Thought experiment: Origin of inertia is gravitational?
In summary, the conversation discusses a thought experiment involving a box of photons and the concept of inertia. It is suggested that the box of photons has an inertia equal to the combined mass of the photons, but the source of this inertia is debated. One argument proposes that it is due to radiation pressure, while another argues that it is due to gravitational interaction with the rest of the universe. The conversation also delves into the idea of rest inertia and the role of velocity in determining the inertial mass of the photons.
johne1618
371
Hi,
What do you think of this thought experiment that demonstates a situation where the origin of inertia must be gravitational (Mach's Principle)?
Imagine an empty box with perfect mirrors on its walls.
Now let us pump in a large amount of photons into the box.
Let us assume that the combined mass/energy of the photons is much greater that the mass of the box itself so we can neglect the mass of the box.
Do the confined photons have an inertial mass?
If we apply a force to the box does the box apply an inertial reaction force back proportional to the mass/energy of the photons?
I believe it does.
So where does this inertial force come from?
Apart from elastic scattering from electrons in the walls the only other interaction the photons engage in is gravitational. In particular the photons do not interact with a Higgs field or a zero-point electromagnetic field.
Thus the inertial reaction force can only be due to gravitational interaction with the rest of the Universe.
Now the question is: what type of gravitational interaction?
If we assume an analogy with Electromagnetism then there are two types of gravitational interaction: a static attractive force or acceleration-induced radiation. It seems the latter fits the bill nicely especially if one allows advanced waves so that the resulting inertial reaction force appears instantaneously as it should.
John
Actually I've done a similar thought experiment and found out the box of photons does have an inertia exactly equal to the mass of the photons combined (ignoring the mass of box). But it is not due to gravity, it is due to radiation pressure of photons.
Suppose you push the box, result in some acceleration in say x direction, photons that travel along -x direction would have a blue shift relative to the box, photons travel on x direction would have red shift relative to box.
Thus blue shifted photons will impart more momentum to the box when reflected then before, red shifted photons less.
This change of imparted momentum would behave like reaction force to the outside world. I've calculated the force using only doppler effect and relation between wavelength and momentum and found them to be exact.
The thought experiment I used is also about whether photons have gravitational mass. As photons clearly have inertial mass.
Interesting - I'd like to see your calculations.
John
Inertial mass implies gravitational mass. If a photon passes a massive body its path will be deflected. Conservation of momentum means that the massive body must also be accelerated, responding to the gravitational field of the photon.
Maybe enroger0's argument goes something like this:
Imagine a photon in a box with energy
[itex]\Large E = h \nu[/itex]
Let us assume the box accelerates with acceleration [itex]a[/itex] for a small time [itex]\Delta t[/itex]. Then its velocity [itex]v[/itex] is given by
[itex]\Large v = a \Delta t[/itex]
Then, due to the Doppler shift, the energy of the photon as it is reflected off the back wall of the box is given by
[itex]\Large h\nu_d = h\nu (1 + \frac{v}{c})[/itex]
[itex]\Large h\nu_d = h\nu(1 + \frac{a \Delta t}{c})[/itex]
Therefore in terms of the energy change of the photon
[itex]\Large \Delta E = h\nu_d - h\nu[/itex]
we have
[itex]\Large\Delta E = h \nu \frac{a \Delta t}{c}[/itex]
Using the relationship
[itex]\Large E = p c[/itex]
we have
[itex]\Large \Delta E = \Delta p \ c[/itex]
and thus
[itex]\Large\frac{\Delta p}{\Delta t} = \frac{h \nu}{c^2} a[/itex]
Now in order to produce this rate of change of momentum we need to apply a force to the box
[itex]\Large F = \frac{\Delta p}{\Delta t}[/itex]
Therefore we have
[itex]\Large F = \frac{h \nu}{c^2} a[/itex]
Therefore the inertial mass of the photon is [itex]h \nu/c^2[/itex].
This seems to be an argument for the inertial mass of a confined photon using only the concept of Doppler shift and the energy/momentum relations for a photon.
This argument does seem to require that the photon box is moving.
What supplies the inertial reaction force *before* the box moves?
Well, I might be wrong, but I would say, that there is no inertial reaction force unless the box is changing speed.
I think just as a particle has a rest mass/energy it also has a corresponding rest inertia defined by F = m a at zero velocity.
But "a" is only about change of speed. At rest or at constant speed it would be 0, so no force...
That's exactly the calculation I did. As to what supplies the inertial force "before", you can think of this box simply as a box holding a bunch of bouncing balls inside. Before any of the balls hit the wall you won't have any reaction force too.
Maybe stupid question, but if there is red/blue shift, wouldn't it be preserved after you stop applying force and thus stoping the box again?
I think the equation F = m a where m is a constant is only exactly true when the box is instantaneously at rest with zero velocity but with non-zero acceleration. I think the Doppler shift argument only works after the box has attained a non-zero velocity. I think we need to explain where the inertial reaction force comes from before the box moves. If you say before the box moves its inertial mass is zero then you are implying that as soon as the force is applied to the box it responds with an infinite acceleration.
You only get a Doppler shift while the box is accelerating and thus providing a difference in velocity between the box and the confined photon. As soon as the box stops accelerating the Doppler shift disappears.
Again, the analogy of a box with bouncing balls holds very well. If the mass of the box is very small, then indeed when force is applied you get a very large acceleration (lets not deal with infinities). Until one of the ball hits the box and transferred momentum and bounced the box back and forth.
This is a simple case of delayed reaction/inertia, the whole of the system has a total inertia of an certain amount, but since the members of the system don't interact instantaneously (photons still traveling, balls still moving between the walls...), inertial reaction don't come immediately too but at a delayed time. You can't just apply F=ma in this case since m isn't a rigid body.
Lets consider this in detail:
consider a photon moving back and forth, it will impart equal (but opposite sign) momentum when reflected by both sides.
consider the case when a photon is moving towards -x direction after the box is accelerated, photon is blue shifted, thus when it hit the wall it will impart more momentum then before. But it is reflected as blue shifted photon, so when it hit the other side of the wall it will have the same blue shifted momentum and impart same momentum, reflected back and so forth as before and everything in balance again.
So Doppler shift only cause reaction force (change of momentum) when there is a change of velocity.
People talk about photons as if they are true particles with mass. A photon is a unit of light and is a wave that acts like a particle. Light is an electro-magnetic energy transfer from one object to another. Inertia is caused by an objects gravity field. Inertia and mutual attraction are the two functions of the gravity field. Inertia is the primary function and mutual attraction is the secondary function. Electro-magnetism is the inertia and gravity for charges. Inductance does the same thing with current as mass does with velocity. Mass and charges act the same way but operate at different scales.
1. What is a thought experiment?
A thought experiment is a mental exercise or hypothetical scenario used by scientists and philosophers to explore ideas and concepts that cannot be tested or observed directly in reality.
2. How does the origin of inertia relate to gravity?
The origin of inertia is thought to be related to gravity because inertia is the resistance of an object to change its state of motion, and gravity is the force that attracts objects towards each other. Scientists have proposed that the gravitational force of massive objects in the universe may be responsible for the inertia of other objects.
3. What is the significance of understanding the origin of inertia?
Understanding the origin of inertia is significant because it can provide insight into the nature of the universe and the fundamental laws of physics. It may also lead to advancements in technology and our understanding of space and time.
4. What evidence supports the theory that gravity is the origin of inertia?
Currently, there is no definitive evidence that supports the theory that gravity is the origin of inertia. However, some scientists have proposed that the observed behavior of objects in the universe, such as the rotation of galaxies, can be explained by the gravitational origin of inertia.
5. What are the potential implications of the theory that gravity is the origin of inertia?
If the theory that gravity is the origin of inertia is proven to be true, it could have significant implications for our understanding of the universe and the laws of physics. It may also open up new avenues for research and technology, such as the ability to manipulate gravity for propulsion or energy generation.
  • Mechanics
  • Classical Physics
