I still don't quite get the idea of subspaces, span, and range
In summary: Let's just stick with "linear transformation".I need some clear definitions and examples to sort this out...Thanks! :DIn summary, a subspace is a set of vectors that satisfies closure under addition, subtraction, and scalar multiplication, and also contains at least one vector. The span of a set of vectors is the set of all possible linear combinations of those vectors. The range of a linear transformation is the set of all possible outputs from that transformation.
kesun
37
Alright. As stated in the title above.
So, a subspace is a set of vectors that satisfies:
1) It contained the zero vector;
2) It's closed under addition and subtraction.
By "closed", it means that when I add another vector in R2 or multiply by a scalar k on A(x)=m, it will end up with A(x)+A(y)=m or k(A(x))=m.
Is it correct so far?
Now, I know span is like mapping, but I don't have a precise definition nor explanation for it...Is it like mapping a spanning set to a set of column spaces?
Range is all possible result of a linear transformation of a matrix, ie. L(x)=b, where b is a spanned vectors..is it?
It's easiest to imagine what a subspace is in three dimensions, and then generalize to higher dimensions. In 3-dimensional Euclidean space, a subspace is any 3-, 2-, 1-, or 0-dimensional "slice" of space that passes through the origin. That is, all planes or lines that pass through the origin are subspaces, as is the origin itself. One example of a subspace is the x-y plane; another example is the line going through the point (2, 1, 5). Planes and lines of all other orientations are also included, provided that they pass through the origin.
The span of a given set of vectors is precisely the subspace defined by those vectors. For example, the vectors (1,0,0) and (0,1,0) span the x-y plane. The vectors (1,1,0) and (1,-1,0) also span the x-y plane. The vector (2,1,5) spans the 1-dimension subspace given in the last paragraph.
Basically, the span of a set of vectors a_m is the subspace of all vectors which can be written as linear combinations of a_m. The vectors a_m then constitute a basis for this subspace.
Likes linkshimers
The word definitions are clear, but I find it hard to actually put them to use in problems.
For example, if a question asks to find the matrix of a linear mapping L:R2 -> R2 that has a nullspace of span({(2, 1)}) and range span({(2, 1)}), what's the method of determine this matrix? I understand that I am supposed to put the givens into use, but the straightforward of only givens of spans kind of stuck me of how to manipulate them to give me what I want. For example, how is this range denoted in normal column space notation (or something that's easier to understand)?
For any vectors [tex]v_1,...,v_m[/tex] in [tex]\mathbb{R}^n[/tex], the span of these vectors is the range of the linear map [tex]\mathbb{R}^m\to\mathbb{R}^n[/tex] given by the matrix with these vectors as columns.
A linear map is not uniquely determined by its image and range, so you will need to make some arbitrary choices. For example, we could choose the first column to be (2,1), i.e. (1,0) is mapped to (2,1) by the corresponding linear map. (Any other vector not in the span of (2,1) would also work.)
Since we do not want the image to be larger than the span of (2,1), the other basis vector, (0,1) must be mapped to a vector of the form (2a,a). For (2,1) to be in the kernel of the resulting map, is equivalent to
2*2 + 2a*1=0
1*2 + a*1=0
So one must take a=-2, hence a solution is the matrix with columns (2,1), (-4,-2).
Alright!
So for example, if I was asked to fine the matrix of a linear mapping L:R2 -> R3 whose nullspace is Sp({(1,1)}) and range is Sp({(1,2,3)}), then the matrix turns out to be:
[1 -1]
[2 -2]
[3 -3]
right?
kesun said:
Alright!
[1 -1]
[2 -2]
[3 -3]
right?
Yes.
Hmm...I just found this weird problem:
Let n and m be distinct non-zero vectors in R3, and let b be an arbitrary vector in R2. Is W={b[tex]\in[/tex]R2|(n [dot] x, m [dot] x)=b for some x in R3} a subspace of R2? R3?
First of all, it concerns both R2 and R2, and I am not sure what's the approach for something like this.. :S
Do the vectors of W have 2 or 3 components? This should tell you where W might be a subspace.
Then you will need to check the axioms of a subspace: closure under addition and scalar multiplication, are they satisified?
No. It must also contain the product of a real number (or whatever the base field is) and a vector. For example the set of all integers is closed under addition and subtraction but is not a subspace of R1. Also, since v- v= 0, you don't need "contains 0" but you do need "contains at least one vector".
I wouldn't think of the span as being anything like a "mapping"! The span of a set of vectors is the set of all possible linear combinations of the vectors.
I don't know what you mean by "b is a spanned vector"- you have no spanning set. I wouldn't say "linear transformation of a matrix". A matrix is a way of representing a linear transformation, given a specific basis. Certainly, the range of a linear transformation is a the set of all possible "results": {b| Ax= b for some x}. It is, in fact, exactly the same as the general "range" of a function.
What is a subspace?
A subspace is a subset of a vector space that contains all possible linear combinations of its vectors. In other words, it is a smaller space that exists within a larger vector space.
What is the span of a set of vectors?
The span of a set of vectors is the set of all possible linear combinations of those vectors. This means that any vector within the span can be created by multiplying each vector in the set by a scalar and adding them together.
How is the range related to subspaces and span?
The range of a linear transformation is the set of all possible outputs that can be generated by applying the transformation to a vector. This range will always be a subspace of the vector space that the transformation is applied to, and it can also be described as the span of the transformed vectors.
Why is understanding subspaces, span, and range important in linear algebra?
Subspaces, span, and range are fundamental concepts in linear algebra that help us understand the structure and relationships between vectors and vector spaces. They allow us to solve systems of linear equations, perform transformations, and analyze data in a more efficient and systematic manner.
How can one visualize subspaces, span, and range?
One way to visualize subspaces, span, and range is to think of them as planes or lines within a larger space. The span represents all possible points that can be reached by moving along these planes or lines, while the range represents the points that can be reached by applying a transformation to these planes or lines.
  • Linear and Abstract Algebra
