How to integrate 0 to 1 (1-x^2)^n
  • Thread starter mecattronics
  • Tags
    Integrate
In summary, the formula for integrating (1-x^2)^n from 0 to 1 is ∫<sub>0</sub><sup>1</sup> (1-x^2)^n dx = (2n-1)!!/(2n+1)!!. The exclamation marks represent the double factorial function, which can be calculated using a factorial calculator or manually multiplying the terms. The integration formula can be simplified using the binomial coefficient or the gamma function. There are many real-life applications of this formula, including calculating areas under a normal distribution curve and solving problems in physics and engineering involving spherical or cylindrical symmetry.
mecattronics
The reduction formula is:
[tex] \int (1-x^2)^n dx = (1-x^2)^n x + 2n \int x^2(1-x^2)^{n-1} dx [/tex]
and the question is:
use this formula above how many times is necessary to prove:
[tex] \int^{1}_{0} (1-x^2)^n dx = 2n \frac{2(n-1)}{3} \frac{2(n-2)}{5} ... \frac{4}{2n-3} \frac{2}{(2n-1)(2n+1)}[/tex]
but I don't know how to get there.
I tried to modify the reduction formula leaving it more recursive:
Integrating by parts:
[tex] =x(1-x^2)^n+2n \int x^2(1-x^2)^{n-1}dx [/tex]
let [tex] x^2 = -(1-x^2)+1 [/tex]
[tex]=x(1-x^2)^n-2n \int(1-x^2)^n dx + 2n \int (1-x^2)^{n-1}dx [/tex]
but I still don't know how to get there with this formula.
Any guidance would be appreciated.
use your last equality and induction.see attached.
mecattronics said:
The reduction formula is:[tex] \int (1-x^2)^n dx = (1-x^2)^n x + 2n \int x^2(1-x^2)^{n-1} dx [/tex]and the question is:
use this formula above how many times is necessary to prove:[tex] \int^{1}_{0} (1-x^2)^n dx = 2n \frac{2(n-1)}{3} \frac{2(n-2)}{5} ... \frac{4}{2n-3} \frac{2}{(2n-1)(2n+1)}[/tex]but I don't know how to get there.
I tried to modify the reduction formula leaving it more recursive:[tex] \int (1-x^2)^n dx = (1-x^2)^n x + 2n \int x^2(1-x^2)^{n-1} dx [/tex]Integrating by parts:
Your last line says that
[itex]\displaystyle \int (1-x^2)^n dx=x(1-x^2)^n-2n \int(1-x^2)^n dx + 2n \int (1-x^2)^{n-1}dx\ .[/itex]
That has [itex]\displaystyle \ \int (1-x^2)^n dx\ \ [/itex] on both sides of the equation.
Solve for [itex]\displaystyle \ \int (1-x^2)^n dx\ .[/itex]
Hi hedipaldi, thanks for your help!
How did you get this formula?
substitute the limits in your last equality.
FAQ: How to integrate 0 to 1 (1-x^2)^n
1. What is the formula for integrating (1-x^2)^n from 0 to 1?
The formula for integrating (1-x^2)^n from 0 to 1 is:
01 (1-x^2)^n dx = (2n-1)!!/(2n+1)!!
2. What is the meaning of the exclamation marks in the integration formula?
The exclamation marks represent the double factorial function, which is defined as:
n!! = n*(n-2)*(n-4)*...*3*1 (for n odd)
n!! = n*(n-2)*(n-4)*...*4*2 (for n even)
3. How do I calculate the value of (2n-1)!!/(2n+1)!!?
You can calculate the value of (2n-1)!!/(2n+1)!! using a factorial calculator or by manually multiplying the terms in the numerator and denominator. For example, if n = 3:
(2n-1)!!/(2n+1)!! = (5!!)/(7!!) = (5*3*1)/(7*5*3*1) = 15/105 = 1/7
4. Can the integration formula be simplified?
Yes, the integration formula can be simplified by using the binomial coefficient or the gamma function. For example:
01 (1-x^2)^n dx = (2n-1)!!/(2n+1)!! = (2n)!/[(n!)^2 * (2n+1)] = 2/(2n+1) * (2n)!/[n! * (n+1)!]
5. Are there any real-life applications of integrating (1-x^2)^n from 0 to 1?
Yes, there are many real-life applications of integrating (1-x^2)^n from 0 to 1, such as calculating the area under a normal distribution curve, solving problems in physics and engineering that involve spherical or cylindrical symmetry, and analyzing the behavior of electric charges on a spherical or cylindrical surface.
