Inverter low voltage high current 5-12v in 13.8v out 30 amps
In summary: If so, it may be that the voltage drop isn't causing the issue. If you're not using a battery isolator, then you may want to consider getting one.
corsymons
I am looking for a design to achieve the following. I have an off road camping trailer with a second deep cycle battery installed. The second battery never reaches full charge because of the voltage drop from the alternator in front to the battery in the rear of trailer To charge the second battery in the trailer to its full capacity from the tow vehicle I use a 12v to 220v inverter and then a 12v battery charger. Very inefficient and bulky. Where can I find information to assist in designing a 5-12volt(dc) input to 13.8v(dc) output voltage booster/inverter that can deliver 30 amps.
If you take the worst case, convering 5 volts to 13.8 volts at 30 amps would require an input current of 82.8 amps even if you could do it at 100 % efficiency
30 amps * 13.8 volts / 5 volts = 82.8 amps..
Realistically, it would probably take 100 amps at 5 volts.
However, you probably don't really need 30 amps.
How about 6 amps?
This would charge a 40 amp hour battery in about 7 hours, so it would be ready to use after a day of driving.
Also the 5 volt figure is a bit optimistic. That would be a very dead 12 volt battery. How about 10 volts?
There are booster circuits available on Internet which could probably do this.
Here is one that can convert 10 volts up to 12 volts to 32 volts
http://www.ebay.com.au/itm/DC-10-32V-12-35V-Step-up-Boost-Power-Supply-Module-/120757538824?pt=AU_B_I_Electrical_Test_Equipment&hash=item1c1db5d008
As they say on the above site, though:
But please be reminded that the output voltage cannot be lower than input voltage.
There are probably plenty of them if you would like to do a search.
How much voltage drop are you experiencing? It really shouldn't be an issue with proper size wiring.
Are you using a battery isolator between the trailer and the tow vehicle?
FAQ: Inverter low voltage high current 5-12v in 13.8v out 30 amps
1. What is an inverter low voltage high current?
An inverter low voltage high current is an electronic device that converts low voltage input (such as 5-12v) into higher voltage output (such as 13.8v) with a high current capability of up to 30 amps.
2. What is the purpose of an inverter low voltage high current?
The purpose of an inverter low voltage high current is to provide a stable and reliable power source for devices that require higher voltage and current than what is available from the input source. This is commonly used in automotive applications, such as powering car audio systems or charging electronic devices.
3. How does an inverter low voltage high current work?
An inverter low voltage high current works by using a DC-DC converter to increase the input voltage to the desired output voltage. This is achieved through the use of transistors, capacitors, and inductors to convert and regulate the voltage and current levels.
4. What is the difference between low voltage and high current?
Low voltage refers to the amount of electrical potential difference or voltage between two points, while high current refers to the amount of electrical flow or amperage. In an inverter low voltage high current, the voltage is low at the input but is increased to a higher level at the output, while the current remains high to provide sufficient power.
5. What are the applications of an inverter low voltage high current?
An inverter low voltage high current is commonly used in automotive, marine, and solar applications to power devices that require higher voltage and current. It can also be used for emergency backup power, such as in RVs and boats, or for powering electronic devices in remote locations where traditional power sources are not available.
