A constant can be moved through limit sign-any intuitive way to understand this?
In summary, a constant can be moved through a limit sign by using the theorem that the limit of a product is equal to the product of the limits. This can be intuitively understood by considering the definition of a limit and using simple algebraic manipulations.
Juwane
87
A constant can be moved through limit sign--any intuitive way to understand this?
We know that a constant can be moved through limit sign. However, according to my understanding, this result follows from the theorem that the limit of a product is equal to the product of the limits, and when one of the multiplicand of the product is a constant, then if we take the limit of the constant, it will equal to the constant itself.
But is there an intuitive or graphical way of showing that a constant can be moved through a limit sign?
Suppose we were considering the following:
[tex]
lim_{x \rightarrow a} \ c f(x)
[/tex]
Where c is a constant.
Then, we can agree that
[tex]
c f(x) = \underbrace{f(x) + f(x) + ... + f(x)}_{c}
[/tex]
Thus,
[tex]
lim_{x \rightarrow a} \ c f(x) = lim_{x \rightarrow a} \underbrace{f(x) + f(x) + ... + f(x)}_{c}
[/tex]
Would you be willing to believe the sum of the limits is the limit of the sum? If so, we're done.
l'Hôpital, are you asserting that this is only true if c is a positive integer? That's the only case in which
[tex]c f(x) = \underbrace{f(x) + f(x) + ... + f(x)}_{c}[/tex]
(Added- Ah, I see, Juwant asked for an "intuitive" way of seeing it.)
From the definition of "limit":
If [itex]\lim_{x\to a} cf(x)= L[/itex], c a (non zero) constant, then given any [itex]\epsilon> 0[/itex], there exist [itex]\delta> 0[/itex] such that if [itex]|x-a|<\delta[/itex], then [itex]|cf(x)- L|< \epsilon[/itex]. Therefore, given any [itex]\epsilon> 0[/itex], [itex]|c|\epsilon[/itex] is also greater than 0 and there exist [itex]\delta> 0[/itex] such that if [itex]|x- a|< \delta[/itex], [itex]|cf(x)- L|< |c|\epsilon[/itex]. Now, [itex]|c||f(x)- L/c|< |c|\epsilon[/itex] so [itex]|f(x)- L/c|< \epsilon[/itex] so [itex]\lim_{x\to a} f(x)= L/c[/itex].
That is, if [itex]\lim_{x\to a} cf(x)= L[/itex], then [itex]\lim_{x\to a}f(x)= L/c[/itex] which is the same as [itex]c \lim_{x\to a}f(x)= L[/itex].
If c= 0, then cf(x)= 0 for all x so [itex]\lim_{x\to a} cf(x)= 0= 0(\lim_{x\to a} f(x))[/itex] as well.
1. Why can a constant be moved through a limit sign?
The idea of moving a constant through a limit sign is based on the definition of a limit. When evaluating a limit, the constant is essentially multiplied by the expression inside the limit sign. Since multiplication is a commutative operation, the constant can be moved to the other side of the limit sign without changing the value of the limit.
2. Can all constants be moved through a limit sign?
Yes, all constants can be moved through a limit sign. This includes both numerical constants, such as 2 or -5, and algebraic constants, such as x or y.
3. Is there a specific process for moving a constant through a limit sign?
No, there is no specific process for moving a constant through a limit sign. It is simply a mathematical property that allows us to manipulate limits and evaluate them more easily.
4. Are there any limitations to moving a constant through a limit sign?
The only limitation to moving a constant through a limit sign is that the limit must exist. If the limit does not exist, the constant cannot be moved through the limit sign.
5. How can understanding this concept be useful in solving mathematical problems?
Understanding how a constant can be moved through a limit sign can be useful in evaluating limits and solving various mathematical problems. It allows us to simplify expressions and make calculations easier, ultimately leading to a better understanding of the underlying concepts.
  • Calculus
  • Calculus
