Engineering Ideas for preventing a fire at a tyre recycling plant ?
In summary, a fire at a recycling plant can be difficult to prevent. Fire fighters would need to be on standby to put out the fire.
davekardle
23
Hey guys I was trying to come up with some ideas for preventing a fire at a recycling power plant.
From an engineerings perspective. Some method of cooling or something ? any idea/input would be appreciated guys. thanks.
How does a fire start there? Tyres should not start to burn on their own.
Water?
SteamKing said:
Believe it or not, a couple of wikis about tire recycling and tire fires:
http://en.wikipedia.org/wiki/Tire_recycling
http://en.wikipedia.org/wiki/Tire_fire
I've read all of them but the thing is my "project manager" assigned this project and also quoted the latent heat and heat of vaporisation of water as well as for the tires ? I haven't got a clue what to do with those figures. the only data I know is that I have a reservoir nearby and I'm recycling half million tyres.
This is exactly the question I asked myself.
Put all the tyres in the reservoir?
...burned for months as the fire department was unable to extinguish it.
If professional fire fighters can't put them out, I doubt there is an "engineering" fix to put out a fire.
from the aforementioned wiki link said:
Tires are typically not prone to self-ignition as a tire must be heated to at least 400 °C for a period of several minutes prior to ignition. Therefore, tire fires are normally the result of arson or improper manipulation with open fire.
Based on this, my engineering ideas are:
a. do not light the tyres on fire
b. keep the tyres away from flames
c. keep the grass trimmed around the tyres, or use Roundup to kill the grass completely
d. install lightning rods away from the tyre mound
Presumably recycling the tires requires shredding them, which seems a real risk of fire. The tire cords are often steel, so sparks are likely, plus shredding tires is very energy demanding, so a lot of heat is generated.
Is your manager hinting that he's thinking of spraying water on the tires as they are getting shredded?
Do also note that spontaneous combustion in tire remnants is a real hazard and tire fires are a bear to extinguish. Where do you store the recycled materials?
I couldn't find any reliable references to "spontaneous combustion", but did find the following website very informative: http://www.scrap.org/ArticlesArchive/2004/Jul-Aug/TireFires.HTM
Spark Detection and Suppression
Due to the risk of fire, most operators agree that granulation lines today require spark detection and suppression systems. “It’s not an option,” Hinsey asserts. “In our opinion, it’s absolutely mandatory.”
As Colyar explains, “To remove the wire from the rubber, you’re going to have sparking inside the machine, so the real issue becomes containment. That’s what a spark detection and suppression system can do.”
One vendor in this niche is Flamex Inc. (Greensboro, N.C.), which offers a high-speed infrared detection and suppression system. Among its features, the Flamex system has a flame detector on the outfeed of the processing system. “An infrared flame detector is used to stop the belt from moving down the process line and trigger a water spray in the machine as well as the infeed and outfeed to extinguish any fire,” notes Allen Wagoner, the firm’s vice president.
You would just need to use your common sense. Maybe pay a visit to the site.
Plenty of barbed wire, IR cameras on towers, hungry Alsatians, and a fast response team on standby 24/7, for starters, with all leave canceled on full moons, public holidays, and Guy Fawkes night.
Sooner or later massive piles of tyres must prove irresistible to a local pyromaniac.
I suppose they should be arranged in multiple smaller manageable piles, spaced apart, rather than one giant and inaccessible heap, so that any fire could be contained and attacked from all sides.
Just move the entire operation off-shore and do it under water.
Some ideas: A temperature sensing thermocouple in the larger piles of granulated material? Auto-ignition can be monitored. On really hot days a cooling water trickle / spray might be worth it?
Large separation between piles? Some sort of wind-break so that fires do not easily spread? Good inventory management so that large piles are rarer. Especially if ground material / residues can be minimized.
N2 blanketing within the grinding machines? Isolating the "hot" / high-risk areas from rest of the facility? Good housekeeping / reduce stray material that's a fire risk.
Arson seems a big threat. Invest in good security systems? Dogs might work.
Mostly, it depends on how much money you can spare for the measures.
Related to Engineering Ideas for preventing a fire at a tyre recycling plant ?
1. How can engineering ideas be used to prevent a fire at a tyre recycling plant?
Engineering ideas can be used to prevent a fire at a tyre recycling plant by implementing fire detection and suppression systems, designing the plant layout to minimize fire hazards and improve ventilation, using fire-resistant materials, and providing proper training and safety protocols for employees.
2. What types of fire detection systems are commonly used in tyre recycling plants?
Some commonly used fire detection systems in tyre recycling plants include smoke detectors, heat detectors, and flame detectors. These systems can be connected to an alarm system and automatically trigger a response, such as shutting down equipment or activating fire suppression systems, when a fire is detected.
3. How does the plant layout affect the risk of fire at a tyre recycling plant?
The plant layout can greatly impact the risk of fire at a tyre recycling plant. By separating potential fire hazards, such as storage areas for flammable materials, from other areas and providing proper ventilation, the risk of fire spreading can be reduced. Additionally, having clear and accessible exits and pathways can aid in the safe evacuation of employees in case of a fire.
4. What materials are commonly used in the construction of a fire-resistant tyre recycling plant?
Fire-resistant materials, such as concrete, brick, and steel, are commonly used in the construction of a tyre recycling plant. These materials have a high resistance to fire and can help prevent the spread of flames and heat in case of a fire.
5. How important is employee training in preventing fires at a tyre recycling plant?
Employee training is crucial in preventing fires at a tyre recycling plant. Employees should be trained on fire prevention and safety protocols, such as how to properly handle and store materials, how to use fire extinguishers, and how to evacuate the plant in case of a fire. Regular training and drills can also help ensure that employees are prepared to respond quickly and effectively in case of a fire.
  • General Engineering
