the electrons in a wire conducting electricity. Gravitational fields, on the other hand, are created by the presence of mass or energy. In other words, any object with mass or energy will have a gravitational field surrounding it. I hope this helps clarify the sources of these fields for you.
What is the difference between magnetism and electricity?
Magnetism and electricity are both forms of energy, but they are fundamentally different. Magnetism is the force exerted by magnets and magnetic objects, while electricity is the flow of charged particles. Magnetism can exist without electricity, but electricity cannot exist without magnetism.
How do magnets work?
Magnets work by creating a magnetic field, which is a force that attracts or repels other magnets or magnetic materials. This is due to the alignment of the electrons in the material, creating a north and south pole. Opposite poles attract each other, while like poles repel each other.
What is an electric circuit?
An electric circuit is a path through which electricity can flow. It typically consists of a power source, such as a battery, and components such as wires, switches, and resistors, through which the electricity flows. The flow of electricity is controlled and directed by the components in the circuit.
How do electricity and magnetism interact?
Electricity and magnetism are closely related and can interact with each other. When an electric current flows through a wire, it creates a magnetic field. Similarly, when a magnet is moved near a wire, it can induce an electric current in the wire. This phenomenon is known as electromagnetic induction.
What are some practical applications of magnetism and electricity?
Magnetism and electricity have countless practical applications in our daily lives. Some examples include generators, motors, speakers, MRI machines, and credit card strips. Electricity is also used to power our homes, cars, and electronic devices, while magnetism is used in compasses, doorbells, and computer hard drives.
