How a Good Conductor is always a good Conductor
  • Thread starter call_naveen
  • Tags
    Conductor
In summary, electrons in a good conductor are free to move and carry charge. In a closed circuit, they continue to move because they are connected in a loop. The voltage or potential difference acts as the pusher for the electrons to flow. This can be seen in electric generators where rotating wire and magnetic forces cause the electrons to move and create an electric current.
call_naveen
Hi,
I have a doubt in my mind about the behaviour of Good Conductors. So far whatever we studied,
1. Good Conductors have free electrons to move and carry the charge,
2. Electric charge is being carried in form of electrons.
Now the question is Suppose, we have piece of good conductor(copper).
B(+) =====COPPER_WIRE======== (-)A
Scenario 1
In above arrangement, in the copper is connected to (-)ive charged source (point A),
and point B is open in the air..
: How come the (-)charge will flow from Point A to the loose end point B.
When we say Point A is Negative source, Is it like a electron gun, bombarding free electrons and pushing electrons into the metal wire ?
: If there is no electron gun of free electrons and its only the charge(more exicted state of electron) which is getting transferred from electron to electron, then charge should also flow thru bad conductors also. Atleast the charge(excited state) of electron can be transferred from rigid packed electron of the atom of any bad conductor.
: Now charge cannot flow thru bad electrons as we all know, and hence we need free electrons to take the charge and move further to +ive side or somewhere.. but in a finite direction..
: But isn't a situation will come, where are the free electrons are clubbed at the B side of wire, and there will not be any free electron on A side, As all the electron are already moved and carried the charge. Then how come wire will still be Good Conductor.
Please anyone try to explain the core, I know I am loosing some basics here
Thanks in advance
No, it is not like an electron gun, it is just like an electron pusher. The electrons in a good conductor are free electrons, so they will get pushed together. But electrons don't like to get bunched up, because like charges repel, so the electrons will start pushing back once they get bunched up. Finally they will stop moving when the are pushing back as hard as they are being pushed.
In a closed circuit, they don't stop moving, because they are connected in a loop, and the will go round and round forever. Thinking of it this way, the situation you set up is an open circuit through which current doesn't flow continuously. When you switch on the lights in a room, you are converting an open circuit to a closed circuit.
Thanks for the reply atty,
What is this electron pusher. Is it the electric flux ? If we see from the very beginning ... the electric generator who is generating the current. pls refer the first picture here http://www.physclips.unsw.edu.au/jw/electricmotors.html
Now in the arrangement between the N/S pole magnets, we are rotating the piece of wire. Due to the magnetic force.. electrons will drift and hence move further in one direction... Is this the push you are talking about?
Now let's say electrons are moving continously and pushing other electrons which makes flow of electrons and hence electric current
But after certain time all the free electrons will go from the rotating wire(the coil inside the generator) and there wud not be any free electrons to push further... unless the other end of wire (which is goin out of generator station is looping back to get the free electons which were pushed back earlier)
Am i on right track on this ?
Thanks
Voltage, potential difference, is the pusher. Think of voltage as the PRESSURE in a water system, think of the movement of the electrons in a conductor as the water flow. Electrons move because they are charged...regardless of the source of voltage, whether emf induced via a field in a rotating device or via chemical means in a battery, electric potential can push electrons along especially when they are abundant and weakly bound to the nucleus.
What makes a good conductor?
A good conductor is someone who can effectively lead and direct a group of musicians or performers. They have strong communication and interpersonal skills, as well as a deep understanding of music and its technical aspects.
What qualities should a good conductor possess?
A good conductor should possess excellent musicianship, leadership, and communication skills. They should have a thorough knowledge of music theory and be able to interpret and convey musical ideas clearly to the performers. They also need to have a strong sense of rhythm and tempo, as well as the ability to listen and make adjustments in real-time.
How does a good conductor maintain control during a performance?
A good conductor maintains control through clear and effective communication with the performers. They use a combination of body language, hand gestures, and verbal cues to convey their musical intentions. They also need to have a strong sense of timing and be able to make quick decisions to keep the performance on track.
Why is a good conductor important in a musical ensemble?
A good conductor is essential in a musical ensemble because they serve as the leader and guide for the performers. They are responsible for interpreting the music and conveying it to the performers in a way that creates a cohesive and unified performance. They also help to maintain the tempo and dynamics of the music, ensuring that the ensemble stays together and performs at their best.
Can anyone become a good conductor?
While anyone can learn the skills and techniques of conducting, it takes a lot of practice, dedication, and natural talent to become a truly great conductor. It requires a deep understanding and love for music, as well as strong leadership and communication abilities. With hard work and determination, anyone can improve their conducting skills, but it takes a special individual to become a truly exceptional conductor.
  • Electromagnetism
  • Other Physics Topics
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
