ensabah6
- 695
Is there a way to get a local bosonic theory out of spin foam formalism?
Xiao-Gang Wen's suggestion, first published 6 Jul 2004
http://arxiv.org/abs/cond-mat/0407140v2 Page 8
"Remarkably, it appears that the theory of loop
quantum gravity can be reformulated in terms of a
particular kind of string net [condensation]...in
addition to gauge interactions and Fermi statistics,
string net condensation can give rise to gravity"
If you can connect spin foam formalism with Wen's
string-net derivation, you can get gravity and the
standard model.
http://dao.mit.edu/~wen/NSart-wen.html
"So in their theory elementary particles are not the
fundamental building blocks of matter. Instead, they
emerge as defects or "whirlpools" in the deeper
organized structure of space-time."
"Now this problem is solved. If the spins that form
our space organize into a string-net liquid, then the
collective motions of strings give rise to light waves
and the ends of strings give rise to electrons. The
next challenge is to find an organization of spins
that can give rise to gravitational wave."
How hard would it be to get from 4D spin foams to
Wen's string-nets "lattice spin models"
http://dao.mit.edu/~wen/pub/qorder.html?
http://dao.mit.edu/~wen/pub/cosmos.html
An artistic summary of the result:
The following picture
has mountain, lake, trees, snow,... ..., and light.
If we look closer, we see atoms, electrons, protons, and photons.
If we look even closer (I mean really really close), we see ...
boring spins on a lattice.
How can a simple boring spin system produce such a nice scenery?
The answer is "more is different". When many quantum spins interact with each other, the spins can get organized (or entangled). The pattern of organization is called quantum order. It is this pattern (ie the quantum order) of spins that makes wonders. The twists and defects in the pattern correspond to "elementary" particles. In this way, quantum order produces electrons, photons, atoms, ... ..., and the beautiful scenery.
(4/2002)
He's recently published how to get gravitons from a "spin" model.
arXiv:gr-qc/0606100 [ps, pdf, other] :
Title: A lattice bosonic model as a quantum theory of gravity
Authors: Zheng-Cheng Gu, Xiao-Gang Wen
Comments: 4 pages. RevTeX4. Homepage this http URL
Could spin foam theorists make use of his results directly into their own models?
Both make use of wilson lines, wilson loops, simon-cherns theories, etc.
Recent advances in condensed matter theory have revealed that new and exotic phases of matter can exist in spin models (or more precisely, local bosonic models) via a simple physical mechanism, known as "string-net condensation." These new phases of matter have the unusual property that their collective excitations are gauge bosons and fermions. In some cases, the collective excitations can behave just like the photons, electrons, gluons, and quarks in our vacuum. This suggests that photons, electrons, and other elementary particles may have a unified origin -- string-net condensation in our vacuum. In addition, the string-net picture indicates how to make artificial photons, artificial electrons, and artificial quarks and gluons in condensed matter systems.
standard model.
(4/2002)
