Can Pure Helium White Dwarfs Support a Habitable Zone for Billions of Years?
In summary, Eric Agol's recent paper discusses the habitable zones of white dwarfs (WDs) and their cooling pace. While he uses models of Carbon core WDs with helium atmospheres, it is possible that pure helium WDs would last three times longer due to their higher opacity. However, this could also result in a shorter CHZ lifetime of 5-8 Gyr due to their faster cooling rate and potential thermal instabilities.
qraal
790
Just pondering Eric Agol's recent paper on White Dwarf habitable zones and the pace of cooling of white dwarfs (WDs.) He uses models of Carbon core WDs with helium atmospheres, but I am wondering if pure helium WDs would last three times longer. Opacity from the atmosphere slows down heat loss significantly else WDs would cool very quickly since the interior is nearly isothermal from highly efficient heat conduction. Thus there should be three times the heat energy available since helium masses one third carbon and energy of a gas depends on the numbers of atoms, not the whole mass.
In theory higher opacity in Red Giant stars should blow off enough mass before the Red Giant Tip and the Helium flash, so that the Helium Main Sequence is never initiated. Thus a pure helium WD should be possible, given sufficient mass-loss by its Main Sequence precursor. So instead of a maximum CHZ lifetime of 8 Gyr, there should be a 24 Gyr CHZ lifetime for a well placed planet.
Astronomy news on Phys.org
However, the actual lifetime of a pure helium WD is likely to be much shorter than this due to the lower opacity of the atmosphere. Pure helium WDs are expected to cool faster than Carbon core WDs due to their lack of significant carbon opacity. This could reduce the CHZ lifetime by a factor of 3-5 relative to a Carbon core WD. Thus the maximum lifetime of a pure Helium WD CHZ could be around 5-8 Gyr. In addition, the actual lifetimes of pure helium WDs may be further reduced since they are expected to suffer from a form of thermal instabilities known as the 'double degenerate instability', which can cause rapid and extreme cooling. This could limit the lifetime of a pure helium WD CHZ to just a few billion years.
FAQ: Can Pure Helium White Dwarfs Support a Habitable Zone for Billions of Years?
1. What is a white dwarf?
A white dwarf is a small, dense star that is the remnant of a low or medium mass star after it has exhausted all of its nuclear fuel and shed its outer layers.
2. How do white dwarfs cool?
White dwarfs cool by radiating their remaining thermal energy into space. As they cool, they also shrink in size and become dimmer.
3. What is the cooling time of a white dwarf?
The cooling time of a white dwarf varies depending on its mass, but on average, it takes billions of years for a white dwarf to cool to a temperature where it is no longer detectable.
4. How does the cooling time of a white dwarf affect its luminosity?
As a white dwarf cools, it becomes less luminous, meaning it emits less light. This is because the star has less thermal energy to radiate into space.
5. Can white dwarfs ever stop cooling?
No, white dwarfs will continue to cool until they reach a temperature of absolute zero, which is not possible according to the laws of physics. However, their cooling rate will become extremely slow as they approach this temperature.
