Can someone explain the following logic used to define the meter?
In summary, the meter is defined as the length of the path traveled by light in vacuum during a time interval of 1/299,792,458 of a second, which is based on the fundamental unit of time, the second. This definition allows for the speed of light in a vacuum to be fixed at exactly 299,792,458 m/s. However, as more precise measurements of the speed of light are made, the length of the meter may slightly change while the speed of light remains constant.
sodium.dioxid
51
"The meter is the length of the path traveled by light in vacuum during a time interval of 1/299,792,458 of a second.Note that the effect of this definition is to fix the speed of light in vacuum at exactly 299,792,458 m/s."
I don't understand this because how can you use a number based on the meter to go back and define the meter? In other words, if light travels at x METERS / second. How can you use x METERS / second to define what a meter is?
Imagine that you need to communicate our systems of weights and measures to an intelligent being from another planet ... the only common basis for comparison that you can use are the properties of the universe that we find ourselves in. So, the idea is to define SI units of measure in terms of physically observable phenomena, rather than marks on a bar in a museum somewhere. We know from relativity that the speed of light in a vacuum is a fundamental constant of nature. Its dimensions are length divided by time. So, once we decide on a fundamental unit of time or length, we can define the other in terms of the speed of light. In the case of SI units, it is the second which is arbitrarily defined as:
"the duration of 9,192,631,770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium-133 atom"
Now that you have the fundamental unit of time nailed down, you can choose to define your fundamental unit of length in terms of how far light travels in a certain time interval. For historical reasons (i.e. marks on a bar of platinum in a Paris museum), we chose to define the meter as indicated in your post.
How much of these definitions are affected by gravity under general reltivity, in terms of the ratio of the difference in magnitude between two environments, versus total magnitude of the defined constants, due to gravity, say between 0 to 10 g's?
sodium.dioxid said:
"The meter is the length of the path traveled by light in vacuum during a time interval of 1/299,792,458 of a second."
There's no circularity here. Just a bit of oddness with that magic time interval, 1/299,792,458 of a second.
"Note that the effect of this definition is to fix the speed of light in vacuum at exactly 299,792,458 m/s."
This is a direct consequence of the definition of a meter. The speed of light is a defined constant. The rationale is that the speed of light, as far as we can tell, is a universal constant. Almost 100 years past between the Michelson Morley experiment and the adoption of this definition of the meter. Physicists had had a century to find any evidence that the speed of light is not the same to all observers. No such evidence was found.
This is a little bit twisted and I think I know where your confusion comes from. Note that speed of light is fixed at the cost of meter - with each more precise measurement of light speed length of meter can slightly change, even if the speed of light will be still constant at exactly 299,792,458 m/s.
1. What is the logic behind defining the meter?
The logic used to define the meter is based on the speed of light in a vacuum. It is defined as the distance that light travels in 1/299,792,458 of a second.
2. Why was this specific definition of the meter chosen?
This definition was chosen because the speed of light is a universal constant and can be accurately measured. It also allows for a precise and consistent measurement of distance.
3. How does this definition differ from previous definitions of the meter?
Prior to this definition, the meter was defined as one ten-millionth of the distance from the equator to the North Pole. This new definition is based on a scientific constant rather than a physical distance.
4. Are there any limitations to using this definition of the meter?
One limitation is that it assumes the speed of light is constant in a vacuum, which may not be the case in all situations. Additionally, it is difficult to measure the speed of light with complete accuracy.
5. How does this definition of the meter impact other areas of science?
This definition has had a significant impact on other areas of science, particularly in the fields of physics and engineering. It allows for more precise and standardized measurements, leading to advancements in research and technology.
  • Other Physics Topics
9K
