- #456
- 8,142
- 1,756
mheslep said:Clever idea, but doesn't this imply the reactor has to be sealed and capable of withstanding some pressure, and if that is the case what is the economic advantage of placing the farm in the ocean (vs land or lake) and having to deal with marine operations?
Many designs for bioreactors are basicaly just big plastic bags filled with water. They already have a fair degree of mechanical strength as required by the weight of the water. It would be easy to modify these for total submersion. An air gap above the algae water would normally make the reactor slightly buoyant.
As stated earlier, there are several advantages. The biggest consideration is the cost of land [and property taxes], which is siginficant to the cost of production, thus the required yields, thus the required CO2 supply. We can live with less CO2 if we don't require the maximum possible yields. Also, no land preparation is required. While the cost of a marine bioreactor may be higher than one for land [I don't know that it would be!], land preparation can be a costly proposition for a new site. Next, semi-submersion in marine environments means that we naturally have very stable temps. This is highly siginficant as closed systems are also greenhouses by nature. It takes energy to keep them cool. Also, extreme winter conditions eliminate the chance of winter crops. In fact, this is what killed the bloom used in the Aquatic Species Program! If it is even possible, temperature regulation is critical and it can be energy costly. Coastal areas generally have moderate temps. Additionally, we have a ready supply of water with no energy-expensive deep pumping required. There are other practical advantages. For example, we have no drainage problems, land use laws, or concerns about flooding. Finally, the energy cost of mixing [water circulation], which can be significant, might be reduced by cleverly tapping the energy in the wave action of the ocean.
If one can significantly reduce the cost of start-up and operations - financially and in terms of energy - one can live with lower yields. This could make algae-fuels cost-competitive sooner than they would be otherwise.
Note also that diesel generators needed for processing the algae would supply about 40% of the CO2 needed for growth. This is added to the ambient CO2. There is no reason why any closed system should be limited to the ambient CO2 supply. The fact that processing is energy costly also means that we have a signficant CO2 supply to boost the growth rate of the algae. As discussed earlier, the diesel engines might even be easily modified to "fix" a good percentage of the required nitrogen.
