Twin clocks-is it acceleration?
In summary, the document states that if the twins experience the same two acceleration profiles but with different times between them then the twins experience a difference in aging.
phyti
452
Acceleration is an equivalent answer to differential aging only in special cases such as the one restricting all acceleration to one twin.
https://www.physicsforums.com/attachments/56070
Doesn't sound right. If both are accelerating, but with different (vector) functions, the results will be different.
Acceleration is only invoked to break the symmetry between the twins. In this case, it still breaks the symmetry since their acceleration profiles are different.
Not as I read it. The twins experience exactly the same accelerations, just at different times. Actually, the first twin has a long gap between his two accelerations while the second twin has no gap.
But I think it would have been easier to see this if extra time were inserted between both gaps. Then we would see the two twins starting out inertially and colocated (at rest with respect to each other), one of them accelerates (the document says decelerates, but it's the same thing) and then the two twins have a relative separation speed between them. After some time, the second twin accelerates in exactly the same way as the first one did, bringing them to rest with respect to each other but with a constant separation between them. Next the second twin accelerates again in the same direction, possibly with the same acceleration as before but this is not necessary. This causes the twins to have a relative closing speed between them that continually reduces their separation. Just before they make contact, the first twin accelerates in exactly the same way as the other twin's second acceleration, bringing them once more into mutual inertial rest and colocation but with different aging accumulated during their time of separation.
I think this is a brilliant variant of the Twin Paradox that shows that acceleration has nothing to do with the difference in aging and it also can't be used to determine which twin is younger, in other words, acceleration cannot be "invoked to break the symmetry between the twins". It also shows that it is not necessary for the twins to return to the same location that they started out in or even that they need to be at rest in the same frame they started out in. But it has the same "paradoxical" issue that while separated, in each twin's inertial rest frame(s), the other twin's time is dilated.
I just don't understand the U-frame/U-time explanation but like all SR scenarios, the standard explanations using inertial frames work just fine. Did you make the document, phyti? Do you understand the explanation?
That is asymmetric. What is the symmetry operation which maps one twin's acceleration profile to the other?
According to SR the laws of physics are invariant under spatial rotations, spatial and temporal translations, and boosts. If you make an acceleration and time measurement profile that is symmetric under some combination of those symmetry operations then the twins will have the same elapsed age. Otherwise there is an asymmetry and they do not have the same age.
ghwellsjr said:
I think this is a brilliant variant of the Twin Paradox that shows that acceleration has nothing to do with the difference in aging...
The age difference depends on acceleration and the spatial separation during that acceleration.
Different acceleration profiles break the symmetry.
Sorry, I didn't realize that you were including both intervals of acceleration plus the interval of inertial travel between them for the first twin as one acceleration profile. I assumed that the first twin's two intervals of acceleration were separate acceleration profiles.
The document looked to me like it was showing the two acceleration intervals of the first twin concatenated together to form the acceleration profile of the second twin. I broke it apart into two acceleration profiles and inserted a time gap between them (and added the same time gap to the first twin) to make this more obvious in my explanation.
So both twins experience the same two acceleration profiles but with different times between them. It's not the acceleration profiles alone that explain the difference in aging but rather we have to include the time interval between them to get the full story. I just thought this was a brilliant way to counter the argument that "it's the twin that accelerates that ends up younger" and the erroneous conclusion that it is only the acceleration that creates the time difference between them.
phyti, too much focus is given to the acceleration. It's the path lengths through space-time that should be compared, regardless of whether one or both are accelerating and when the accelerations occur.
An "acceleration profile" is the entire history of acceleration between the two meetings. Different timings means different profiles.
If you know the acceleration profiles between the two meetings, you can compute the age difference.
Well how am I supposed to know that except by making this mistake and getting corrected by someone else? Where is the official dictionary of approved relativity terms that I can reference to make sure I never make another mistake like this again?
True, given the official definition of "acceleration profile", did you get the impression that I didn't already know this?
The deceleration profiles are purposely made equivalent, the two for A connected together equal the one for B, in duration and curvature and tangent (speed) vectors. If you employed integration methods for the two complete curved profiles, they are equal. In the traditional simple case, B changes course 3 times, departs, reverses, and returns. He has 3 speed changes to 0 for A, thus his accumulated time is shorter, so the argument goes. Are you going to invoke asymmetry in this case in favor of A because he has 2 changes to 1 for B?
By eliminating the acceleration/deceleration issues, the focus is on the inertial portions, and specificaly on time lost as it relates to speed. The example also emphasizes the time lost is permanent, since there is no speed by which a clock can gain time.
This is my own work. After the continuous rehashing of the 'twin thing', I thought there should be a simpler way, possibly without math, to demonstrate physically why there is differential aging. The U-frame represents a universal time standard, and the red portions represent what's missing after subtracting the dilated time for A and B.
You have a good understanding of the post, thank you.
I find the talk about acceleration "breaking the symmetry" in the twin paradox to be a little misleading. On the one hand, it is true that without invoking weird topologies, it is impossible for the twins to get back together without one or the other accelerating. It's also true, if they do get back together, that if one accelerated and the other didn't, then the one accelerated will be the youngest. But it's not correct, in my opinion, to conclude from this that acceleration somehow is responsible for the difference in ages, as if acceleration causes people to age slower. It doesn't. If you accelerate away from Earth, turn around and accelerate back, turn around and accelerate away, etc. you can arrange that you're always feeling acceleration. But if you never accelerate in one direction long enough to acquire relativistic velocity, then the acceleration isn't going to make you younger than the stay-at-home twin. The formula for elapsed time depends only on velocity, not acceleration.
Here's an analogy that I think is pretty good.
Suppose you hop in a car, and set your trip meter to 0, and travel from New York City to Chicago. What does your odometer read when you get to Chicago? The least it can read is 1270 km. But depending on the path you took, the reading can be different from 1270.
Suppose you hop in a rocket, and set your clock to 0, and travel from New York City in 2013 to Chicago in 2023. The most your clock can read is 10 years. But depending on the path you took, the reading can be different from 10.
The big difference between the two cases is that in the Euclidean geometry governing odometer readings, the straight-line path has the least length, while in the Minkowsky geometry governing clocks, the straight-line path has the greatest elapsed time. These facts follow from the definitions of length:
For Euclidean paths: [itex]L = \int \sqrt{1+s^2} dx[/itex] where [itex]s[/itex] is the slope of the path ([itex]s = dy/dx[/itex]).
For Minkowsky paths: [itex]\tau = \int \sqrt{1-\frac{v^2}{c^2}} dt[/itex] where [itex]v[/itex] is the velocity of the path ([itex]v = dx/dt[/itex]).
It doesn't matter if you call it acceleration or deceleration. They are not symmetric.
In physics, "symmetry" means that something is unchanged under some mathematical operation. In the case of SR, the symmetry operations are spatial and temporal translations, rotations, and boosts. There is no way to turn a(t) for one twin into a(t) for the other twin through any combination of translations, rotations, and boosts. They are not symmetric.
I think we agree that the terms "acceleration" and "deceleration" are equivalent, at least I pointed that out in post #4 which phyti quoted and agreed with.
So are you saying that if we start with two colocated twins at rest with each other and they both identically accelerate in opposite directions, coast for the same length of time and then accelerate identically but in opposite directions so that they approach each other and then finally accelerate in opposite directions to come to mutual colocated rest, then we cannot say that symmetry applies here and we cannot conclude that they are the same age? The mathematical operation in this case is multiplying the acceleration profile of one twin by -1 to get the acceleration profile of the other twin.
Velocity is frame dependent. The age difference after reunion and proper acceleration aren't.
You are missing the point of the twin paradox.
The question is not: "How can I explain the age difference geometrically in one inertial frame?"
The question is : "Why can't I use the same explanation in both twin's rest frames to get the opposite result?"
The answer to the question is : "Difference in proper acceleration profiles"
That is a rotation by 180º, which is a symmetry of SR. We can conclude that they are the same age.
The integral [itex]\tau = \int \sqrt{1-\frac{v^2}{c^2}} dt[/itex] is frame-independent. [itex]v[/itex] and [itex]t[/itex] are both frame-dependent, but the combination
[itex]\sqrt{1-\frac{v^2}{c^2}} dt[/itex] is frame-independent.
It's exactly analogous to the Euclidean formula for the length of a curve:
[itex]L = \int \sqrt{1-s^2} dx[/itex]
where [itex]s = \dfrac{dy}{dx}[/itex] is the slope of the curve at point [itex]x[/itex]. Of course, slope is relative to a coordinate system, but that integral is the same for any (cartesian) coordinate system.
Well, if you are allowing non-inertial coordinates you need the metric contracted with coordinate velocities inside the square root. Obviously your main point is correct.
I think that the answer "different acceleration profiles" for why one twin ages more than the other is misleading. It certainly is true that in flat Minkowsky spacetime, there is no way for two twins to depart and reunite unless one of them accelerates. But using acceleration as the cause of the difference doesn't generalize to other kinds of topologies of spacetime, and doesn't generalize to General Relativity.
In a cylindrical spacetime, you can have twins start off together, depart and reunite later without either twin accelerating. I guess you could say that such an example goes beyond SR, but it doesn't involve any gravity, so it's not very GR-ish, either. It's just geometry.
Unfortunately, with GR and non-standard topology for SR, the 'straight line' analogy to Euclidean geometry breaks as well. You have multiple geodesics, and typically only one of them is longest in proper time. The truth ends up being hard to accept for neophytes: there exists one or more paths of longest time; every other path encompasses less time; this fact is independent of conventions like coordinates; there is no way to say 'where' faster aging is. For some reason, people who can accept that for lines on a paper, "one line is longer" is all that you can say, cannot accept the same for world lines. Oh well.
phyti said:
Acceleration is an equivalent answer to differential aging only in special cases such as the one restricting all acceleration to one twin. [example of different velocity histories with equal accelerations]
Acceleration is indeed necessary to break the symmetry in SR (thus ignoring gravitational time dilation); it was the purpose of the "twin" example to clarify that fact. It should be stressed that what matters for the SR calculation is the velocity profiles. Of course, those can be obtained from the accelerations as function of time.
A.T. said:
[..] You are missing the point of the twin paradox. [..] The answer to the question is : "Difference in proper acceleration profiles"
The point of the twin paradox was that different from uniform translational motion, acceleration - a change of velocity - has "absolute" effects: http://en.wikisource.org/wiki/The_Evolution_of_Space_and_Time (from p.47)
Change of velocity, as observed from an inertial frame, has frame invariant effects. This is also known as proper acceleration.
It is the answer for the flat spacetime version.
The paradox in flat spacetime is based on (a misinterpretation of) the lack of a preferred inertial frame. In a cylindrical spacetime, you have a preferred inertial frame, so there is no paradox that needs to be resolved.
But you cannot build such a simple system for the rest frames of both twins, which is the presumed assumption and basis of the paradox. The reason for this, and thus the resolution of the paradox, is different proper acceleration. The point is not how to compute the age difference in an inertial frame, but to explain why you can't do the same simple calculation in the accelerating twin's rest frame.
stevendaryl said:
It's just geometry.
The explanation (of the flat space time version) based on proper acceleration also becomes "just geometry", if you introduce the appropriate space time geometry into the non-inertial frame.
Yes. That's the reason I think that looking for something that one twin or the other did that "breaks the symmetry" is a little misleading. They don't have to do anything different, it's just that different spacetime paths have different lengths.
Right.
But the paradox can arise (in SR with a nontrivial topology for spacetime) with no acceleration at all. So it doesn't make sense to me to say that acceleration made the difference. Even without acceleration, different paths have different associated proper times.
There is no paradox in either case. If you're making the empirical claim that people are more confused by the usual twin paradox than they are by the one in cylindrical spacetime, I don't think that's true. And it's exactly because they've heard "acceleration breaks the symmetry" that causes people to get the wrong answer in the case of a cylindrical spacetime. It's also true in General Relativity that two geodesics that start together, depart, and come back together can have different proper times. So talking about acceleration isn't really getting to anything fundamental about why twins can have different ages when they reunite, since it only applies to one case.
I don't like that way of putting things. The geometry of spacetime is independent of observer. There isn't a different geometry for inertial observers and noninertial observers.
I assume what you mean is that you can describe the geometry of spacetime using noninertial coordinates, and that's certainly true.
"Apparent" is implied, although some say that the word "paradox" already means "apparent contradiction". Semantics.
It is a different scenario, with a different reason for the asymmetry.
  • #31
Yes. I'm not against geometrical explanations. But if you do it only in the inertial frame, you are not really addressing the issue.
  • #32
Is your point for the scenario in this thread that it doesn't apply to the Twin Paradox because neither twin is inertial?
So the only kind of answer that you will accept is one that shows an inertial explanation for the inertial twin and simply asserts that no such explanation applies to the non-inertial twin (simply because he is non-inertial)?
So when the questioner correctly points out that in the inertial twin's rest frame, there is a constant Time Dilation for the non-inertial twin (assuming instant turn-around), but the rest frame for the non-inertial twin is non-inertial and so it is an incorrect comparison and we simply stop right there. We just call foul?
  • #33
I agree with you, that's why the post. The accumulated time on a clock depends on the path. Obviously there must be a change in speed to assume a new direction. Ignoring the separation and reunion, we could easily have the A clock do a reversal, then both paths woud be 'bent'. Which acceleration/deceleration (there is a difference) counts?
Examining the expression for time dilation, the only factor is v/c. The space-time drawing with ct and x axes represents what?...speed, i.e. object motion vt vs. light motion ct, or v/c. The velocity change can be approximated with a series of inertial segments, without any significant loss of accuracy.
  • #34
I don't understand this comment. Geometrical explanations are frame independent, they are not done in any frame. If an explanation uses any frame then it isn't a geometrical explanation.
However, I agree with what I think is your main point that the answer must be in terms of some asymmetry.
  • #35
I agree. Geometrically the acceleration is the "bend" in the worldline. That bend breaks the symmetry but by itself it doesn't add or subtract any length to the worldline.
