What factors impact the calorific value of petrol from coal liquefaction?
  • Thread starter ruzfactor
  • Tags
    Value
In summary, the conversation discusses the differences in heating/calorific values of petrol extracted from crude oil and from liquefaction of coal. The participants mention that different petrochemicals have varying calorific values and that coal liquefaction allows for the end product to be tailored to meet specific specifications. They also provide a source for the calorific values of different fuels. The conversation concludes by discussing the importance of considering factors such as freezing point and viscosity when using these fuels in engines.
ruzfactor
82
Hi
I am bit confused regarding the heating/calorific value of petrol (used for vehicle) extracted from crude oil and from liquefaction of coal. Should they be same? or Petrol extracted from crude oil will have different calorific value compared to the petrol from liquefaction (direct/indirect) of coal? Could anyone please give any reference?
Thanks in advance.
Thanks for the reply. The link you referred gives heating value of many fuels. Is there any source where I can get heating values of petrol extracted from crude oil and, from liquefaction of coal. Are they really different?
Yeah - the idea was to show you that heat output varies a lot between petrochemicals - you can easily see that different mixtures will produce different values.
Modern direct-liquifaction plants can manage 60-70% of input coal calories to the resulting fuel.[1]
Anthracite coal is very shiny, repels moisture, calorific value 7,800 – 8,000 kcal/kg.[2]
... so you can do the math.
[1] http://www.netl.doe.gov/technologies/coalpower/gasification/gasifipedia/pdfs/technology-status-coal-liquefaction.pdf
[2] http://www.coalmarketinginfo.com/coal-basics/
Likes 1 person
It depends what you meant by "petrol". The petrol you put in your car is manufactured to meet a set of standards for its properties, so it won't wreck your engine. Whatever you make it from, the end product will have the same properties.
But if you take a "random" sample of coal and liquefy it in an uncontrolled way, the end result could be almost anything, from methane gas to heavy oil sludge. The same applies to cracking crude oil.
The liquified-coal "petrol" can be as close to regular petrol as you like of course.
However, it is likely to differ if only a little bit... probably different impurities.
How tight is the domestic petrol standard in different countries anyway?
I suspect that there is a specific goal behind the question... perhaps someone has been making claims about synthetic fuel and ruzfactor wants a reality check? If so - it would be best just to state the claims.
Actually I wanted to know if a country ,for example, chooses to extract petrol from liquefaction of coal over cracking of crudeoil, will the petrol be the same as (in terms of energy content) from crude oil.
Coal liquefaction is a very flexible process, so the end products can be tailored to a desired specification.
Caloric content is a very basic measure, the process engineers would want to tune the composition much more exactly. Issues such as freezing point, viscosity and vapor pressure become important when the end use is in engines.
If you would like a bit more detail, a nice primer is provided by SASOL, currently the world leader in coal liquefaction, here:
http://m.everythingscience.co.za/grade-12/05-the-chemical-industry/05-the-chemical-industry-02.cnxmlplus
FAQ: What factors impact the calorific value of petrol from coal liquefaction?
1. What is the calorific value of petrol?
The calorific value of petrol is the amount of heat energy that can be produced when a unit of petrol is completely burned in a controlled environment. It is typically measured in joules per liter (J/L) or kilojoules per kilogram (kJ/kg).
2. How is the calorific value of petrol determined?
The calorific value of petrol is determined through a process called bomb calorimetry. This involves burning a known amount of petrol in a sealed container and measuring the heat released. The resulting heat energy is then converted into joules per liter or kilojoules per kilogram.
3. What factors affect the calorific value of petrol?
The calorific value of petrol can be affected by various factors such as the chemical composition of the fuel, the temperature and pressure at which it is burned, and the presence of impurities. The type of engine and combustion process used can also affect the calorific value of petrol.
4. How does the calorific value of petrol compare to other fuels?
Petrol has a relatively high calorific value compared to other common fuels such as diesel, natural gas, and coal. However, it has a lower calorific value compared to more energy-dense fuels like hydrogen and methane.
5. Why is knowing the calorific value of petrol important?
The calorific value of petrol is important for several reasons. It is used to determine the efficiency of engines and the amount of energy that can be obtained from a given amount of fuel. It is also a crucial factor in calculating the environmental impact of burning petrol, as well as in the pricing and taxation of fuel.
