Calculating force on object being lowered/dropped into water
In summary, the person is looking for information or resources on calculating the hydrodynamic force of an object hitting the water with constant velocity. They are specifically interested in understanding this at a tertiary level in order to create a design equation at a secondary school level. They mention being familiar with buoyancy and drag, but needing more understanding on the force of an object hitting the water. They also ask about the drag force and coefficient for a square object, but mention it may be easier to conduct an experiment rather than trying to calculate it.
PLI
Any info/resources on calculating the hydrodynamic force on an object when it hits the water surface with constant velocity?
cheers
Welcome to PF.
You mean something like this one or more general like this one?
Put another way - at what level should we be pitching this?
If just lowering an object into water, and at secondary school level, you'd only want to worry about bouyancy and, maybe, surface tension... for eg.
thanks simon,
both are good.
trying to get good understanding at "tertiary level", so that i can then put it into a design equation at "secondary school level" :)
haven't had a good read through either yet but I'm ok with submerged buoyancy, drag etc. it's the force acting on the object as it hits the water i need to understand better.
out of interest - do you have drag force and drag coefficient for a square object?
Not lying around no.
These things are not trivial to work out - especially as you'll get turbulent motion.
It's usually easier just to do an experiment.
I would recommend looking into the principles of fluid mechanics and specifically, hydrodynamics. The force on an object being lowered or dropped into water can be calculated using the equation F = ρVg, where ρ is the density of the fluid (water), V is the volume of the object, and g is the acceleration due to gravity. This equation takes into account the buoyant force acting on the object as it enters the water.
To calculate the hydrodynamic force on an object hitting the water surface with constant velocity, you would need to consider the impact force and the drag force. The impact force is the force exerted on the object as it enters the water and is dependent on the velocity and mass of the object. The drag force is the force exerted by the water on the object as it moves through it and is dependent on the velocity, shape, and size of the object.
There are various resources available online, such as textbooks and research papers, that provide more detailed equations and methods for calculating hydrodynamic forces. Additionally, conducting experiments in a controlled environment can also help in understanding the forces acting on an object in water. I suggest consulting with a fluid mechanics expert or conducting further research to obtain more specific information on your particular scenario.
1. How do you calculate the force on an object being lowered into water?
The force on an object being lowered into water can be calculated using the formula F = ρVg, where F is the force, ρ is the density of the water, V is the volume of the object, and g is the acceleration due to gravity.
2. What factors affect the force on an object being dropped into water?
The force on an object being dropped into water is affected by the density of the water, the volume and shape of the object, and the acceleration due to gravity.
3. How does the shape of the object affect the force on an object being lowered into water?
The shape of the object affects the force on an object being lowered into water because it determines the volume of the object. Objects with a larger volume will experience a greater force when submerged in water.
4. Is there a difference in the force when an object is dropped into still water versus moving water?
Yes, there is a difference in the force when an object is dropped into still water versus moving water. This is because when an object is dropped into still water, it displaces the water and creates a downward force equal to its weight. However, when an object is dropped into moving water, the force will also be affected by the speed and direction of the water's flow.
5. How can the force on an object being dropped into water be used in practical applications?
The force on an object being dropped into water can be used in practical applications such as designing structures that will be submerged in water, calculating the impact force of objects falling into bodies of water, and understanding the forces involved in diving and swimming activities.
  • Mechanics
  • Mechanics
