What exactly is a power flicker, and how can it be simulated?
  • Thread starter KingNothing
  • Tags
    Power
In summary, the conversation discusses a common occurrence of a brief flicker in residential power systems and raises questions about the duration and voltage drop associated with this event. The possibility of simulating this flicker using relays is also mentioned, with suggestions for how to achieve it. Additionally, the conversation touches on the use of circuit breakers in high tension lines and the potential for voltage flicker during lightning strikes. The need for standards and ways to measure and characterize power sags and voltage flicker is also mentioned.
KingNothing
882
You guys have all seen a tiny flicker in the lights, where they either go dim or shut off completely for a very small period of time - usually less than half a second. It typically does not cause computers to shut down.
What duration of abnormal power is usually associated with this? What voltage drop is normal? (If it helps, I am referring to residential power systems in the US)
Also, does anyone have any quick suggestions on how to simulate this with a few 120VAC relays?
I was working in a plant that made circuit breakers for high tension lines. Their circuit breakers could break and make the circuit up to three times a second and are responsible for the flicker in the lights when lightning strikes. They used a blast of high pressure nitrogen to blow out the arc when the circuit breakers opened.
How much current will be in the circuit you are breaking?
You may be able to simulate it by putting a momentary switch in series with the coil of your relay.
The simulated flicker will depend on the phase of the voltage when the interruption occurs. So you may need a zero crossing trigger plus delay. If you use DPDT relays with 6 volt dc coils, a simple RC delay might work. I can inadvertantly cause flicker by turning on a 1 HP single phase motor.
There are IEEE standards for power sag, voltage flicker, etc. on AC power mains, as well as ways to characterize their severity and surveys of frequency of occurance in the US. Here is the main website:
http://www.powerstandards.com/IEEE.htm
Unfortunately, it looks like you need a registration or membership to gain access to the docs. You might see if your local technical library has access...
1. What is a power flicker?
A power flicker, also known as a voltage dip or sag, is a temporary decrease in the voltage of an electrical power system. It can be caused by various factors such as lightning strikes, equipment failures, or sudden changes in demand for electricity.
2. How does a power flicker affect electrical devices?
A power flicker can cause electronic devices to malfunction or shut down, as they require a certain level of voltage to operate properly. It can also damage sensitive equipment over time if it occurs frequently.
3. Can power flickers be simulated?
Yes, power flickers can be simulated in a controlled laboratory setting using specialized equipment. This allows researchers to study the effects of flickers on various electrical devices and develop methods to mitigate their impact.
4. What are the benefits of simulating power flickers?
Simulating power flickers allows for a better understanding of their causes and effects, which can aid in the development of more reliable and resilient electrical systems. It can also help in the design and testing of devices that are less susceptible to flickers.
5. How can power flickers be mitigated in real-life situations?
There are various methods for mitigating power flickers, such as using voltage regulators, uninterruptible power supplies, and surge protectors. Proper maintenance and regular inspections of electrical systems can also help prevent flickers from occurring.
  • Aerospace Engineering
  • Electrical Engineering
