Verifying R is an Order Relation on {1,2,3}
  • Thread starter laminatedevildoll
  • Tags
    Relation
In summary, you need to check if < is an order relation on {1,2,3} by using the three properties: reflexive, anti-symmetric, and transitive.
laminatedevildoll
211
How do I verify that R={(1,1). (2,2), (3,3) (3,2) (3,1), (2,1)} is an order relation on {1,2,3}.
So far, I have that an ordered set is a pair (X, <) where X is a set tand where < in a binary relation on X so that the following three properties are fulfilled:
1. reflexive prop
2. anti-symmetric prop
3. transitive prop
Do I have to prove each property for R?
Yes, and the simplest way to check is just go through the pairs.
Reflexive: Are (1,1), (2,2), (3,3) in the set?
Anti-symmetric: (2, 1) is in the set. If this relation is anti-symmetric, (1, 2) must not be in the set. Is that true? What other pairs do you have to look at?
Transitive: I see (3,2) and (2,1) in the set. If this relation is transitive, what pair must be in the set? Is it?
Reflexive: (1,1), (2,2), (3,3) are in the set.
Anti-symmetric: (2, 1) is in the set. If this relation is anti-symmetric, (1, 2) must not be in the set. Yes this is true. So, this property is true.
Transitive: (3,2) and (2,1) are in the set. If this relation is transitive, then (3,1) must be in the set.
Follow up:
Let x,y be in R.
If y precedes x if and only if y less than or equal to x, the, do I verify that this statement is an order relation like before using the three properties? If I use the three properties, then how can I prove that y precedes x.
This is how I started off:
Reflexive Property:
If x in an element in R, then x < x for all x in R. Therefore, x precedes x.
Anti-symmetric:
For all x,y in R if x<y y< x then, x=y, where y precedes x.
Thank you for your help.
I was giving an example! (2,1) is not the only pair you need to check.
Reflexive Property:
You mean x<= x (or [itex]x\le x[/tex]), of course.
laminatedevildoll said:
Follow up:
Let x,y be in R.
I can't really follow what you're saying. You have two order relations here: R and <. And you've defined R to be <. So you really have nothing to prove- just check your definition of < - is it an order relation?
Did you want to prove something else? You haven't said on what set the relations are defined, but assume they're defined on {1, 2, 3}. Using the usual definition of <, "y precedes x if and only if y less than or equal to x" means "if y precedes x, then y < x" and "if y < x, then y precedes x". So R = {(1, 1), (2, 2), (3, 3), (1, 2), (1, 3), (2, 3)}. Is this what you meant to say?
I think you only meant "For all x and y in R, if (y, x) is in R, then y < x." That also means if y > x, then (y, x) is not in R. Is that what you wanted?
This is actually unrelated to the previous problem. But, I think that I have to go through the three properties of an order relation to prove this.
The problem:
Let x,y is an element in R, real number. We define a relation <= (precedes symbol) on R. Verify that <= (precedes symbol) defined by
x<= (precedes) y if and only if y<= x (less than or equal to)
Verify that <= (precedes symbol) is an order relation.
Similarly, (3,2) and (3,1) are also anti-symmetric since (2,3) and (1,3) are not on the set, right?
The problem:
Okay, you said before that y precedes x iff y < x. Let P denote the relation "precedes" and L denote the relation "less than or equal to". So now instead of P = L, you have that (x, y) is in P iff (y, x) is in L. In other words,
P = {(x, y) : (y, x) is in L and x and y are in R}.
What else does P equal (what is the relationship between P and L)?
Do you mean this relationship?
P={(x,y): x P y if y L x}
or do I have to jump into the reflexive property?
I mean that P and L are inverses. Remember that binary relations are sets of pairs. You're told that if (x, y) is in L, then (y, x) is in P, and if (y, x) is in P, then (x, y) is in L. In other words, L and P contain the same pairs- just reversed. If (x, x) is in L, then (x, x) is in P. If (x, y) and (y, z) are in L, then (y, x) and (z, y) are in P.
In order to prove that P is an order relation, you need to know that L is an order relation. Otherwise, you could only prove that if L is an order relation, then P is an order relation. But assume you already know L is an order relation. Then the following holds:
For all x, y, and z in R
1) (x, x) is in L.
2) If (x, y) and (y, x) are in L, then x = y.
3) If (x, y) and (y, z) are in L, then (x, z) is in L.
L and P have the same pairs- just reversed, so:
4) (x, x) is in P.
Can you see the rest now? To see the rest, highlight:
5) If (y, x) and (x, y) are in P, then y = x.
6) If (y, x) and (z, y) are in P, then (z, x) is in P.
To make it even clearer, (6) can be rewritten as
7) If (z, y) and (y, x) are in P, then (z, x) is in P.
So (4), (5), and (7) show that P is an order relation. Notice that P is usually called "greater than or equal to" :)
Does that make sense?
1) (x, x) is in L.
4) (x, x) is in P.
Yes, it makes sense. I got confused with the "precedes" symbol, when in reality it somewhat refers closely to the "less than or equal to" sign. Thank you.
Related to Verifying R is an Order Relation on {1,2,3}
1. How can you verify that R is an order relation on {1,2,3}?
To verify that R is an order relation on {1,2,3}, we need to check if it satisfies the three properties of an order relation: reflexivity, transitivity, and antisymmetry.
2. What is the definition of an order relation?
An order relation is a binary relation on a set that satisfies the three properties of reflexivity, transitivity, and antisymmetry. It is used to compare elements in a set and establish a partial ordering.
3. How do you check reflexivity for R on {1,2,3}?
To check reflexivity for R on {1,2,3}, we need to see if every element in {1,2,3} is related to itself. In other words, we need to check if (1,1), (2,2), and (3,3) are all in R.
4. How do you check transitivity for R on {1,2,3}?
To check transitivity for R on {1,2,3}, we need to see if for every (a,b) and (b,c) in R, (a,c) is also in R. In other words, we need to check if (1,2), (2,3), and (1,3) are all in R.
5. What does it mean for R to be an order relation on {1,2,3}?
For R to be an order relation on {1,2,3}, it means that it satisfies the three properties of an order relation: reflexivity, transitivity, and antisymmetry. This means that R can be used to establish a partial ordering of the elements in {1,2,3}.
  • Set Theory, Logic, Probability, Statistics
