Why does rotational invariance have to do with spin?
In summary, the conversation discusses the relationship between rotational invariance and spin relations in quantum mechanics. It is noted that rotational invariance does not necessarily involve physical rotations, but rather is an abstract concept that can be represented in different ways. The connection between orbital angular momentum and classical notions of rotation and orbit is also discussed, with the reminder that these concepts do not translate directly to quantum mechanics. Further clarification is recommended by reading Chapter 7 of Ballentine's book.
carllacan
274
Hi.
According to Griffiths the conmutation relations for the angular momentum and spin operators conmutation relations can be deduced from the rotational invariance, as in Ballentine 3.3. For the angular momentum seems logical that it is so, but how is it that rotational invariance leads to spin relations if quantum spin has nothing to do with rotations (as it is emphatically repeated in most books)?
Or is it that rotational invariance has actually a different, more abstract, meaning in quantum mechanics than it has in the classical case, as spin does?
Thank you for your time.
Two things:
(1) Rotational invariance and rotation refer to invariance under the rotation group for both the orbital and spin angular momentum. The rotation group itself is an abstract object that can be given explicit form using different representations but these representations need not act on 3-dimensional physical space and produce rotational flows of the form you are familiar with both from classical mechanics and intuitively (for example the spin 1/2 representation acts on a complex 2-dimensional vector space of spinors). Read chapter 7 of Ballentine after finishing chapter 3 and then hopefully this will all be clear to you. The subject of your question constitutes a very deep and far reaching concept so you really need to go through chapter 7 of Ballentine; a forum post won't do it any justice. After that you can ask more specific questions.
(2) Orbital angular momentum also does not correspond to rotation or orbit in the classical sense. Such classical notions of rotation and orbit would first require the notion of a spatial trajectory and secondly the notion of actually "possessing" angular momentum neither of which can be realized (no pun intended) in QM without a plethora of issues following suit. So if it seems logical to you, make sure it is not for the wrong reason(s) conceptually
1. What is rotational invariance?
Rotational invariance is a property of physical systems that means the laws governing the system do not change under rotations. This means that the system behaves the same way regardless of its orientation in space.
2. What is spin?
Spin is a fundamental property of particles that describes their intrinsic angular momentum. It is a quantum mechanical property and is quantized, meaning it can only take on certain discrete values.
3. How is rotational invariance related to spin?
Rotational invariance is related to spin because particles with spin exhibit the same behavior under rotations as particles without spin. This means that the laws of physics are rotationally invariant for all particles, regardless of their spin values.
4. Why is rotational invariance important in physics?
Rotational invariance is important in physics because it allows us to apply the same laws and equations to physical systems regardless of their orientation. This simplifies our understanding and analysis of these systems and helps us make accurate predictions about their behavior.
5. How does rotational invariance affect our understanding of the universe?
Rotational invariance is a fundamental principle in physics and is essential for our understanding of the universe. It allows us to apply the same laws and concepts to all physical systems, from subatomic particles to galaxies, and helps us build a unified understanding of the world around us.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
