The Relativity of Simultaneity: A Fundamental Concept in Special Relativity
In summary, RoS is a consequence of time dilation, which is a feature of the Lorentz transform. It is not a separate stand-alone component of SR.
  • #36
mangaroosh said:
am I at least [some way] right in thinking that if all clocks ticked at the same rate then absolute simultaneity would prevail; but because clocks tick at different rates RoS prevails?
No, I explicitly showed that to be incorrect above, and I have stated it clearly multiple times.
  • #37
mangaroosh said:
My interpretation of it would be that, if the clocks which give the time co-ordinates all ran at the same rate, then absolute simultaneity should prevail; and in order for RoS to prevail clocks would have to give different times (co-ordinates).
This interpretation is incorrect. dt'/dt=1 so all of the clocks run at the same rate.
mangaroosh said:
That would be another thing that I don't understand, namely how, or why, the time co-ordinate would include a spatial term.
If the transform is linear (I.e. Both frames are inertial) then the transform in general includes a spatial term. It may be that the coefficient is zero, but that is an additional assumption.
  • #38
in some sense, it makes no sense. But this may offer a way to begin to think about it:
A simple minded thought experiment: picture an x,y plot...as two particles move around there in different paths, they experience different rates of x and y distances covered,,,right? we don't normally think much about that...each would observe the
other moving differenty through space [distance] than themselves...
now consider a plot of time versus,say, x distance: observe two particles moving differently... say straight lines with different slopes as an example...one moves faster thru time and another faster thru distance [space]. We observe the particles and each observe's the other moving differently through time and the x direction than themselves...all the
observations are 'correct' but they are also 'different'.
  • #39
Hi Dalespam, are you referring to another thread, because I only saw your response on the first page of this one and had a few questions about it?
I'm sorry, I don't really understand what dt'/dt=1; I am familiar with the notation from high school maths but I'm not sure how to interpret it in this context.
Where I am not clear is why there is absolute simultaneity according to Lorentzian relativity but RoS according to Einsteinian. Do both not use the same transformations?
  • #40
I explicitly showed it to be incorrect here:
https://www.physicsforums.com/showpost.php?p=3751522&postcount=2
And I stated it clearly here:
https://www.physicsforums.com/showpost.php?p=3747625&postcount=57
https://www.physicsforums.com/showpost.php?p=3747739&postcount=59
https://www.physicsforums.com/showpost.php?p=3752737&postcount=11
It means that the ratio of the time in one frame to the time in the other frame is 1, i.e. time is not dilated.
  • #41
DaleSpam said:
I appreciate you taking the time to reply DaleSpam, but it was the comments in "the constancy of c" thread lead to me starting this thread, to try and get a better understanding. You posted a few responses in the first page of this thread, the first being post #2; I replied to that explaining that I didn't fully understand the logic as represented by the maths; your subsequent reply was an expansion on that point (post #11); to which I posted some questions in reply. From there the discussion of my reply to your post was continued with George and Harry, where I outlined my rationale; your next reply was post #36 where you said that you had explicitly addressed the issue in a previous post (in the thread) and has stated it countless times. As mentioned, however, there were subsequent questions to that clarification which lead to the conversation with George and Harry.
I do appreciate your taking the time to entertain my questions, and I'm sure you're probably addressing countless other [perhaps equally naiive] questions, so it will hopefully reduce any frustration you might be feeling by highlighting why I still haven't got my head around the issue, despite your generous attempts to clarify it.
Thanks for the clarification.
My trouble with "getting it" lies in the difference, or lack thereof, between Einsteinian relativity and Lorentzian relativity; do I understand correctly that there is essentially no difference between the mathematics of both interpretations?
If so, the trouble I have is understanding how one interpretation includes RoS while the other includes absolute simultaneity. George suggested that it is down to the different assumptions about the propagation of light, but I don't see how that would lead to RoS without some intermediary step(s).
If my understanding is correct, and the mathematics is the same for both theories, then I'm not sure a mathematical explanation will address the issue; I would imagine it has to be more of a theoretical consideration of what the maths represents.
  • #42
Hello Mangaroosh,
May I suggest yet another way of answering your two questions about Relativity of Simultaneity [RoS]? You might find it simpler to understand, and I am confident that DaleSpam, Ghwellsir, and other posters who have been answering your questions so tirelessly will vouch for its correctness:
Your OP question is,
mangaroosh said:
this might seem like yet another basic question, but I was wondering about RoS. The impression that I got from reading about relativity was that relativity of simultaneity was a consequence of Lorentz contractions, primarily time dilation.
And your latest post question is (with [SR] & [LET] inserted for clarity):
mangaroosh said:
... the trouble I have is understanding how one interpretation [SR] includes RoS while the other [LET] includes absolute simultaneity. George suggested that it is down to the different assumptions about the propagation of light, but I don't see how that would lead to RoS without some intermediary step(s).
Fortunately in this case, both questions can be addressed without Lorentz transforms, clocks or rulers. The price of using this approach is that we cannot quantify RoS, but we can demonstrate its existence.
Relativity of Simultaneity means simply that two events, separated by a distance from one another, and simultaneous according to one competent observer are not (generally) simultaneous according to another moving relative to the first at some constant speed.
The simultaneity of two events can be established using a shuttered lamp on a track between two distant mirrors positioned on the track to reflect any light pulses from the lamp back to it and yourself, the observer. The mirrors need not be at rest and may move independently at arbitrary speeds along the track. Suppose that you are very quick with the shutter and send an extremely brief pulse of light towards both mirrors. If the reflected pulses from both mirrors happen to return simultaneously, what can you legitimately infer? Since by Einstein's postulate, light moves at one speed only, you know these two things:
1. the mirrors were equidistant from the lamp at the time of the reflection, and
2. the two reflections occurred simultaneously.
Now suppose that a second observer happens to be moving along the track just as you send your light pulse from the lamp. Will he agree that the reflections were simultaneous? No. By the time the two reflected pulses meet at your lamp, observer #2 has moved some distance along the track, and correctly notes that the two pulses did not "return" simultaneously to his "here", and for that reason, by Einstein's postulate he must infer that the two reflections did not occur simultaneously.
The LET interpretation predicts exactly the same phenomena, but differs from SR only in that it insists that light depends upon a hypothetical medium, or aether, Therefore the method of "simultaneous arrival" for determining simultaneity is valid only for an observer who is motionless in the aether, and there is only one "true" definition of simultaneity -- that of the motionless observer. Einstein's great insight was that the aether hypothesis was completely superfluous.
- Regards
  • #43
Hi I answered that in post #28 and also, indirectly, in post #31. RoS corresponds to the "local time" concept as interpreted by Poincare but Einstein interpreted it differently. Did you study the references? Is there something unclear about it?
  • #44
mangaroosh said:
[..] My trouble with "getting it" lies in the difference, or lack thereof, between Einsteinian relativity and Lorentzian relativity; do I understand correctly that there is essentially no difference between the mathematics of both interpretations? [..]
Apparently you missed my post here, in which I explained this in detail and with a lot of precision:
https://www.physicsforums.com/showpost.php?p=3756233&postcount=54
Harald
  • #45
It would probably be fair and correct to say that the mathematics going into and coming out of the Lorentz Transformation and their usage is very different comparing Einstein-Minkowski and Lorentz-Poincare relativity. While the Lorentz Transformation itself is obviously common. For the most part, Lorentz worked with vectors, differential equations and their initial and boundary conditions. Einstein and Minkowski built a platform where those things were abstracted away in which tensors and 4-vectors are preferred.
  • #46
http://en.wikipedia.org/wiki/Relativity_of_simultaneity
From wikipedia:
"A popular picture for understanding this idea is provided by a thought experiment consisting of one observer midway inside a speeding traincar and another observer standing on a platform as the train moves past. It is similar to thought experiments suggested by Daniel Frost Comstock in 1910[1] and Einstein in 1917.[2][3]
A flash of light is given off at the center of the traincar just as the two observers pass each other. The observer onboard the train sees the front and back of the traincar at fixed distances from the source of light and as such, according to this observer, the light will reach the front and back of the traincar at the same time.
The observer standing on the platform, on the other hand, sees the rear of the traincar moving (catching up) toward the point at which the flash was given off and the front of the traincar moving away from it. As the speed of light is finite and the same in all directions for all observers, the light headed for the back of the train will have less distance to cover than the light headed for the front. Thus, the flashes of light will strike the ends of the traincar at different times."
Is this helpful? According to SR the speed of light on Earth is not c in relation to the gravitational field of the Earth but relative to "any inertial frame". Thus the observer on the platform sees the front- and the backside of the wagon lit up at different times but the guy on the train will think that the front and the backside of the train are lit up simultanesously, because the light coming back from the rear and the front end of the wagon walls will hit him simultaneously.
I think this type of thought experiments are always what is meant when someone talks about "relativity of simultaneity", but I might be wrong...
  • #47
James_Harford said:
Hello Mangaroosh,
- Regards
Hi James, thanks a million for taking the time to reply.
I hope I'm using the right phraseology here when I say that, under Galilean transformations we would expect the moving observer to measure a different speed of light to the pulse operator, but under Lorentz transformations this isn't the case; is that accurate?
Lorentzian relativity maintains absolute simultaneity, while Einsteinian relativity incorporates RoS. I don't think we're too concerned with Lorentzian relativity in this particular instance, what we're looking for, or rather, what I'm trying to understand, is what phenomena must occur in order for the speed of light to remain constant for all observers, regardless of their motion realtive to the source of the light; which appears to be the reason given, why RoS prevails. That was essentially the point made by George, so I presume he would agree with your statement to a similar effect.
One thing he might disagree on is that Lorentzian relativity necessarily includes the superfluous concept of an aether.
ghwellsjr said:
nowadays, when we speak of LET, we have striped it of everything except the idea of a preferred rest frame.
  • #48
Hi Harry, the conversation with DaleSpam is in reference to mathematical transformations, while your reply in post #28 was with respect to clocks; unfortunately I don't have the nous to make the connection between the two, so I find it more beneficial to engage with the point that is raised and see where it goes.
I had a quick glance at the reference in post #31, but statement immediately following the link was something you had mentioned before, with respect to detecting absolute simultaneity (or the time on a distant clock) and which I had addressed in #18; so that affected my judgement of the necessity to go through it in detail. Is there a specific part that I can jump to that would address the issue?
Just reading back over the exchange I realize that I didn't address reply in #20 directly. I tried reformulating the question, which lead to your reply in #28, which appears to just be a reformulation of the same reply that was questioned previously.
Post #20:
harrylin said:
We understood your intention, which appears to be based on an unfounded assumption. Clocks are man-made and when you put a battery in it you can set it at any time you want. Thus, in order to have two clocks tell the same time, you have to do that.
You seem to have already a difficulty with getting two distant clocks synchronized according to yourself, despite your suggestion that all clocks will be automatically synchronized with all other clocks according to everyone. Nevertheless it was only an introduction to the next question: how can you do that in such a way that everyone will agree?
The issue being raised appears to be the idea of detecting absolute simultaneity; but that isn't necessarily an issue that needs to be addressed. We don't need to figure out how to synchronise clocks to say that if all clocks remained synchronised then there would be absolute simultaneity; it's somewhat of a tautology. If any clock falls out of sync, and the change isn't due to mechanical processes, then RoS prevails; if the change is down to mechanical processes then absolute simultaneity prevails - that is assuming that a clock measures time, because if a clock doesn't measure time, then we have no way of measuring time, and it wouldn't necessarily be something that could be dealt with in physics - as someone mentioned in another thread on here a while ago, pertaining to the MMX.This is #28, which, as mentioned, appears to just reformulate the issue of detecting absolute simultaneity.
harrylin said:
In Lorentzian relativity there is absolute simultaneity that cannot be measured, as well as "local time". Poincare pointed out that clocks measure local time. This local time already had the characteristic of relativity of simultaneity before relativity, but until 1904 it was only approximate. Einsteinian relativity considers only what can be measured; consequently he calls "local time" simply "time".
A similar thing happened earlier in classical mechanics: Newtonian mechanics distinguishes absolute velocity that cannot be measured as well as relative velocity that can be measured. Classical mechanics only deals with relative velocity.
  • #49
Harald
I didn't miss it, my reply was deleted because I used an invalid reference; although I didn't intend for it to be a reference per se, rather as a means of explaining a point that was made more eloquently than I could have done.
I'll PM you the reply, but I'd prefer to continue the discussion in an open thread. Perhaps if I PM you, you might be able to paraphrase the quote in your reply, for the posterity of the thread - that is if you deem it worthy of reply, of course.
  • #50
That is fine. If you don't understand then ask new questions that will help me get at your root concern. But if you merely repeat the same incorrect claim that I answered already then all I can do is as I did above and refer back to my previous answers.
You are correct, I was traveling for about two weeks with reduced time and access. However, I did find it frustrating to come back and find you repeating the same mistake that I already addressed weeks ago.
I don't think that anything productive will come from a discussion of Lorentzian relativity. It is a defunct interpretation which asserts the reality of undetectable entities. All of the confusion with LET comes from the simple fact that the aether is undetectable, so in LET you continually have to make careful distinctions between measurements and what is happening in (undetectable) reality. It is a rabbit hole not worth going down.
  • #51
Try the reply without the invalid reference. Btw, I saw the reference, and if that is the kind of material that you are trying to learn relativity by reading then it is no wonder that you are confused.
  • #52
From wikipedia:
Thanks Agerhall, I am familiat with the thought experiment alright, and it is essentially the same one that James posted, I think.
What phenomena occur that means the speed of light is c "in any inertial frame"? We would, ordinarily, expect the moving observer to measure a different speed of light - why is this not the case?
  • #53
mangaroosh said:
I didn't miss it, my reply was deleted because I used an invalid reference; although I didn't intend for it to be a reference per se, rather as a means of explaining a point that was made more eloquently than I could have done. [...]
Then, evidently, you did not understand it. As Dalespam suggests, you can simply re-post the reformulation of your question without including a link to a crank(?) site.
  • #54
If you first assume that the speed of light is c in relation to the guy standing on the platform. The guy on the platform would classically expect that it takes longer time for the light from the guy on the train to reach the back and front wall and bounce back towards the guy on the train than if the train had not been moving. You can do the math, it is simple.
However, in Special Relativity the Time Dilation formula kicks in and it so happens that if the guy on the platform would expect it to take a factor k longer for the light to reach the back and front wall and get back to the guy on the train again, then the time for the guy on the train slows down with the same factor k so he thinks the two way speed of light has the same value, c, no matter what the velocity of the train relative to the ground is...
In this way the "two-way speed of light is the same in all inertial frames".
I believe this is how it is always explained...
  • #55
The way you describe it, you probably mean the ceiling and the floor. :rolleyes: Else you should add length contraction to the mix...
And to top it off (in view of the topic!), one usually makes the one-way speed equal to the two-way speed by means of the Poincare-Einstein synchronization procedure.
  • #56
Your OP question:
And your latest question about LET:
are answered in my earlier post. I guess I missed that you have a third question:
mangaroosh said:
I don't think we're too concerned with Lorentzian relativity in this particular instance, what we're looking for, or rather, what I'm trying to understand, is what phenomena must occur in order for the speed of light to remain constant for all observers, regardless of their motion realtive to the source of the light...
May I suggest that we work on them one at a time? Bouncing back and forth between all of them and adding time dilation and lorentz contractions and LET makes all of this a rather poisonous mix of unrelated factors. Please go back to my earlier post and note that it fully answers your first two questions, as stated. The only valid questions about that post are
1. Is it a correct analysis?
2. Do you understand it?
If you do not, then, I would not go on to the third question until you do.
If you do, then you have just the third question.
That question, unlike the others, is about the ratio of a time and a space measurement, and this unavoidably requires some level of understanding of the Lorentz transforms themselves, which is bad news for you. Give up the notion that time dilations and Lorentz space contractions are sufficient. You will fail. You need a complete coordinate transformation, because only that gives exactly the differences in how the various observers make these measurements.
I would recommend that you start playing around with pencil and paper with various XT coordinate systems, and see if you can find (by trial and error) two coordinate systems in which the path of a photon (a slanted line) has the same speed. Whether you succeed or not, the exercise will get you past a psychological obstacle and improve your chances of grasping what your friends here are telling you.
I doubt it.
- Regards
  • #57
yes. Galileo would have EXPECTED to measure a different speed, but if he had the proper apparatus, would have been dumbfounded when he actually observed the fixed speed of light! And probably so would have Newton.
Dalespam:
YES! YES! ...I was just about to post similar when I realized there is this last page.
Harford:
again, YES! Let's get the proper theory explained, then it
will become clear why older theories were inadequate.
The HISTORY section here explains why such confusion reigned before Einstein...nobody had Einstein's physical insights...
http://en.wikipedia.org/wiki/Minkowski_space
  • #58
Does this not just verify the point of the OP that RoS is just a consequence of Lorentz contractions, and isn't necessarily a separate, third aspect of Einsteinian relativity?
  • #59
Apologies DS, I tend to treat each conversation individually and try not to take it for granted that every poster reads every post, so I tend to restate certain points for the purpose of the conversation. A number of the times I have restated the point, however, has either been in somewhat different context or for the purpose of reformulating for clarity.
I would argue, though, that the times I have restated it it hasn't necessarily been superfluous to the two-way conversation. I can understand how it might be frustrating to read the same point repeated, particularly when you are under the impression that you have already answered it, but, as mentioned, I had subsequent questions which were taken up by someone else; this lead me to repeat and/or reformulate the point for the purpose of that discussion.
The purpose of this thread isn't necessarily to discuss Lorentzian relativity, I think it is sufficient to discuss it in the competing theories thread; the purpose of bringing up Lorentzian relativity here, was solely to juxtapose it with Einsteinian relativity for the purpose of clarification; namely that it appears that the same transformations can result in both absolute simultaneity and RoS. The question that is begged from that is, what is the difference between the two; why RoS under one interpretation, but absolute relativity in the other?
Please forgive the repetition there, I'm using it solely to emphasise that the question hasn't been addressed just yet.
I'm not sure the specific example of the transform you gave fully addresses the question, because the question is more general. It might be the case that length contraction and time dilation do not lead every single event to be relatively simultaneous, but if time dilation and/or length contraction never occurred at all, anywhere, would RoS still prevail?
It's not so much that I'm confused, rather I haven't made the logical connection yet as to how RoS is separate, stand-alone aspect of Einsteinian relativity and not just a consequence of Lorentzian contractions.
It's probably also worth pointing out that I don't try to learn relativity from sources such as the one posted; I learn relativity largely from discussions with people on sites like this, from the references they post and from my own searches; however, I tend not to simply accept as gospel what I am told, and try to subject such things to critical inquiry, which usually serves the purpose of developing a better understaning; on that basis I will consider alternative viewpoints as long as they stand up to reason, and of course experiment.
The "reference" posted seems to make quite a reasonable point about the propagation of light, which I haven't seen considered elsewhere. Unfortunately I'm not in a position to subject it to the level of critical reasoning required so I can only present it as it is and see if there are arguments against it. However, as it strikes me as being quite reasonable, and conforms to [more reliable] information I have encountered previously, I would lean more towards accepting it (without accepting it fully).
Incidentally, I posted the reply without the reference in the other thread.
  • #60
James_Harford said:
Your OP question:
I doubt it.
- Regards
Hi James, if possible I'd like to change the first question; I didn't formulate it in reply to yourself, but did in reply to Agerhall.
Your explanation was based on the second postulate, the constancy of c in every reference frame, regardless of the motion relative to the source. The question that arises from that is, what phenomena have to occur to allow for this possibility? Ordinarily, with the addition of velocities we would expect the moving observer to measure a different speed of light; what phenomena occur that leads to him measuring the speed of light to be the same as the other observer?
  • #61
DS, just wondering if you would agree with what George said was accurate, that Lorentzian relativity had been divested of all the trappings except for the absolute rest frame?
  • #62
Thanks Phil.
The points being raised appear to pertain to the Lorentz transformation; does it make sense then to ask why the transformation under one interpretation has RoS while under the other interpretation has absolute simultaneity?
  • #63
I could be completely wrong Harry, but based on your posts and the fact that you mentioned you prefer to base your understanding on Einstein's original German paper I would guess that either English or German is your native language - of course you could be form a bilungual family. But if one of them isn't your native language, then you presumably have experience in learning a foreign language. If so, I'm sure you will have noticed that there is usually a disconnect between how much a person can understand and how much they can express themselves, such that it is possible to understand something without necessarily being able to express it [adequately] in your own words. The inability to express it in your own words wouldn't necessarily mean that you haven't understood something that has been said.
The post has been re-posted without the link. As to whether or not the site is a "crank" site, I prefer to examine the content and judge it on that basis.
  • #64
I specifically addressed that in the math above. In one transform I showed there can be no length contraction nor time dilation at all, anywhere, and there is still RoS.
The opposite claim is that the RoS is a consequence of length contraction and time dilation, and I disproved that claim also by providing a transform that had length contraction and time dilation, but no RoS.
Both claims have been disproven by counter-example. I don't know why you persist in them.
  • #65
He and I disagree about LET, but it is such a useless topic that I do not intend to dispute it, neither with him nor with you.
  • #66
I have a few questions relating to that, so if it is possible to proceed from here I might be able to get my head around it.
Were the transformations you gave for just one event EDIT: between two reference frames?
Would the same transformations be used in Lorentzian relativity and not include RoS in any of them?
In the example of the transform where there was no RoS, would we conclude that absolute simultaneity prevails, right across the universe, under the Einsteinian interpretation?
  • #67
mangaroosh said:
Were the transformations you gave for just one event?
They were for all events.
Those transforms are not the Lorentz transform, so it is not used in LET.
Again, those transforms are not the Lorentz transform, so it is not used by SR.
  • #68
sorry, you've thrown me with the last 2 comments; I thought we were talking about Lorentz transformations under Einsteinian relativity.
EDIT: that might be where the confusion is arising from.
  • #69
mangaroosh said:
Apologies DS, ... I can understand how it might be frustrating to read the same point repeated, particularly when you are under the impression that you have already answered it, but, as mentioned, I had subsequent questions which were taken up by someone else; this lead me to repeat and/or reformulate the point for the purpose of that discussion.
Repeating a question that has already been answered to your satisfaction "for the purpose of that discussion" is puzzling, to put it mildly.
mangaroosh said:
...the purpose of bringing up Lorentzian relativity here, was solely to juxtapose it with Einsteinian relativity for the purpose of clarification; namely that it appears that the same transformations can result in both absolute simultaneity and RoS. The question that is begged from that is, what is the difference between the two; why RoS under one interpretation, but absolute relativity in the other?.
In terms of predictive capability, there is no difference between the two. The only difference is of interpretation. Lorentz assumed, in accordance with the conventional belief of that time in the aether, that a preferred frame of reference existed. Einstein' noted that since no such frame was detactable, it is a superfluous assumption. That, in a capsule, is all you need to know about Lorentz Ether Theory (LET).
mangaroosh said:
... but if time dilation and/or length contraction never occurred at all, anywhere, would RoS still prevail?
Yes. A simple example of your hypothetical question is a Euclidean space spacetime. It also has RoS, but unlike Minkowski spacetime of SR, moving objects undergo the opposite effects, i.e. time contraction and space dilation. So if you want to insist that such effects "explain" RoS, you must include these as well. Learning Euclidean spacetime is, relatively speaking (!), a snap, so you might want try out your questions on this spacetime first, perhaps with pencil and paper. Hint : the axis of every coordinate system in a Euclidean spacetime are at right angles. You will see exactly how RoS interacts with space dilation and time contraction, and having done this, you will have some idea of how to adapt what you have learned to actual relativistic, or Minkowski, spacetime.
You don't know that it is a consequence, so why assume that it is? That no one can explain your belief should tell you that maybe this duck can't fly. Indeed, it cannot.
- Regards
  • #70
Then you should have done so.
The general phenomena that you are looking for is that every object defines a proper reference frame in which all of the laws of physics, including the speed of light, are the same as that of a stationary observer. These frames are related by the Lorentz transformations derived from Einstein's postulates. All relativistic effects can be obtained from these transformations. Therefore learn about these transformations and their derivation.
