Exploring the Nature of Space Expansion: Self-Expansion vs Dark Energy
In summary, the expansion of the universe is the result of the gravitational forces of matter, which is explained by the presence of dark energy.
murongqingcao
A few years ago I came to this forum to ask about the issue of space expansion...and the answer I got then was that the expansion is the nature of the space (or space-time) according to relativity or some other more advanced theory...no one used dark energy to explain the issue at that time...now because of the 2011 nobel prize, should we say that the assumption that the space would expand by itself is not correct but we need to introduce the dark energy to explain this?
My interest to this issue is philosophical...to me, the self expansion and the dark energy theory are two different philisophies: the first treats the space as "something", but the second treats the space as the empty container and any symptoms of expansion could only be meaningful by the departure of the bodies in that container, which is caused by some energy inside the the container, and that some energy is dark energy...
Would anyone to kindly clarify the issue here for me? Thanks a lot in advance.
Phinds:
Thanks for the response...however, first of all, there were a few people (more than one) responded, and none of them was trying to use cosmological constant to convince me that the universe is unchanging...second of all, the response was more involved...I even asked why we don't see the expansion in our solar system, and a senior replied that the reason that we don't see it here is because that the density of matter is high here therefore, the gravitation reduced the expansion...
i think now you would tell me that the reason that there is no expansion in this solar system is because there is no dark energy, right?
Regards
murongqingcao said:
Phinds:
Regards
No, I absolutely would not. Dark energy, as far as I know, exists everywhere. It just has no effect on gravitationally bound objects.
The analogy that I like to use is this. If an ant pushes on a tank, it does not have a tiny effect, it has absolutely no effect at all. It cannot overcome the inertia of the tank and the friction of the tank against the ground.
Similarly, dark energy has no effect on gravitationally bound objects. It is INCREDIBLY weak on small scales. It is only on HUGE cosmological scales that it adds up to having an enormous effect.
To give you another of my favorite analogies, even though the universe is expanding, it is still going to be hard to find a parking place. What this is a description of is that if you could magically go out into intergalactic space and paint parking lines, it would take a BILLION YEARS before the lines would get far enough apart to let you park one more car between the lines.
BUT ... when you consider an amount of space billions of light years across, then dark energy has a huge effect because it is cumulative over distance.
Phinds:
Thanks a lot for the clear explanation!
But to me, philosohically I would consider both dark energy and space self-expansion (i.e. space is something and that something itself stretch out without the need of any energy and it is meaningful not because the departures of the bodies inside it) would remain possible causes for the observed space-expansion until someone finally find the dark energy...thanks
Dark energy interacts only through gravity . The proposal of itself expansion got fallen apart when it was noticed that when graphs of expansion of universe by studying the supernova red shifts were sketched , they were not even near to the "farthest neighbourhood" as predicted by applying the self expansion theory. Also the self expansion started violating the Einstein's general theory of relativity .So the scientists felt that a driving force is present uniformly throughout the universe that is causing the exponential expansion of universe and that was termed as dark energy .
Both theories are indeed different philisophies .
I hope this informatiom might help you a little bit .
Would it help if you considered dark matter within the very basic concept that momentum is the observers past and that particle position is the observers present, and then develop ideas within this direction towards an understanding of dark energy.
If dark matter has no momentum then it does not exist to the observer because the past cannot exist.
Dark matter would be a particulate state that does exist but only in the observers present and so cannot be observed outside of the observers state of awareness.
Although it is not relevant to your posting if you sometimes consider the double slit experiment you may find it helpful to introduce this concept.
huh ?
There are two distinct facts here. The first is that the universe is expanding, and the second is that the expansion of the universe is accelerating.
Dark energy is not needed to explain the first fact, that the universe is expanding. We can describe an expanding universe perfectly well with general relativity and what we know about normal matter. Actually, we need dark matter to explain how much mass galaxies seem to have, but don't confuse dark matter with dark energy.
Dark energy came into the picture when recent observations revealed that the expansion of the universe was accelerating. The effect of the gravitational attraction of regular and dark matter in the universe ought to be to slow the expansion of the universe. However, the observations leading to the 2011 Nobel prize contradicted this prediction: they revealed that the expansion is not slowing down, but speeding up. To explain this we need dark energy.
Thanks all for the introduction of how dark energy is getting into the picture as well as the reminder of the difference between dark matter and dark energy...
Somehow I still feel as space_buster said that those two theories are still two viable philosophies...because even though now I know that based on previous self-expansion theory we could not count for the accelerated expansion so that the whole idea of dark energy comes about...however, if the space (or space-time) itself is "something", then whatever behavior (accelerated expansion or unaccelerated expansion) could also be just the behavior of that "something" itself...therefore, what we need might not necessarily be some other thing in that container like dark energy, but a new descriptive model about the behavior of this "something" itself...does that even make a bit sense at all?
Thanks
murongqingcao , I have a bit of similar thinking as yours . Currently I am working on my own space model . However , I have halted that to clear my basics and to solve the space-time and energy-mass distribution math and many other concepts . Anybody's interest into it is always welcome ...
best wish to you...I wish I could help but I am not a physicist...my main interest in philosophy...good luck with your math model!
1. What is space expansion?
Space expansion refers to the phenomenon where the distance between objects in the universe increases over time. This is a fundamental property of our universe and is constantly occurring.
2. What causes space expansion?
The two main theories explaining space expansion are self-expansion and dark energy. Self-expansion suggests that space itself is expanding due to the energy and matter within it. Dark energy, on the other hand, is a theoretical force that is thought to be responsible for the accelerating expansion of the universe.
3. How do scientists measure space expansion?
Scientists use a variety of techniques to measure space expansion, such as observing the redshift of light from distant galaxies, studying the cosmic microwave background radiation, and analyzing the distribution of galaxies in the universe. These measurements provide evidence for the existence of dark energy and the expansion of space.
4. Is space expansion constant?
No, space expansion is not constant. The rate of expansion, also known as the Hubble constant, has been increasing over time due to the influence of dark energy. This means that the universe is expanding at a faster rate now than it was in the past.
5. What are the implications of space expansion for the future of the universe?
Based on current observations and theories, it is believed that space expansion will continue to accelerate and eventually lead to the "heat death" of the universe. This means that all matter and energy will become so spread out that the universe will become cold and dark, making it unable to sustain life.
  • STEM Academic Advising
