Attraction and repulsion for identical particles
In summary, the conversation discusses the notion of attraction and repulsion between particles based on the exchange of bosons with even or odd integer spin. The PCT Theorem and Pauli's paper are mentioned as evidence for the connection between spin classes and the exclusion principle. The method used to calculate the potential is also briefly discussed. Finally, a link to a related thread is shared, along with a comment about the age of the original discussion.
Janitor
I briefly scanned back through old topics in this part of the Physics Forum, and didn't see any that seemed to bring up this exact issue, so...
I have read in several popularizations of physics that the exchange of bosons between a pair of identical particles will cause attraction if the boson has even integer spin, and repulsion if the boson has odd integer spin. Is there any sort of reasonably simple explanation?
[Example: a pair of electrons repel one another under the exchange of spin 1 (odd integer) virtual photons.]
I have never seen an intuitive argument for it. The derivation usually calculates first order diagrams, then reverses Born approximation to obtain an equivalent potential. It can be seen that the potential gets a positive sign for spin 1 (generically, odd) and negative for spin 0. Thus one is repulsive, the other is attractive.
Thanks, arivero.
I know that the PCT Theorem can be proved in a pretty airtight way--though it is not a very simple argument to follow. And around the start of World War II, Pauli showed in a paper (in the Physical Review, if I remember) that certain contradictions would arise if the connection between spin classes (integer vs. half-odd integer in this case) and the exclusion principle were not to hold. I was hoping something similarly elegant might be the case for the attraction vs. repulsion connection to boson spin.
Does the method you speak of work out the same way for higher order diagrams as well?
Well, at least a 50% of the participants of the thread are still around.
1. What is the principle of "Attraction and Repulsion for Identical Particles"?
The principle of "Attraction and Repulsion for Identical Particles" states that identical particles, such as electrons or protons, can either attract or repel each other based on their electrical charge. Like charges (positive-positive or negative-negative) will repel each other, while opposite charges (positive-negative) will attract.
2. What is the significance of "Attraction and Repulsion for Identical Particles" in physics?
The principle of "Attraction and Repulsion for Identical Particles" plays a crucial role in understanding the behavior of particles at the atomic and subatomic level. It helps explain the structure and properties of matter, as well as the interactions between particles in processes such as chemical bonding and nuclear fusion.
3. Can identical particles attract and repel each other at the same time?
No, identical particles cannot simultaneously attract and repel each other. This is because the forces of attraction and repulsion are opposite and cancel each other out. However, they can alternate between attraction and repulsion depending on their relative positions and the balance of forces between them.
4. How does the distance between identical particles affect their attraction and repulsion?
The force of attraction or repulsion between identical particles decreases as the distance between them increases. This is known as the inverse square law, which states that the force is inversely proportional to the square of the distance between the particles. In other words, the farther apart the particles are, the weaker the force of attraction or repulsion between them.
5. Is the principle of "Attraction and Repulsion for Identical Particles" applicable to all types of particles?
Yes, the principle of "Attraction and Repulsion for Identical Particles" applies to all types of particles, including subatomic particles like electrons and protons, as well as larger particles like molecules. However, the strength and range of the forces of attraction and repulsion may vary depending on the size and electrical charge of the particles involved.
  • Quantum Physics
