Energy-mom tensor does not determine curvature tensor uniquely ?
In summary: So the question is what conditions do we have to impose at spatial infinity to get Schwarzschild.In summary, the conversation discusses the relationship between the energy-momentum tensor and the curvature tensor in general relativity. It is noted that the energy-momentum tensor does not uniquely determine the curvature tensor, and that a single energy-momentum tensor can generate spacetimes with different curvatures. The concept of boundary conditions and initial value formulations is also brought up, and it is mentioned that these play a role in selecting a specific solution from the many possible vacuum solutions. The example of the Schwarzschild solution is used to illustrate this concept.
smallphi
441
If the energy momentum tensor is known, that fixes the Einstein tensor uniquely from the Einstein eqs. Einstein tensor is built from Riemann contractions so it doesn't fix Riemann uniquely.
Does that mean a single energy momentum tensor can generate spacetimes with different curvature tensors?
smallphi said:
Does that mean the same energy momentum tensor can generate spacetimes with different curvatures?
A particular spacetime is the "sum" of all energy-momentum tensors.
An interesting question would be: can we demonstrate or reason that an energy-momentum tensor pertains to a point in spacetime in general relativity.
It's probably not a good idea to think of one side of Einstein's Equation "generating" the other side. Indeed, there are many vacuum solutions. In many situations, the metric tensor appears on both sides of the equation. There's more to say on this point. But I don't have the time right now.
I think the electromagnetic analogy is useful. Suppose you specify the location and direction of motion of all charges, by specifying the current density J.
Have you completely specified a unique solution of Maxwell's equations? The answer is no, because you haven't specified the boundary conditions.
Physically, one can see this by thinking about adding or subtracting an electromagnetic wave from the solution. It doesn't change the charge density at all, but generates a different solution, i.e. a different set of elecltric and magnetic fields, a different Faraday tensor.
So giving the energy momentum tensor to Einstein's equations is not enough in a similar manner to the way that giving the charge density and current density to Maxwell's equations is not enough - one also needs boundary conditions.
I have a conceptual problem with the EM analogy. Boundary conditions are necessary if you want to specify the influence of the outside world on the boundary of your system. If your system is the whole universe and we accept that EM waves can't just pop out of nothing but require accelerating charges to create them, then specifying the position of all charges in the universe at all times should produce an unique solution for the EM field. You are not allowed to add extra waves anymore without the physical charges creating those waves present.
That sounds like a paradox between physics (can't add waves without charges creating them) and math (can add waves without charges).
In the same way I don't think that fixing the curvature tensor should require anything more than specifying the energy-momentum tensor at all spacetime points.
It is true that there are many vacuum solutions of Einstein eq. corresponding to the same Tmunu = 0 like Schwarzschild and gravitational waves but all these must have sources and their Tmunu is not zero over the whole of spacetime. Mathematically you can have gravitational wave without any source or a Schwarzschild around a singular point but physically that doesn't make sense. Again the same paradox as in the EM case.
Mathematically, your physical statement about waves is handled by the boundary conditions, however.
Maxwell's equations have a number of different solutions - the way we prevent EM waves from "popping out of nothing" is by specifying the boundary conditions.
We use the same mathematically tool in GR to solve the same issue - gravitational waves "popping out of nothing" is prevented by the tool of applying the boundary conditions.
What exactly is boundary conditions in GR? Specification of the metric and first derivatives on the 'boundary' of the manifold?
Wald (pg 252) say that an initial value formulation of GR can be specified with a spacelike hypersurface [itex]\Sigma[/itex], a 3-metric on [itex]\Sigma[/itex], and a symmetric tensor field [itex]K_{ab}[/itex] whih represents the extrinsic curvature on [itex]\Sigma[/itex].
There are probably other ways of doing things, for instance you can apparently specify a Klein-Gordon field by [itex]\Phi[/itex] and [itex]\frac{\partial \Phi}{\partial t}[/itex] on some spacelike hypersurface.
So where is the initial value formulation ala Wald in finding the Schwarzschild solution? The spacelike hypersurface must be one of the spheres. The 3 metric on it is the spherical metric in polar coordinates. What plays the role of K?
The Schwarzschild solution is an exact solution, therefore there are no boundary conditions or initial values (except of course for the mass). But note that the complete Schwarzschild solution connects two asymptotically flat regions and that there are multiple topologies possible.
Interesting here is that we can connect two or more Schwarzschild solutions (at infinity) at both of these asymptotically flat regions.
This thread is about exact solutions. The boundary conditions have to select somehow between all the possible vacuum solutions and pick up Schwarzschild.
1. What is the energy-momentum tensor and how does it relate to the curvature tensor?
The energy-momentum tensor is a mathematical object used in general relativity to describe the distribution of energy and momentum in space-time. It is directly related to the curvature tensor, which describes the curvature of space-time in the presence of matter and energy. In simple terms, the energy-momentum tensor tells us how the distribution of energy and momentum affects the curvature of space-time.
2. Why does the energy-momentum tensor not uniquely determine the curvature tensor?
The energy-momentum tensor does not uniquely determine the curvature tensor because there are multiple ways in which energy and momentum can be distributed in space-time to produce the same curvature. This is known as the "equivalence principle" in general relativity. Essentially, the same curvature can be produced by different configurations of matter and energy, making it impossible to determine the exact distribution of energy and momentum based on the curvature alone.
3. How does the energy-momentum tensor affect the equations of motion in general relativity?
The energy-momentum tensor is a key component in the Einstein field equations, which describe the relationship between the curvature of space-time and the distribution of matter and energy. The energy-momentum tensor appears on the right side of the equation, representing the matter and energy content of the universe, while the curvature tensor appears on the left side, representing the geometry of space-time. Together, these equations determine how matter and energy move and interact in the presence of gravitational fields.
4. Can the energy-momentum tensor be used to predict the behavior of matter and energy in the universe?
While the energy-momentum tensor is a fundamental concept in general relativity, it is not a predictive tool in and of itself. It is simply a mathematical representation of the distribution of matter and energy in space-time. In order to make predictions about the behavior of matter and energy, the energy-momentum tensor must be combined with the equations of motion and other physical laws.
5. How does the energy-momentum tensor relate to conservation laws in physics?
The energy-momentum tensor is closely related to the conservation laws of energy and momentum in physics. In general relativity, these laws are expressed as the "covariant divergence" of the energy-momentum tensor, which essentially means that the total amount of energy and momentum in a given region of space-time remains constant. This is known as the conservation of energy-momentum and is a fundamental principle in general relativity and other theories of physics.
