Top 10 Questions on Leonard Susskind's "The Black Hole War
  • Thread starter PaulMurphy
In summary, Leonard Susskind discusses the concept that radiation with a wavelength larger than the event horizon of a black hole will bounce off instead of falling in. The escape velocity of the universe after the big bang may have been greater than the speed of light, but there was no place for light to escape to. Gravity is not considered a repulsive force at the singularity of the big bang or black holes. The singularity of a black hole can be said to rotate even though it has no spatial dimensions. The singularity has infinite density but no size, making most of the black hole empty. Matter takes a finite amount of time to reach the singularity from the event horizon. The effect of a time gradient on a string near a
PaulMurphy
1. In Leonard Susskind’s “The Black Hole War,” he says that if radiation has a wavelength larger than the event horizon of a black hole, it will bounce off instead of falling in. I've never read this anywhere else. Can anyone here discuss this topic further?
2. Based on how dense the energy and matter was immediately after the big bang, for how long after the big bang was the escape velocity greater than the speed of light, and thus, the entire Universe was inside the event horizon of a black hole?
3. If gravity was a repulsive force at the singularity of the big bang, why is it not repulsive at the singularity of a black hole?
4. How can a singularity be said to rotate when it has no spatial dimensions?
5. Black holes are described as having a mass, but isn’t 100% of the mass in the singularity itself, which has zero volume? If this is the case, then I think 100% of the volume of the black hole inside the event horizon would have no mass.
6. How does matter ever get to the singularity from the event horizon if time slows to a stop at the singularity?
7. What happens as a string gets close enough to a singularity to experience a time gradient severe enough to distort its vibrational wave pattern?
8. Does the speed of light have any relationship to any process that generates electromagnetic radiation? For instance, does the quantum of energy needed to create the longest wavelength radio wave equal the smallest quantum of energy released to place an electron in the lowest energy orbit?
9. Could the speed of light be a property of spacetime rather than of matter and energy?
10. If all forms of life are entropy engines, taking in low entropy energy and giving off high entropy energy and the arrow of time is the direction pointing toward greater entropy, could a living creature’s perception of time be due to their being entropy engines?
Astronomy news on Phys.org
2.There was very high density everywhere, so there was nothing to 'escape from'.
5.The singularity doesn't have zero volume. Its just small.
6.Once the singularity has been established, no more matter goes into the singularity (from our perspective).
9.Both.
10. Could be. Or that could be a coincidence.
I've never heard of this, but it does sound plausible to me. The photon would exist over an area of space greater than the diameter of the BH, so it might not fall in. But that's just a guess.
I'm not sure this makes any sense. The universe as a whole was compressed, so there was no where for the light to "escape" to at any point. The gravitational force should have been the same everywhere at all points of the universe, unlike a black hole with has a gradiant.
Who said gravity was a repulsive force?
I'd guess the same way that a point particle such as an electron can have intrinsic spin. But I really don't know.
You are correct. The singularity has no size, but infite density. Other than mass that is falling towards the singularity inside the event horizon, the BH would be mostly empty. (I think. I'm not an expert on Black Holes)
I'm not sure, but I know that the proper time for the infalling mass is finite, meaning that it takes a finite amount of time to fall in from its own frame.
String? As in string theory?
To my knowledge the amount of energy needed to create a photon has no lower limit.
Your question doesn't make sense. Everything exists within spacetime, so anything that affects one affects the other somehow. Just like how gravity, which is viewed as spacetime being warped, affects everything within the universe.
No, as even when you have entropy being lowered in a system time still operates in one direction.
PaulMurphy said:
...I think 100% of the volume of the black hole inside the event horizon would have no mass.
Why? Your logic does not follow.
Really? Why not? If the singularity has no volume, then the volume of the space inside the event horizon should be nearly empty, or so I thought.
But why would that affect the mass?
Oh. I see what he's saying. It's flawed logic: If the mass has zero volume, then a larger volume that contains that mass is 100% mass-free. Therefore ... the mass at the centre ... has no mass.
The flaw is that he first grants that a mass could have zero volume, but then goes on to conclude that, if a volume contains that mass, that the mass can't have mass ... why? because it's zero volume.
The mass would be concentrated in the BH in the singularity. There wouldn't be any mass anywhere else. Is that false?
Sure. That's OK.
I thought he was putting forth a paradox.
DaveC426913 said:
Sure. That's OK.
Oh, ok lol.
Thanks for all the replies. I learned a few things already. Here is some clarification:
3. Who said gravity was a repulsive force?
I read about inflation theory in Brian Greene's new book, The Hidden Reality. There is a whole section about repulsive gravity, the inflaton field and negative pressure. In summary, he said the force that caused the faster than light expansion of spacetime during inflation was repulsive gravity.
5...I think 100% of the volume of the black hole inside the event horizon would have no mass.
What I was trying to say is that if a singularity really has zero volume and 100% of the black hole's mass is in the singularity, then 100% of the volume of the black hole within the event horizon would be empty space (except for the background noise of virtual particles caused by quantum uncertainty). I'm creating a contradiction on purpose to show that I don't really believe (yet) that all the mass inside the event horizon truly occupies zero volume yet can still directly interact with exterior spacetime via gravity.
7. String? As in string theory?
Yes, again Brian Greene's books. He says that the strings of string theory vibrate in the extra dimensions and based on the given Calabi-Yau shape they vibrate in, the vibrational pattern gives the particle its properties. A string vibrating in one pattern would be an electron, in another pattern a photon, etc.
I'm wondering if one part of the string is in a slower flow rate of time frame of reference than another part, would that cause distortion to the calabi-yau manifold and change the particle's properties? Say it was vibrating as an up quark and as it gets very close to the singularity, part of it would be vibrating in a different flow rate of time than the rest. Does it become a new type of particle?
But the argument is circular. If you believe that mass cannot occur in zero volume, you don't need to use the convoluted logic to arrive back at the same conclusion.
Paul, trying to discuss ten questions in a single thread is a surefire route to confusion and madness. Questions on different subjects should be in different threads.
Also, most of these questions really belong in other forums than this one (Quantum Physics), IMO. I suggest:
1, 3, 4, 5, 6: Astrophysics
2: Cosmology
7: Beyond the Standard Model
8: Relativity or Quantum Physics
9: Relativity
10: Classical Physics or maybe Philosophy
1. What is "The Black Hole War" about?
The Black Hole War is a book written by physicist Leonard Susskind that discusses the scientific debate surrounding the concept of black holes and their role in the universe.
2. What are some of the key topics discussed in "The Black Hole War"?
Some of the key topics include the paradox of information loss in black holes, the holographic principle, and the role of black holes in the laws of thermodynamics.
3. How does "The Black Hole War" contribute to our understanding of black holes?
Susskind's book presents a unique perspective on black holes and their properties, challenging traditional theories and proposing new ideas. It also sheds light on the ongoing scientific debate surrounding black holes.
4. What are some criticisms of "The Black Hole War"?
Some critics argue that Susskind's ideas are controversial and not widely accepted by the scientific community. Others have questioned the validity of his arguments and the evidence used to support them.
5. Can "The Black Hole War" be understood by non-scientists?
While the book does contain complex scientific concepts, Susskind presents them in an accessible and engaging manner. Non-scientists with an interest in physics and black holes can still gain a basic understanding of the topics discussed in the book.
  • Astronomy and Astrophysics
