Variation in EMF of a magnet moving through a Coil
In summary: ohh, i thought we were talking about the first pictureok, in the second picture there's a vertical solenoid (with no battery), and a very small magnet dropping through itso long as the magnet is well inside the solenoid, the number of field lines being cut at any instant (the flux) is constant, irrespective of the speedremember, the speed at which they're cut doesn't matter, what matters is the difference in the number being cut at any instant, from one instant to another...
elemis
163
NOTE : My Current question and source of debate is in post number 10.
Lets say I have a square coil.
I accelerate it in a direction such that it is perpendicular to a magnetic field directed into the page.
As it enters the field and before it is completely in the field an INCREASING EMF will be induced.
The graph of EMF against time would be a straight line graph of CONSTANT GRADIENT through the origin which decreases to zero instantaneously once it is completely in the magnetic field, correct ?
http://www.a-levelphysicstutor.com/field-electro-mag-ind.php
Now, here we have a magnet being dropped into a coil.
The graph of EMF against time is more of a smooth pulse...
I have two questions :
1.) Why is it not a straight line that has constant gradient that then decreases instantaneously to zero ?
2.) Why does the EMF decrease to zero ? I know its because no lines of force are cut by the coil, but I cannot see how this is the case. I'm having trouble visualising it.
hi elemis! :smile:
elemis said:
2.) Why does the EMF decrease to zero ? I know its because no lines of force are cut by the coil, but I cannot see how this is the case. I'm having trouble visualising it.[/B]
it's not that no lines of force are cut,
it's that the number of lines of force that are cut is not changing (or not noticeably changing, when the magnet is a long way away)
zero change => zero emf :wink:
not following you :redface: … why should it be? :confused:
But the magnet is accelerating is it not ? Hence, the number of lines of force cut per unit time is INCREASING... Hence, there is a change in magnetic flux from one moment to the next.
Well, if you accelerate a coil through a magnetic field you get a straight line of constant gradient that then decreases to zero once the whole coil is in the field, correct ?
Why doesn't the same apply here ?
tiny-tim said:
x
This a diagram from my A Level Physics textbook.
It clearly shows a long stretch where EMF = 0. The explanation given is as follows:
there is no change in the flux linking the coil as the motion is parallel to the magnetic field.
hi elemis! :smile:
yes, but when the magnet is a long way away, that increasing number is negligibly small, so the change in flux is negligible
that's a uniform magnetic field …
a magnet's magnetic field is highly non-uniform
tiny-tim said:
hi elemis! :smile:
Thank you for staying online and helping me but I'm afraid I don't understand. Isn't the magnet accelerating whilst INSIDE the coil ?
Ah, I see. Yes, that clears that issue up.
yes, and that's why the graph is curvy :smile:
But then why does it decrease to zero and remain at zero for so long ? (see second attachment).
Now that I think about it, it should be a smooth change over from a positive emf to a negative emf as shown in the first picture...
remember, the speed at which they're cut doesn't matter, what matters is the difference in the number being cut at any instant, from one instant to another :wink:
https://www.physicsforums.com/attachment.php?attachmentid=45876&d=1333537181
No, you're failing to see my point.
EMF = BLV
If the magnet is traveling at 0.1 m/s it will cut 3 (just a random number) coils in the solenoid.
Since its accelerating it is now at a speed of, let's say, 0.3 m/s. Therefore, in one second it will travel further than previously and hence cut MORE coils in the same time.
So why does the EMF fall to zero for so long ?
ah, no, BLv only applies when v is in the plane of the wire, ie when the plane of the wire is crossing the B field lines (as opposed to moving along them)
BLv comes from emf = d/dt (flux) = d/dt (BA) where A is area cut by the flux = d/dt (BLW) where L is length inside the B field and W is width
now if the loop is entering the B field sideways on (in its own plane), with the L sides at back and front, so that L stays the same while W increases, then dW/dt = v, and so …
emf = BLv​
see the diagram at http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elevol.html#c3 (hyperphysics has the best diagrams! :approve:)
comparing your example with that diagram, your magnet, which is pointing vertically, is coming out of the page, but your wire isn't moving across the field lines, it's moving along them …
the number of dots (field lines) that your wire encloses is staying the same :wink:
Yes ! I finally understand ! Thank you Tiny Tim ! :)
FAQ: Variation in EMF of a magnet moving through a Coil
1. What is the cause of variation in EMF when a magnet moves through a coil?
The variation in EMF (electromotive force) is caused by the changing magnetic field as the magnet moves through the coil. When the magnet moves closer to the coil, the magnetic field becomes stronger, resulting in a higher EMF. As the magnet moves further away, the magnetic field weakens, leading to a lower EMF.
2. How does the speed of the magnet affect the variation in EMF?
The speed of the magnet does not directly affect the variation in EMF. However, a faster-moving magnet will cause the magnetic field to change more rapidly, resulting in a higher frequency of variation in EMF.
3. Does the strength of the magnet impact the variation in EMF?
Yes, the strength of the magnet does have an impact on the variation in EMF. A stronger magnet will have a stronger magnetic field, resulting in a greater change in EMF as it moves through the coil.
4. How does the number of coils in the coil impact the variation in EMF?
The number of coils in the coil does not directly impact the variation in EMF. However, a coil with more coils will produce a stronger magnetic field, resulting in a larger change in EMF as the magnet moves through it.
5. Can the variation in EMF be measured and quantified?
Yes, the variation in EMF can be measured and quantified using instruments such as a voltmeter. The magnitude and frequency of the variation in EMF can provide valuable information about the strength and speed of the magnet, as well as the number of coils in the coil.
