Is it acceptable to work backwards in a show this problem?
  • Thread starter serllus reuel
  • Tags
    Work
In summary, when it comes to problems that ask you to "show" something, it is generally expected that you proceed in a direct fashion by defining variables and manipulating them to find the desired formula or equation. Working backwards can lead to errors and is usually more difficult. However, in some cases, it may be possible to work backwards if each step is reversible. It is important to clarify the expectations of the exercise, as some may only require you to justify a given solution rather than derive it.
serllus reuel
60
Is it acceptable to work backwards in a "show this" problem?
In problems that ask you to "show" something (e.g. "show that the formula/equation for ____ is _____") , it it sufficient to simply justify the answer they give (working backwards to literally "show it"), or should one derive the formula, as if the answer were not there?
I know this depends on the problem, for example, an exercise that asks you show that a particular solution to an ODE is correct probably does not want you to solve the ODE. There are also cases in which it is impossible to work backwards. But, what is the general rule to these problems, if any?
Mathematics news on Phys.org
I believe most questions like those expect you to proceed in a direct fashion (defining variables and manipulating them) to find the "target equation/answer".
That's probably almost always the case because if you work backwards, there's far more room for errors and you may potentially find yourself with the "wrong start" if you know what I mean.
Take for example something like Hess' law. Imagine trying to work the target equation backwards to find the 'x' many given equations and molar enthalpies. That's definitely harder than using the x many equations to find the target equation.
If you can work it backwards first you then should be able to then show it forwards. If they are just asking to show it is solution, plug it in I say!
I find it that it is easy to plug the variables into the equation. For example if you take the basic equation d=st, then rather than thinking in your brain backwards about numbers, plugging in is a lot easier.
If the goal of the exercise is as you state here, you should start with the given assumptions and work toward the formula or equation.
This is really a different question. Here you are given a differential equation and a purported solution. All you need to do is show that the solution that is provided satisfies the D.E. You do not need to solve the differential equation, and doing so is much more work than is asked for.
If you are asked to show that two equations are equivalent, then it might be possible to work backward from the equation you're supposed to end with, provided that each step you apply is reversible. For example, operations such as adding a certain quantity to both sides of the equation, multiplying both sides by the same nonzero number, and others are reversible steps. Squaring both sides, however, is not a reversible step.
This is sometimes called a "synthetic" proof: you start from the conclusion and work backwards to the hypothesis. As long as it is clear that every step is reversible that's a valid proof because we could go from hypothesis to conclusion by reversing each step.
Related to Is it acceptable to work backwards in a show this problem?
1. Is working backwards a valid problem-solving approach in the scientific method?
Yes, working backwards can be a valid problem-solving approach in the scientific method. It involves starting with the desired outcome and then working backwards to determine the steps needed to achieve that outcome. This approach is commonly used in fields such as mathematics, physics, and engineering.
2. What are the potential benefits of working backwards in a problem?
Working backwards in a problem can help identify the necessary steps and potential roadblocks to reaching a desired outcome. It can also help in breaking down a complex problem into smaller, more manageable parts.
3. Can working backwards lead to biased results?
Working backwards can lead to biased results if not done carefully. It is important to consider all possible solutions and not just focus on the desired outcome. Additionally, it is important to validate the results obtained from working backwards through other means, such as experimentation or peer review.
4. Are there any limitations to working backwards in problem solving?
One limitation of working backwards in problem solving is that it may not always be the most efficient or effective approach. It may also not be suitable for every type of problem, particularly those with multiple variables or unknown factors. In these cases, other problem-solving methods may be more appropriate.
5. How does working backwards differ from the traditional scientific method?
Working backwards differs from the traditional scientific method in that it starts with the desired outcome and works backwards to determine the steps needed to achieve it. In the traditional scientific method, the approach is to start with a hypothesis and then use experimentation to test and validate it. However, both methods can be used in conjunction with each other to solve complex problems.
  • STEM Educators and Teaching
  • Other Physics Topics
  • General Math
