- #36
rcgldr
- 8,855
- 632
Are you sure about this? After going through the math, it seems that the puck shouldn't have an increase in energy, but this is based on the assumption that the puck does follow an involute of circle path, and this sure looks like the proper model for anything winding around a post. Assuming the puck is attached at the side, then it's angular momentum (rotation wise) should slow things down a bit.LeeB said:So if there is no work done, then you are suggesting that the new velocity WON'T be twice the old velocity under these circumstances? When we actually did this on an air table, the results were virtually identical to the first case.
I do realize that the string is moving inwards with tension, but it's tension is perpendicular to the path of the puck so I'm not sure where the increase in energy would originate from. Relative to the string (which isn't an inertial frame since it's rotating), the string is being wrapped around the pole similar to the pole rotating and pulling in the string. Using this analogy, the only work done is to increase the potential energy (relative to the pole), but not the kinetic energy of the puck, similar to rasing a weight with a string (increase in potential energy, no increase in kinetic energy).
