Does atmospheric pressure affect the saturated vapor pressure ?
by Jano L.
Tags: affect, atmospheric, pressure, saturated, vapor
Jano L.
Jano L. is offline
#1
Jul6-13, 11:42 AM
P: 1,027
When the Clausius-Clapeyron equation for saturation vapor pressure over liquid water is derived via the Carnot cycle, it is usually assumed that there is only gaseous water above the liquid. The other atmospheric gases are neglected.
However, in common settings (lake, glass of water...), the atmospheric gases exert much higher pressure on the liquid surface than the water vapor. Does this large pressure affect the saturation vapor pressure somehow? I guess that the correction is small, perhaps since the additional atmospheric pressure is too low to change the volume of liquid water significantly...
Phys.Org News Partner Physics news on Phys.org
Sensitive detection method may help impede illicit nuclear trafficking
CERN: World-record current in a superconductor
Beam on target: CEBAF accelerator achieves 12 GeV commissioning milestone
mfb
mfb is offline
#2
Jul6-13, 12:54 PM
Mentor
P: 10,766
For ideal gases, I think there should be no change.
Gases are not ideal, of course - they need some volume (reducing the volume available for water a bit), they have some interaction (I guess this gives a bit more water, but I don't know). In real air, you also have dust particles and so on.
Jano L.
Jano L. is offline
#3
Jul7-13, 03:01 AM
P: 1,027
Yes, that is similar to what I was thinking.
On the other hand, when applied to solid-liquid equilibrium, the "p" in the C-C equation refers to total liquid pressure. It is a bit strange that for liquid-gas equilibrium, the "p" in the C-C equation refers to partial pressure of the vapor, not to the total liquid pressure.
Register to reply
Related Discussions
Vapor pressure and atmospheric pressure Chemistry 5
Vapor Pressure and Atmospheric Pressure Classical Physics 1
Why liquid boils when the envrionmental pressure equals its saturated vapor pressure General Physics 4
Why do bubbles form when vapor pressure = external pressure? Chemistry 1
Vapor pressure vs liquid pressure in enthalpic combustion reaction Biology, Chemistry & Other Homework 0
