Double Slit Experiment with White Light and one Slit colour filtered
In summary: It would not pass through the slit if the wavelength of the monochromatic light were removed from it.
Commando Spaz
What would happen if the double slit experiment were to be undertaken using white light, and one of the slits was covered by a monochromatic filter (i.e. something which only one wavelength could pass through), and apart from this there was no detector monitoring which slit each photon was coming through?
I think there are two possible scenarios:
1. The wave interference pattern is visible for the colour of the filter, however the rest of the light would display a normal particle pattern behind the slit which was not filtered, it would not be white light, but would represent the white light if the wavelength of the monochromatic filtered light were removed from it.
2. There would be no interference pattern and the particle pattern would appear on the screen, the light which came through the non filtered slit would be white, and the light which came through the filtered slit would be monochromatic.
Please explain which, if either of these scenarios would occur, please explain why or why not
What do you mean by this? The light coming through the slits will retain their property since there is no interference near the slits.
Before going any further can you explain what you think each photon of white light is. In particular do you think each are the same?
Thanks
Bill
Thanks
Bill
I understand that white light is made up of photons of different wavelengths
Yes, that's what I mean in the second scenario. In the first scenario, the monochromatic light passing through the filtered slit interacts with the same wavelength going through the unfiltered slit. The other wavelengths of the white light are unaffected.
That's correct - and random polarisations as well.
That being the case the solution to your query is easy.
If its the same wavelength as the colour filter of your slit you will get interference. If not it will not pass through that slit and you wont.
It looks pretty trivial to me, which is why I asked the question.
Thanks
Bill
Likes 1 person
1. What is the Double Slit Experiment with White Light and one Slit colour filtered?
The Double Slit Experiment with White Light and one Slit colour filtered is a physics experiment that demonstrates the wave-particle duality of light. It involves passing white light through a single slit and then through two parallel slits, causing an interference pattern to form on a screen. When one of the slits is covered with a color filter, the resulting pattern will show only the color of the filter, indicating that light behaves as both a wave and a particle.
2. How does this experiment relate to the wave-particle duality of light?
The Double Slit Experiment with White Light and one Slit colour filtered is one of the most famous experiments that demonstrates the wave-particle duality of light. It shows that light can behave as both a wave and a particle, depending on the conditions of the experiment. This phenomenon is a fundamental principle in quantum mechanics and has implications for our understanding of the nature of light and matter.
3. What is the purpose of using a color filter in this experiment?
The purpose of using a color filter in the Double Slit Experiment with White Light and one Slit colour filtered is to isolate a specific color of light and observe its behavior as it passes through the slits. This allows for a clearer demonstration of the wave-particle duality of light, as the resulting interference pattern will only show the color of the filter used.
4. What is the significance of the interference pattern formed in this experiment?
The interference pattern formed in the Double Slit Experiment with White Light and one Slit colour filtered is significant because it shows that light behaves as a wave, as it creates a pattern of light and dark bands on the screen. This pattern is a result of the constructive and destructive interference of the light waves passing through the slits. This phenomenon is a key principle in understanding the behavior of light and other particles at a quantum level.
5. How does this experiment impact our understanding of light and matter?
The Double Slit Experiment with White Light and one Slit colour filtered has had a significant impact on our understanding of light and matter. It has provided evidence for the wave-particle duality of light and has challenged traditional ideas of the nature of light and matter. This experiment has also had implications in the development of quantum mechanics and has led to further exploration and understanding of the behavior of particles at a subatomic level.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
