- #36
rcgldr
Homework Helper
- 8,876
- 638
Jeff Reid said:The old "dime store" type balsa gliders have flat wings and glide just fine. Rubber powered balsa planes with flat wings also fly well.
http://www.retroplanet.com/PROD/24887
http://www.retroplanet.com/PROD/24886
Not the small ones. This one only has a mild taper at the trailing edge of the upper surface, just a rounded leading edge:DaveC426913 said:IIRC, the gliders have to have a curve manually applied to their wings?
http://www.4p8.com/eric.brasseur/glider2.html
Some small indoor models also have flat wings:
http://jeffareid.net/misc/balsagldrs.jpg
Balsa framed models use standard airfoils. For the aerobatic models, just as with real aerobatic models, symmetrical airfoils are used. The point here is that flat or nearly flat air foils work just fine, especially with smaller, low Reynolds number models.balsa built up - standard airfoils
