Rotational Motion and Gravity/Planetary Orbits review
In summary, the conversation is about a student preparing for a test by solving review problems given by their professor. The student is looking for someone to help them step through some of the problems and is stuck on a question involving moment of inertia and kinetic energy. They discuss the equations and variables involved in the problem and the student realizes they made a mistake in calculating the moment of inertia for a rectangular plate. They also mention another problem involving angular momentum and a meter stick, and the student is struggling to get the correct answer.
vdfortd
I have a test Monday and I'm trying some review problems my professor gave us to study from. I'm not looking for answers I'm just looking for someone to help step me through a few of these problems. Thanks for any and all help you guys can provide.
3a). After starting, a lawn mower blade turns at a constant angular velocity of 20 rad/s. In a 10s interval, how many radians and how many degrees does it turn?
I figured out this part. It's 200 radians (20X10) and 11459.156 degrees ( 200(180/[tex]\pi[/tex]))
b) If the blade has a radius of .3 m, what is the linear speed of the tip of the blade?
Using v=rω, I got 6 by doing (.3)(20)= 6
c) If the blade is considered as a rectangular plate of mass .4 kg, and a width of .05 m, what is its kinetic energy as it spins.
This question (3c) is what I am stuck on.
Moment of Inertia for a rectangular plate is: I= 1/12M(a2+b2) where a and b are the length and width of the rectangle.
Kinetic Energy is : K=(1/2)Iω2
Edit: I don't don't why the omega symbol is there as a superscript. It should be omega squared. Sorry I'm trying to get used to this.
Since I know the equations, i was going to plug the mass and dimensions into the equation I= 1/12M(a2+b2) to get Inertia but I realized that they only gave me one dimension (the width) and I don't know what to do since I was not given a second dimension. I'm not sure if my teacher forgot to include the second dimension or if this is actually part of the problem.
After i found Inertia i was going to use the equation K=(1/2)Iω2 since I knew what the Inertia and what Omega is, and use that to find the Kinetic Engery. I'm just at a standstill with the first equation.
6. A particle of mass .4kg is attached to the 100-cm mark of a meter stick of mass .1 kg. The meter stick rotates on a horizontal, frictionless table with an angular speed of 4.00 rad/s. Calculate the angular momentum of the system when the stick is pivoted about an axis (a) perpendicular to the table through the 50cm mark and (b) perpendicular to the table through the 0 cm mark.
ω=4 rad/s
mass of particle = .4kg
mass of meter stick =.1kg
Lengh of stick = 100cm = 1 m
For part a) Moment of Inertia for a Long thin rod with rotation through center: I= (1/12)ML2
For part b) Moment of Inertia for a Long thin rod with rotation through end: I= (1/3)ML2
For these equations, L = the length of the rod and M = the total mass
To find angular momentum, use the equation L= Iω
L represents angular momentum in this equation.
I know the answers. a) is .433 kgm2/s and b) is 1.73 kgm2/s.
But when I do the problem I don't get the right answers.
For (a), I did I= (1/12)(.5)(12)
where .5 is the total mass of the stick and the particle and 1 is the length of the stick in meters. I got about .04167 and when I mutiplied that by omega (which is 4) I got .16667
well for your first question, you're given a radius in part B.
edit:
for second problem you forgot to include the particle in calculating inertia
Welcome to PF!
Hi vdfortd ! Welcome to PF! :smile:
Isn't that for an axis perpendicular to the rectangle?
A mower blade rotates about an axis parallel to its length. :smile:
Nooo … you can't add the masses. :frown:
The MI formula for a rod is for a uniform rod.
You must calculate the two MIs separately, and then add them. :smile:
edit:
Yeah, I brought the problems with me to work and read through it again and realized that they gave the radius in part B. I feel stupid for asking that now.
I realized what I did wrong in the first problem. I missed the fact that they gave me a radius in part B of the question.
As for the second problem, I didn't know you had to add them seperatedly. I'm going to go try that. Thanks.
OK, I thought I understood what you meant but i got the same answer :(. I did the first part for the .4kg (I= (1/12)ML2. So I did I= (1/12)(.4)(12)= .03333. Then I did it for the mass of the meter stick. I=(1/12)(.1)(12) and I got .0083333. Add them together and you get .0416 which is the same number I got when I added the masses together (.5kg) and plugged it into the equation.
Then for L= Iω .. I got L= 4(.0416) = .166533. The correct answer is .433.
If I work this problem backwards and do .433= I(4), you get that I= .10825. So I have to somehow get .10825 from the first equation and I can't see what I'm doing wrong.
Don't calculate the inertia of a .4 kg particle using the formula for a long thin rod. Imagine that just the particle was revolving (held by a massless string for example). What would its' inertia be? Add this inertia to the inertia of the meter stick.
Hi vdfortd! :smile:
1/12 etc is only for a rod, about an axis through its centre.
The .4kg is "a particle" (which means the examiner is telling you to treat it as a point), and about a distant axis.
So its MI about that axis is … ? :smile:
Ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh.
So I do (1/12)(.1)(1) for the Inertia of the meter stick and then I find the Inertia of the particle itself which I assume would be the equation I=mr2. The radius would be how far the particle is from the center of the meter stick, which is 50 cm or .5 meters. So the Inertia of the particle would be I= (.4)(.52). Does that sound right?
That's it! :smile:
(except of course, "inertia" is mass … so don't leave out "moment of" :wink:)
tiny-tim said:
That's it! :smile:
I just tried both part a and b and they worked out to the correct answer. Thanks a lot. My professor never really explained how to do these type or problems, he just told us the equations for certain objects are listed in the book. Anyway, I finished my review so thanks again.
1. What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. This type of motion is commonly seen in objects such as spinning tops, wheels, and planets rotating around their own axis.
2. How does gravity affect rotational motion?
Gravity is the force that pulls objects towards each other. In rotational motion, gravity acts as a centripetal force that keeps objects moving in a circular path around a central point. This force is essential for maintaining the stability of planetary orbits.
3. What is the difference between circular and elliptical orbits?
Circular orbits are perfect circles, where the distance between the object and the central point remains constant. Elliptical orbits, on the other hand, are oval-shaped and have varying distances between the object and central point. Planets in our solar system have elliptical orbits around the sun.
4. How do scientists calculate the speed of objects in rotational motion?
The speed of an object in rotational motion can be calculated using the formula v = rω, where v is the linear speed of the object, r is the radius of the circular path, and ω is the angular velocity (how fast the object is rotating).
5. What factors affect the orbital period of a planet?
The orbital period of a planet, or the time it takes for the planet to complete one orbit around the sun, is affected by the mass of the planet, the distance from the planet to the sun, and the gravitational force between the planet and the sun. These factors are all related to Kepler's Third Law of Planetary Motion.
