Servo Motors: Precisely Control Force & Pressure
In summary, there are two main types of servo motors - hobby servo motors and general servo motors. General servo motors use an encoder to measure the shaft's position and speed, allowing for control of power output. To control force or pressure, a force sensor can be used in the feedback system along with the position sensor. Torque is a better property to measure than force, and this can be calculated using a current sensor and combined with the position sensor in the feedback system. This allows for control of both angular position and force applied by the motor.
KingNothing
881
A normal servo motor gives a highly accurate response to an input, with the output being an angular position of the shaft. For example, give it a 2ms pulse and it might go to +63 degrees.
I am wondering what sort of motor (or system) is used to control an amount of force or pressure. For example, say I have two metal plates which I want to press together with a very specific force. How is this accomplished?
it sounds to me as if you are talking about a press. whether to stamp out a part from steel or press liquid out of a slurry i would not try and do it with a direct mechanical linkage to a motor. this is a high stress situation in which, it is my opinion that hydraulics are the best option. a simple AC induction motor drives a hydraulic pump which sends hydraulic pressure to a piston with some flow control and pressure relief valves on your pressure lines to control the system.
if it is NOT a high stress application you could go the rout of transferring the angular positioning into linear positioning using a screw shaft (lead screw) and a ballnut on a carriage or trolley. the server would provide and highly accurate positional response that is converted to linear consistently and measurably.
here is a website showing what i am talking about with the screw shaft (lead screw)
http://www.thomsonbsa.com/
did i understand what you were trying to accomplish correctly?
Just a bit of clarification...
Your description of a "normal servo motor" sounds more like what many call, with justification, a "hobby servo motor". These are used in a radio controlled airplane to adjust flaps and such-like. They move to a particular angular position based on the width of an input pulse. They don't have a way to adjust the output power -- pretty much whatever the motor is rated for is what you get.
The more general type of servo motor is, usually, a DC motor with an encoder that senses the output shaft's position and speed. The controller for such a motor can then supply a varying amount of power to move the motor's shaft at a particular speed or to a particular position using feedback from the encoder. The input to this system could be step-pulses (like a stepper motor) or a voltage proportional to the desired speed. You can probably imagine how one would make a hobby-servo using such a thing, but that's only one possible application.
Using the "raw" servo capability one can indirectly adjust the power output of the motor, but it's very dependent on the load and motor capabilities. You could combine a strain-gauge or accelerometer with the encoder signal to provide force feedback to accomplish your variable press application.
angular position motors measure their current position with a sensor (rotary encoder, hall sensors, potentiometer, etc.) and then use a feedback system to adjust the voltage in the motor until the position they measure is stable and at the value that they want. The same can be done for a motor if you change the sensor to a force sensor and put the measurement into a feedback system.
Torque is a better property to talk about than force with a motor, and most motor datasheets have a value called the torque constant Kt in units of N-m/Amp. You can use a current sense resistor, current mirror, or some other current sensor that tells you how much current is going into the motor, and then you can calculate the amount of Torque the motor is applying. Combine this with your position sensor, and you can determine over how many Newtons are applied per distance, and combining these two measurements you can put them into a feedback system that will vary the voltage into the motor to keep the force at the value you command it.
So a motor can control both angular position and force applied depending on your load.
FAQ: Servo Motors: Precisely Control Force & Pressure
What are servo motors and how do they work?
Servo motors are motors that use feedback control to precisely control force and pressure. They work by receiving a signal from a controller, which tells them how much force or pressure to apply, and then using an internal feedback mechanism to adjust their output accordingly.
What are the advantages of using servo motors?
Servo motors offer several advantages, including precise control over force and pressure, high torque at low speeds, and the ability to hold a specific position without drifting. They also have a wide range of applications, from robotics and automation to industrial machinery and medical equipment.
What are the main components of a servo motor?
The main components of a servo motor include a DC motor, a gear train, a position feedback device (such as an encoder or potentiometer), and a control circuit. Some servo motors may also have additional features, such as a servo drive or servo controller, for more advanced control and monitoring.
How do you select the right servo motor for a specific application?
Selecting the right servo motor for a specific application involves considering factors such as the required torque and speed, the type of motion (rotary or linear), the power supply and voltage, and the environment in which the motor will be operating. It is also important to choose a motor from a reputable manufacturer and to consult with an expert if needed.
What are some common applications of servo motors?
Servo motors are commonly used in robotics, industrial automation, CNC machinery, medical equipment, and other precision control applications. They are also found in everyday devices such as cameras, printers, and RC cars, where precise motion control is needed.
