Electromagnetic induction and conducting rods
In summary, two 0.68 m long conducting rods, perpendicular to a 4.7 T magnetic field, rotate at the same speed in opposite directions. The ends of the rods come within 1.0mm of each other and are connected by a wire at the same electric potential. To cause a 1.0 mm spark in air, a potential difference of 4.5*10^3 V is required. The angular speed of the rods is found using the formula v = r*angular speed, with the potential difference being divided between the two rods. The answer is 2100 rad/sec, calculated by taking into account the speed of both rods and using calculus to determine the relationship between velocity and length. Alternatively
apchemstudent
220
Two 0.68 m long conducting rods are rotating at the same speed in opposite directions, and both are perpendicular to a 4.7 T magnetic field. As the drawing shows, the ends of these rods come to within 1.0mm of each other as they rotate. More-over, the fixed ends about which the rods are rotating are connected by a wire, so these ends are at the same electric potential. If a potential difference of 4.5*10^3 V is required to cause a 1.0 mm spark in air, what is the angular speed (in rad/s) of the rods when a spark jumps across the gap?
Is it possible to still use the formula
Voltage potential = velocity * magnetic field * length of rod ?
v = r*angular speed
(4.5*10^3)/(4.7*.68) = v = r * angular speed
i got the angular speed as 2070 rad/sec. Is this correct how i solved the question? if not can you correct me. Thanks
Remember that the base of each rotating rod is at the same potential, but they move in opposite directions so that one will contribute V/2 and the other -V/2, and the potential difference is V = 4500 V.
The answer in the back said 2100 rad/sec. At first i thought the same way with V/2, but i only got 1035 rad/sec. So doubling it will bring the answer closer. However though, is this the proper way to solve the problem, as posted from above?
Voltage potential = velocity * magnetic field * length of rod ? v = r*angular speed
Yes, but the speed is a function of l, so you have to apply a bit of calculus:
[tex]dE = vBdl \rightarrow E = \int_0^L \omega lBdl = \frac{1}{2}\omega BL^2[/tex]
Note: the other rod is rotating with speed [itex]-\omega[/itex] so the potential from the centre to the end is [itex] - \frac{1}{2}\omega BL^2[/itex]
The condition for spark is Potential Difference = 4.5kV: [itex]E_L - E_R = 4,500[/itex].
AM
Also note that one can avoid integration by dealing only with the angular velocity as it is independant of the length.
The angle swept by the rod in one second = [tex]\omega[/tex]
So the area swept by the rod in one second, [tex]A=\frac{1}{2}L^2\omega[/tex]
[tex]E = -\frac {d\phi} {dt} = -B\frac {dA} {dt}[/tex]
[tex]E = -\frac {1} {2}BL^2\omega[/tex]
Regards,
Gamma.
1. How does electromagnetic induction work?
Electromagnetic induction is the process of generating an electric current in a conductor by moving it through a magnetic field or by changing the magnetic field around it. This is possible because a changing magnetic field induces a voltage in the conductor, which in turn creates an electric current.
2. What is Faraday's law of induction?
Faraday's law of induction states that the magnitude of the induced voltage in a conductor is proportional to the rate of change of the magnetic field through the conductor. This means that the faster the magnetic field changes, the greater the induced voltage will be.
3. How are conducting rods used in electromagnetic induction?
Conducting rods, also known as conductors, are used in electromagnetic induction to create an electric current. When a conductor is moved through a magnetic field or experiences a changing magnetic field, it induces a voltage and generates an electric current.
4. What are some examples of electromagnetic induction in everyday life?
Electromagnetic induction is used in a variety of everyday devices, such as generators, transformers, and electric motors. It is also used in wireless charging technology, induction cooktops, and some forms of public transportation, such as maglev trains.
5. What are the applications of electromagnetic induction in scientific research?
Electromagnetic induction has many applications in scientific research, including studying the Earth's magnetic field, creating magnetic fields for particle accelerators, and measuring the conductivity of materials. It is also used in geophysical exploration techniques, such as electromagnetic imaging and mapping of underground structures.
