Uniform rectangular plate equilibrium problem
In summary: You used a single equation with two unknowns, T and θ. You need a second equation to solve for both. In summary, the problem involves finding the angle θ at which the tension in the cable is the least, and then finding the value of the tension at that angle. This can be solved by setting up a system of equations using the given information and solving for T and θ.
kudoushinichi88
129
A uniform rectangular plate of width d, height h, and weight W is supported with its top and bottom edges horizontal. At the lower left corner there is a inge, and the upper right corner there is a cable. For what angle [itex]\theta[/itex] with the vertical will the tension in the cable be the least, and what is the tension?
[itex]\tau=Fd[/itex]
for the angle, it's easy,
[itex]tan \theta = d/h[/itex]
[itex]\theta=\arctan{d/h}[/itex]
but I'm having trouble with the tension of the cable. I managed to derive
[itex] \frac{Wd}{2}=Td\cos{\theta}+Th\sin{\theta}[/itex]
which gives T as
[itex]T=\frac{Wd}{2\left(d\cos{\theta}+h\sin{\theta})}[/itex]
the answer given is
[itex]T=(Wd/2)\sqrt{h^2+d^2}[/itex]
I seem to fail to see the connection
[itex]\sqrt{h^2+d^2}=\frac{1}{d\cos{\theta}+h\sin{\theta}}[/itex]
can anyone show me why is this so?
You did only part of the problem. You found the tension at some angle θ. Now you need to find at what angle the tension has the least value, then find what the tension is.
It seems that there may be a typo in the given answer. The correct equation for the tension T should be:
T = (Wd/2) / cos\theta + sin\theta
This can be derived from the equation you already have:
Wd/2 = Td cos\theta + Th sin\theta
Rearranging and solving for T gives us:
T = (Wd/2) / (d cos\theta + h sin\theta)
To simplify this further, we can use the trigonometric identity:
cos\theta = h/sqrt(h^2 + d^2)
sin\theta = d/sqrt(h^2 + d^2)
Substituting these into the equation for T, we get:
T = (Wd/2) / (d(h/sqrt(h^2 + d^2)) + h(d/sqrt(h^2 + d^2)))
= (Wd/2) / (d^2 + h^2)
= (Wd/2) / sqrt(h^2 + d^2)
Which gives us the correct answer:
T = (Wd/2) * sqrt(h^2 + d^2)
This shows that the tension in the cable is directly proportional to the weight of the plate and the length of the plate (d), and is also affected by the angle \theta. It also shows that the minimum tension in the cable occurs when \theta = 0, meaning the cable is vertical and the plate is in perfect equilibrium.
Related to Uniform rectangular plate equilibrium problem
What is the "Uniform Rectangular Plate Equilibrium Problem"?
The Uniform Rectangular Plate Equilibrium Problem is a mathematical problem that involves finding the equilibrium position of a rectangular plate that is uniformly loaded. This problem is commonly encountered in the fields of physics and engineering.
What is the significance of the "Uniform Rectangular Plate Equilibrium Problem"?
The Uniform Rectangular Plate Equilibrium Problem is significant because it helps us understand the stability and balance of objects in real-world scenarios. It is also an important concept in the design of structures and machines.
What are the key assumptions made in the "Uniform Rectangular Plate Equilibrium Problem"?
The key assumptions made in the Uniform Rectangular Plate Equilibrium Problem include: the plate is rigid, the load is uniformly distributed, and the plate is supported by two or more points along its edges.
How is the "Uniform Rectangular Plate Equilibrium Problem" solved?
The Uniform Rectangular Plate Equilibrium Problem is typically solved using the principles of statics and the equations of equilibrium. This involves balancing the forces and moments acting on the plate to determine its equilibrium position.
What are some real-world applications of the "Uniform Rectangular Plate Equilibrium Problem"?
The Uniform Rectangular Plate Equilibrium Problem has many real-world applications, such as in the design of bridges, buildings, and other structures. It is also used in the analysis of machines and equipment to ensure their stability and safety.
