What is the formula for finding the square inch area of an oval?
In summary, calculating the surface area of an oval or ellipsoid shape can be complex and depends on the specific dimensions and shape of the object. However, there are formulas available for common oval shapes such as ellipses and cycloids. For a D-shaped port, the constant for calculating the surface area will depend on whether or not there is a semicircle present.
5.0stang
63
I am trying to find a simple formula for finding the surface area in square inches of an oval.
L x W x .80?
Thanks for any help!
Mathematics news on Phys.org
? I get something neat:
[tex] A = \frac{\pi}{2} W(W + 2L) [/tex]
With W and L being measured in inches.
That's supposing that an oval consists of a half circle and a half ellipse.
The area of an ellipse (two-dimensional "flattened" circle) is [tex]\scriptstyle{lw}\pi/4[/tex].
The surface area of an ellipsoid (three dimensional "flattened" sphere) is more complex; see the formula linked above.
Thanks for the links! I am not a math whiz...lol.
I am trying to find the surface area of a "oval" throttle body blade on a EFI vehicle?
What measurements will I need?
The difficulty here stang is that an "oval" is not really a precisely defined mathematical entity. See http://mathworld.wolfram.com/Oval.html
Various well defined shapes such as ellipses and cycloids are "oval" like, but other mathematical forms could also be considered as oval, In other words the term "oval" is a little too broad to give an actual formula for surface area.
BTW. If the throttle body blade happens to fit snugly, at an oblique angle, inside a cylinder then it is in fact exactly an ellipse. As GRG has already pointed out the area of an ellipse is length times breadth times Pi divide 4. This is actually fairly close to what you originally guessed (L x W x 0.8), but it's actually closer to (L x W x 0.785).
Okay, guys, resurrecting an old thread.
How can one find the area of a D shaped port?
Multiply the long side of the D, and the width, and then multiply by .75?
If it's a semicircular D, then the constant will be pi/4 ~= 0.7854. If there is a semicircle, then a (short) straight segment along the top and bottom, then the constant will be somewhat larger -- perhaps 0.8?
The formula for finding the square inch area of an oval is A = π * (a/2) * (b/2), where A is the area, π is the mathematical constant pi, a is the length of the oval's major axis, and b is the length of the oval's minor axis.
How do you find the major and minor axis of an oval?
The major axis of an oval is the longest diameter, while the minor axis is the shortest diameter. To find these, you can measure the distance between the two opposite points on the oval's longest side for the major axis, and the distance between two opposite points on the oval's shortest side for the minor axis.
Can the formula for finding the square inch area of an oval be used for any oval shape?
Yes, the formula can be used for any oval shape as long as you have the major and minor axis lengths. This includes both symmetrical and asymmetrical oval shapes.
Why is the formula for finding the square inch area of an oval different from that of a regular rectangle or square?
The formula for finding the square inch area of an oval is different because it takes into account the oval's curved edges, unlike a regular rectangle or square which has straight edges. This is why the formula uses pi and the lengths of the major and minor axis instead of just the length and width.
Can the formula for finding the square inch area of an oval be simplified?
Yes, the formula can be simplified by first dividing the major and minor axis lengths by 2, and then multiplying them by pi. This would result in the formula A = π * (a/2) * (b/2), which is the same as A = π * r1 * r2, where r1 is the radius of the major axis and r2 is the radius of the minor axis.
  • General Math
  • General Math
  • General Math
  • General Math
