Is There a Maximum Distance Limit in Our Universe?
In summary: Planck Length-There is still debate and no clear understanding of what happens at such extreme scales and what implications it may have for our understanding of physical reality
vyas22
Hello all,
If Planck length (1.61619926 × 10(-35 )meters) places a theoretical limit on minimum possible distance does it also imply that we have a maximum theoretical limit on measurable length as inverse of Planck length (1/Planck Length)..
does there any such limit on the maximum theoretical distance exist for our Universe?
Thank you for your inputs ..
Likes Ben Finesilver
well, 1/planck length has units (1/meter) not (meter), so it isn't a distance at all.
vyas22 said:
Hello all,
If Planck length (1.61619926 × 10(-35 )meters) places a theoretical limit on minimum possible distance ...
Not true. To quote Wikipedia
There is currently no proven physical significance of the Planck length
√ Agreed!
@ Phinds - Wikipedia also states 'Profound significance of Planck length in theoretical physics' :)
thank you both for responding ..
vyas22 said:
√ Agreed!
Yes but "profound significance" does NOT imply that it represents the smallest unit of length.
An inverse Planck length would be several orders of magnitude larger than the observable universe. It is unclear [for obvious reasons] if it has any fundamental significance. The Planck length is a somewhat contrived unit, as already noted. It is unclear if it has any fundamental significance. It is probably more of a convenient bookkeeping tool.
Re-read post #2. This is utterly incorrect.
Curvature is often measured as inverse area.
A smallest length (if nature had one) would suggest a minimal detectable area, and thus an upper bound on curvature. Nature would have a "greatest possible curvature" in some sense.
These smallest and largest things are not supposed to be exact, I think, but to have meaning as order of magnitude quantities, as *scales*.
The central coefficient in the Einstein GR equation is a FORCE. Usually you see it as an inverse force constant on the lefthand side:
8πG/c4
It relates curvature (on the left) to energy density and the like (on the right). IOW it relates geometry to matter.
I don't imagine folks understand this down to the level of precise detail, but in a general order of magnitude sense nature seems to have intrinsic scales of force, area, pressure, energy density, curvature, built into its very texture. At this point maybe it is just an intuitive feeling some people have. I believe we'll learn more.
To me, the minimal area (and the related maximal curvature, maximal energy concentration) seem more meaningful than the minimal length. The length is just a conceptual way of approach, leading to the other quantities. Have to go, no time to try to make this more coherent.
vyas22 said:
Planck length [...] places a theoretical limit on minimum possible distance...
No, and the reason for this can be understood through this experiment:
Suppose the Earth receives a photon with a wavelength ##\gamma_1##. Since spacetime is expanding, we know that this photon had an original wavelength ##\gamma_2##, such that ##\gamma_2\lt\gamma_1##. This phenomenon is known as redshift. Nothing special.
Now, here's the thing, if the Earth receives from far away a photon whose wavelength is equal to Planck's length ##\ell_p##. This means that the photon before -- who traveled all this distance -- had a wavelength smaller than ##\ell_p##. And this contradicts the "Planck length [...] minimum possible distance".
This problem is known as the Trans-Planckian problem, it's still unsolved and that's mainly because we have no theory of quantum gravity that can describe what happens at such scales.
Thank You all again for your responses,
To summarize what i learned here,
-Theoretically and debatably distances lesser than Planck length can not exist within normally observed properties and framework of space time
-Inverse of Planck length should just mean the number of Planck Length Units that can be included in a meter wide distance
1. What is Plack length?
Plack length, also known as Planck scale, is the smallest possible length in the universe, measuring at approximately 1.6 x 10^-35 meters.
2. How is Plack length related to the inverse of Plack length?
The inverse of Plack length is equal to the Planck mass, which is the smallest possible mass in the universe. They are inversely related, meaning as one increases, the other decreases.
3. Can Plack length be observed or measured?
No, Plack length is a theoretical concept and cannot be directly observed or measured with current technology.
4. What is the significance of Plack length in physics?
Plack length is significant because it is believed to be the scale at which quantum effects become important and the laws of physics as we know them may no longer apply.
5. How does Plack length relate to the concept of a "theory of everything"?
Some theories propose that Plack length is the key to understanding a unified theory of all physical forces, also known as the "theory of everything". However, this theory is still speculative and requires further research and evidence.
  • Quantum Physics
  • Beyond the Standard Models
  • Other Physics Topics
  • Cosmology
  • Cosmology
