Why using quantum group SUq(2) instead of SU(2) makes sense?
In summary, the conversation discusses the increasing use of quantum groups in place of SU(2) in quantum gravity, with one intuitive justification being the inherent uncertainty in determining angles due to a minimum measurable size and maximum distance to the horizon in the universe. This concept is further explored in a 2-page paper, which also discusses the relationship between the deformation parameter q and the cosmological constant. The conversation also touches on the competing ideas of introducing the cosmological constant as a special value via the q-deformation or as an ordinary coupling constant, and the potential for these two approaches to be related. The paper also suggests that the deformation parameter may change over time as the universe evolves.
marcus
Dearly Missed
24,775
792
Increasingly QG is being done with a q-deformed symmetry group: replacing SU(2) by
the quantum group SUq(2). What do you see as the intuitive basis for this?
One intuitive justification is that in a universe with a minimum measurable size and an a maximum distance to horizon there is an inherent uncertainty in determining angle. A minimal angular resolution---which SUq(2) nicely implements. The argument is simple and is worked out in this 2-page paper.http://arxiv.org/abs/1105.1898
A note on the geometrical interpretation of quantum groups and non-commutative spaces in gravity
Eugenio Bianchi, Carlo Rovelli
(Submitted on 10 May 2011)
Quantum groups and non-commutative spaces have been repeatedly utilized in approaches to quantum gravity. They provide a mathematically elegant cut-off, often interpreted as related to the Planck-scale quantum uncertainty in position. We consider here a different geometrical interpretation of this cut-off, where the relevant non-commutative space is the space of directions around any spacetime point. The limitations in angular resolution expresses the finiteness of the angular size of a Planck-scale minimal surface at a maximum distance [itex]1/\sqrt{\Lambda}[/itex] related the cosmological constant Lambda.
This yields a simple geometrical interpretation for the relation between the quantum deformation parameter
[tex]q=e^{i \Lambda l_{Planck}^2} [/tex]
and the cosmological constant, and resolves a difficulty of more conventional interpretations of the physical geometry described by quantum groups or fuzzy spaces.
Comments: 2 pages, 1 figure
The cosmo constant is a reciprocal area: a handle on it is the distance [itex]1/\sqrt{\Lambda}[/itex] which is easy to calculate by typing this into the google window:
c/(70.4 km/s per Mpc)/sqrt 3/sqrt 0.728
A couple reasons before this:
1) The Ponzano-Regge spin foam model of 3D gravity was first regularized by going to quantum groups in the Turaev-Viro state sum model. The TV model seems to have positive cc compared to the Ponzano-Regge model.
2) As Physics Monkey pointed out in https://www.physicsforums.com/showpost.php?p=2576472&postcount=7, the Levin-Wen models (which are somehow related to the TV model) use quantum groups.
Spin foams have a long history of thinking of gravity as being a constrained BF theory, and so related to TQFTs, which the TV and Levin-Wen models are. Rovelli still believes his current model is some sort of TQFT http://arxiv.org/abs/1010.1939 . Hellmann's http://arxiv.org/abs/1105.1334 has very interesting comments on p8 about how triangulation independence, which is characteristic of state sum TQFTs, is supposed to be achieved.
I am still not convinced that this algebraic setup for the cc (via the deformation parameter q) makes sense b/c we know from the asymptotic safety program that the cc is subject to renromalization.
So there are two competeing ideas how to introduce the cc
- as something very special via the q-deformation
- as an ordinary coupling constant
I still do not see how these two approaches can be related.
But if, as you have said, LQG should get unification, then the current interpretations of the formalism as geometry should be wrong anyway.
In his version of dS/CFT, David Lowe used the quantum deformation of the isometry group of de Sitter space, because he wanted a finite-dimensional Hilbert space, because the cosmological horizon of an observer in de Sitter space has a finite entropy.
No, not really. The current formalism is not geometry (neither today nor in future), but geometry emerges in a certain semiclassical limit (already today). Using SUq(2) could be a way to let several aspects emerge simultaneously - geometry, particles, interactions, ...
This is a fascinating idea and I am really a fan - but I don't see how to this can be harmonized with renormalization.
I don't either, but perhaps it is possible that they might be related. This paper gives some suggestions of how that might work, on an intuitive level.
It interprets the deformation parameter as something that could run.
The group deformation q is a function of the finest angular resolution φ = Lmin/Lmax
the ratio of the two distance scales.
In the limit as φ --> 0, the deformation q --> 1
and the quantum group SUq(2) goes to the ordinary SU(2).
One might say the idea of the finest angular resolution is more intuitively meaningful of the two. Or else that the difference between them is trivial, since they are so closely related:
q = exp(i φ2)
I suppose it is obvious that φ can change as the universe evolves. It can change even without Lmin changing, if Lmax does. With any definition I can think of, the latter does change over time.
There is a distance called the cosmological event horizon CEH which is at present slowly increasing towards a limit currently estimated to be about 16 billion lightyears.
Roughly speaking the asymptotic value of the CEH is 1/√Λ, a distance you see being used in the paper. But more precisely using standard model cosmology the limit is √(3/Λ).
There is a rogue factor of √3 which gets in there.
So even if √Λ would remain constant, the Lmax would change over time.
That is if we take it to be the CEH---which is the bound on how close a galaxy must be if it can, today, send us a message which will eventually reach us. If a galaxy is closer than the cosmological event horizon then whatever events happen there today, we will eventually get the news. If it is farther than that, we will never get the news.
Most people here will know the CEH, but I put it in for completeness in case some do not.
Even with Λ constant, that CEH distance is slowly increasing towards estim. 16 billion lightyears. And CEH used to be much smaller. At the time the microwave background light was emitted it was several orders of magnitude smaller. I would guess something like 40-some million lightyears, instead of the present 15 billion or so.
I don't pretend to understand in what sense the cosmological constant Λ itself could run. None of this makes clear sense to me yet. But it seems to have possibilities. Regardless of what happens with Λ itself, there is clearly some play in the both the Planck length (related to Lmin) and in the CEH (related to Lmax).
So intuitively there must be some play in their ratio, the finest angular resolution φ.
The message of this short paper, in my view, is that we can think of the quantum group deformation simply as a measure of the finest angular resolution.
(Perhaps it even has something to do with the "relative locality" line of investigation currently being pursued. This puts emphasis on the individual observer's momentum space and therefore necessarily on determining the incoming angles of whatever the observer is detecting/measuring.)
If anyone is curious, the asymptotic value of the CEH can be gotten by putting this in google:
c/(70.4 km/s per Mpc)/sqrt 0.728 in light years
The numbers 70.4 and 0.728 are from the 7 year WMAP report.
As you mentioned, we think from asymptotic safety that Lambda runs, so how does this fit with SUq(2)? How do the two approaches relate? I don't think there is any mismatch. If indeed Lambda runs then that must affect the maximum length scale Lmax. Then certainly the angle resolution bound must run and therefore also the deformation parameter q!
If we assume Lambda runs then also must q, because Lambda places limits on measurement (the available spherical harmonics etc, as explained in the paper) so there is no incompatibility. Or so I think.
If we assume Lambda runs then also must q, because Lambda places limits on measurement ... so there is no incompatibility.
The inability to show the presence of an incompatibility does not automatically proof its absence.
“This geometrical picture resolves also a certain difficulty in interpreting the non-commutativity implied by a cut-off in the spins as related to the Planck scale fuzziness of physical space: the deformation parameter is dimensionless, and by itself does not determine a scale at which physical space becomes fuzzy.
Okayyyy!
So, now, who can argue ... why this scale cannot be at 10^-18m?
It seems strange to me to have the quantity
[tex]l_{pl}^2 \Lambda = G \Lambda[/tex]
turn up in an equation. Since in the action we always have the cosmological constant in the form
[tex] \frac{\Lambda}{G}[/tex]
This is the energy density that must couple to space-time in order to form a dimensionless quantity. Or just think of the Einstein equations
[tex]G_{\mu \nu} + \Lambda = 8 \pi G T_{\mu \nu} [/tex]
One would have to multiply through by G to get [tex] G \Lambda[/tex] turn up but this is arbitrary to some extent. It seems to imply that the Planck length has been put in by hand and some stage in the construction.
Maybe someone knows at what stage and why we get this combination of the Planck length and the cosmological constant?
That's right! I spoke carelessly there. I should have said, not that there is no incompatibility but that there was no incompatibility shown. AFAIK it not been proven that there is a natural compatibiity between letting the group be deformed a variable amount into SUq(2), on the one hand, and treating Lamba as a running coupling constant, on the other hand.
I have no idea how or if that would work out.
I think it is the natural way to get a dimensionless quantity involving Lambda.
Lambda, as I understand it, is always a reciprocal area. So to get a dimensionless quantity one must multiply it by an area. So one multiplies by the Planck area. (What else :smile: ?)
Just kidding, but you can see where it comes in already in equation (2)
So basically by choosing to measure all quantities in Planck units. Hmm thinking about it should come somehow when one computes the entropy of the cosmological horizon. Since the area of the cosmological horizon is the reciprocal of Lambda.
I don't understand how the EPRL/FK semiclassical limit is going to work in the q-deformed case. Is there still a J->infinity limit, or does J have a maximum value now? Or if q has to be taken to zero for the limit, then the cosmological constant disappears in the semiclassical limit?
Actually that sounds right, given your idea that the cc should arise naturally from some sort of renormalization flow.
Carfora, Maezuoli and Rasetti's review of quantum tetrahedra http://arxiv.org/abs/1001.4402 begins with a great comment inspired by "Nescit Labi Virtus (Virtue cannot fail)".
The semicallsical limit is an interesting aspect; honestly, I can't see how a q = zero or a j = infinity limit could make sense.
It's not my idea that the cc could arise from renromalization. It's just an idea that the non-gaussian fix point in AS gives us a non-zero cc, but I do not see how to get a running cc (which means a running q!) for q-deformation.
FAQ: Why using quantum group SUq(2) instead of SU(2) makes sense?
1. Why is there a need for quantum groups?
Quantum groups were developed to extend the mathematical framework of Lie groups to include non-commutative and non-cocommutative structures. This is important in the study of quantum mechanics, where observables do not always commute.
2. How does SUq(2) differ from SU(2)?
SUq(2) is a quantum group, meaning it is a deformation of the classical Lie group SU(2). This deformation introduces a new parameter, q, which controls the non-commutativity and non-cocommutativity of the group structure.
3. What are the benefits of using SUq(2) instead of SU(2)?
SUq(2) has many applications in quantum mechanics, statistical mechanics, and other areas of theoretical physics. It allows for a deeper understanding of quantum phenomena such as entanglement and quantum information. It also has connections to other mathematical structures, such as Hopf algebras and representation theory.
4. How is SUq(2) used in quantum mechanics?
SUq(2) is used in quantum mechanics to study the behavior of quantum systems. It provides a framework for understanding the non-commutative and non-cocommutative properties of observables, and allows for the development of new mathematical tools for solving quantum mechanical problems.
5. Are there any practical applications of SUq(2)?
Yes, there are several practical applications of SUq(2) in areas such as quantum computing, quantum cryptography, and quantum information processing. It also has applications in condensed matter physics, where it can be used to study the behavior of complex materials and systems.
9K
24K
