Fitting experimental data with exponential curve
In summary: This may give you better results. However, it may be more complicated to set up and may require more advanced statistical techniques. It would be best to consult with an expert in this area or do some research on fitting multiple curves with shared parameters.
Chlorophylle
Hello! :-)
I' have a problem...
I fitted experimental data with a second order exponential theoretical curve:
y = A1*exp(-x/t1)+ A2*exp(-x/t2) + y0
and I have these data for 4 repetitions of the same experiment:
first time:
Reduced Chi-Sqr = 6,81066E-4
Adj. R-Square = 0,41005
y0 = 1,60364 (Standard Error = 0,0012)
A1 = 0,03892 (Standard Error = 0,00349)
t1 = 1,80889 (Standard Error = 0,30923)
A2 = 0,29705 (Standard Error = 0,01466)
t2 = 0,05342 (Standard Error = 0,00445)second time:
Reduced Chi-Sqr = 9,52433E-4
Adj. R-Square = 0,34084
y0 = 1,05106 (Standard Error = 8,31296E-4)
A1 = 0,27818 (Standard Error = 0,02292)
t1 = 0,02764 (Standard Error = 0,00432)
A2 = 0,09086 (Standard Error = 0,01005)
t2 = 0,47223 (Standard Error = 0,06265)third time:
Reduced Chi-Sqr = 6,13655E-4
Adj. R-Square = 0,45827
y0 = 0,60035 (Standard Error = 0,00425)
A1 = 0,02735 (Standard Error = 0,0032)
t1 = 4,40428 (Standard Error = 1,76829)
A2 = 0,27926 (Standard Error = 0,01113)
t2 = 0,0895 (Standard Error = 0,00593)
forth time:
Reduced Chi-Sqr = 9,87583E-4
Adj. R-Square = 0,36993
y0 = 0,16076 (Standard Error = 8,19131E-4)
A1 = 0,28751 (Standard Error = 0,02368)
t1 = 0,02714 (Standard Error = 0,00429)
A2 = 0,10903 (Standard Error = 0,01115)
t2 = 0,42818 (Standard Error = 0,05112)
I discarded the second because of the big standard error of t1. But, this has the bigger adj. R squared.
I thought that the first and third are the best, because values A1, A2, t1, t2 are near.
Is this correct?
How can I evaluate them by the reduced chi-squared and adj. R squared. R squared is so low because of the noise..
First of all, a reduced chi-squared test only really makes sense if we can assume that the errors in the term follows a normal (Gaussian) distribution. Have you tried fitting a QQ plot of the data?
Assuming that the data is in fact normally distributed (or close enough to it), it may be possible that the exponential theoretical curve you gave may not give you a good fit of the data. In that case, you may have to try doing some exploratory plots of the data and try fitting various generalized linear or additive models and see if those may fit it better.
Without knowing more, that's the best advice I could give.
Likes 1 person
Thank you! :-)
Here is the fitting:
Plots 1 and 2 look different, even by eye. If they are supposed to have the same shape, something went wrong. Looks like there is a group (1 and 3) and one (2 and 4).
The numbering is confusing, the pictures do not match to the order in the first post.
To compare amplitudes, I think it would be better to fit
A*(f1*exp(-x/t1)+ f2*exp(-x/t2) + (1-f1-f2))
where A is the (not relevant?) overall amplitude and f1 and f2 are relative fractions of the signal.
Alternatively, if the constant (background?) is not related to the exponentials, use
A*(f1*exp(-x/t1)+ (1-f1)*exp(-x/t2)) + y0
Thanks you!
Yes, the numbering was confusing. I corrected it.
That's the problem. They supposed to be the same. That's why I'm trying to evaluate the fitting, in order to find the best.. Is it correct? I don't know what else I can do... The first group has higher R^2 than the second. Is it a correct criterion? to said that 1 and 3 are better?
y0 is not related to the exponentials..
Then your experiment has a problem somewhere.
The easiest explanation I see are different compositions of the samples, if the two exponentials come from different origins. If 1 and 3 just don't have enough of the longer-living component, that's fine if the composition can vary. You should estimate the longer lifetime based on samples 2 and 4 then. You can then use this as fixed parameter to fit samples 1 and 3.
Alternatively (better, but more complicated), make a fit to all samples at the same time.
Likes 1 person
It is the same sample... :-(
I didn't understand.. Could you explain me what you mean?
Currently you make a fit to all data points of sample 1, then you make a fit to all data points of sample 2, and so on.
You could make a single fit to all data points at the same time, where all 4 curves would share the same lifetimes, but have different amplitudes.
1. How do I determine the best fit for an exponential curve on my experimental data?
The best way to determine the best fit for an exponential curve is to use a mathematical model, such as linear regression, to find the line of best fit. This line will closely follow the pattern of your data points and can be used to estimate the values of the exponential curve for data points that were not measured.
2. What is the equation for an exponential curve?
The equation for an exponential curve is y = ab^x, where a and b are constants and x is the independent variable. This equation shows the exponential relationship between the independent and dependent variables.
3. Can I fit my experimental data with a different type of curve besides an exponential curve?
Yes, depending on the shape of your data, you may be able to fit it with a linear, logarithmic, or polynomial curve. It's important to choose the type of curve that best describes the relationship between your variables.
4. How accurate is fitting data with an exponential curve?
The accuracy of fitting data with an exponential curve depends on the quality of the data and the appropriateness of the model used. It's important to carefully analyze the data and determine if an exponential curve is the best fit for your data.
5. What is the significance of the coefficient of determination (R^2) in fitting data with an exponential curve?
The coefficient of determination, or R^2, is a measure of how well the data points fit the exponential curve. It ranges from 0 to 1, with 1 being a perfect fit. A higher R^2 value indicates a better fit, but it's important to also consider the overall pattern of the data and not rely solely on this value.
20K
  • General Math
15K
