Beyond LHC without a machine (new physics from cosmic rays)
In summary: However, the toy model provides insights into a wide range of existing data sets that are not currently explained.Second, the energy of the primary particles in UHECR is well above the threshold for CSR. In particular, the proton-proton cross-section at the LHC is a bit above the expectations, too. It agrees with fits, but without a theoretical description extrapolations based on fits are problematic.The key to understanding the excess muon production in UHECR may be to find a new physical phenomenon that manifests at energies well above the postulated energy threshold for CSR. Such a phenomenon would be consistent with the data and would
marcus
Dearly Missed
24,775
792
Bee Hossenfelder has an interesting post I'd like to get some comment on
http://backreaction.blogspot.com/2013/07/more-mysteries-in-cosmic-rays-and.html
More mysteries in cosmic rays, and a proposed solution
"...One mystery we already discussed previously. The “penetration depth” of the shower, ie the location where the maximal number of secondary particles are generated, doesn’t match expectation. It doesn’t match when one assumes that the primary particle is a proton, and Shaham and Piran argued that it can’t be matched either by assuming that the primary is some nuclei or a composite of protons and nuclei..."
http://backreaction.blogspot.com/2012/04/cosmic-ray-composition-problem.html
http://arxiv.org/abs/1204.1488
"...Now here’s an interesting new paper on the arXiv that adds another mystery. Pierre Auger sees too many muons
A new physical phenomenon in ultra-high energy collisions
Glennys R. Farrar, Jeffrey D. Allen
http://arxiv.org/abs/1307.2322 [hep-ph]
In the paper the authors go through possible explanations for this mismatch between data and our understanding of particle physics..."
"... it seems that they’re onto something and that cosmic rays are about to teach us new lessons about the structure of elementary matter."
New physics or a bad model?
A bad model (with >90% probability).
In particular a larger cross section than the one extrapolated from low energies can explain the shorter penetration depth.
As far as I know, the proton-proton cross-section at the LHC is a bit above the expectations, too. It agrees with fits, but without a theoretical description extrapolations based on fits are problematic.
TOTEM publication before there was LHC data:
The current large uncertainty on the extrapolation of the proton-proton total cross section at the LHC energy will be resolved by the precise measurement by the TOTEM experiment. Its accurate studies on the basic properties of proton-proton collisions at the maximum accelerator energy could provide a significant contribution to the understanding of cosmic ray physics.
Another thing I noted:
This can be seen very well from the figure below (Fig 2 from Shaham and Piran's paper) which shows the data from the Pierre Auger Collaboration, and the expectation for a composition of protons and Fe nuclei. You can see that adding a second component does have the desired effect of moving the average value to a shorter depth. But it also increases the width. (And, if the individual peaks can be resolved, produces a double-peak structure.)
That is a really weird idea in my opinion. A mixture of protons and various heavier elements is a natural way to resolve those issues.
Thanks for commenting!
This paper puts Farrar on the map for me, for the first time actually. They are proposing what they describe as a preliminary phenomenological "toy model" involving Chiral Symmetry Restoration (CSR) above 1017 eV to explain excess muon production in UHECR. By their account the CSR "toy model" is remarkably successful:
PAGE 5 (section 2 A toy model of the New Physics)
"This first, simplistic version of a CSR model gives a remarkably good accounting of all the published shower observations discussed above. At 1019 eV, where the statistics are good and the energy is well above the postulated energy threshold for CSR, the ground signal and Xmax distributions are essentially perfectly described in every respect: ...[here they refer to several figures comparing predicted/observed distributions]...
Our toy Chiral Symmetry Restoration model is the only model known to date which can simultaneously fit the CIC curve of ground signal versus zenith angle, the Xmax distribution and its energy dependence, and the absolute calibration between SD and FD signals in hybrid events..."
ABSTRACT
"...A 'toy model' of UHE proton-air interactions is presented which provides the first fully consistent description of air shower observations..."
Given Farrar's track record and reputation this makes one sit up and take notice :biggrin:
I got interested in how they arrived at their model, and so explored a bit. Time permitting, I'll quote some excerpts. Hoping for further comment from anyone who has looked at the Farrar paper.
Here's a longer excerpt from the Farrar Allen paper, starting on page 4, with section 2:
====quote=====
We now turn to identifying possible UHE phenomena with the potential to reduce the electromagnetic energy fraction in the UHECR air shower to account for observations. Two important general observations help restrict the search. First, while the ground muon signal varies from event to event, the variation is not dramatic, so the new phenomenon must affect almost all showers as opposed to being a rare occurrence.
This does not mean that every interaction at UHE needs to manifest new physics, since there are quite a few interactions in the VHE-UHE energy range: on average a 1019 eV primary proton shower has 2, 20 and 200 secondary collisions at energies above 1018, 1017 and 1016 eV ... Thus as long as the majority of events manifest whatever new physics is responsible for the higher muon content, and the threshold of the new physics is of order 1017 eV (14 TeV CM energy), the condition that almost all showers have increased muon content can be met.
Second, to produce a 50-100% increase in the muon ground signal, the new physics must impact
a very substantial fraction of the total energy in UHE final states. Production of possible new particles such as those predicted by Supersymmetry cannot account for the UHECR shower observations:... Many types of exotic particle production would actually reduce the muon signal because their decay products include missing energy which would thus be lost to the hadronic shower which yields the muons...
==endquote==
1. What is the significance of studying "Beyond LHC without a machine"?
Studying "Beyond LHC without a machine" refers to the exploration of new physics beyond what can be studied at the Large Hadron Collider (LHC) using cosmic rays. This approach allows scientists to investigate high-energy phenomena that cannot be replicated in a laboratory setting, providing valuable insights into the fundamental nature of our universe.
2. How do cosmic rays contribute to the search for new physics?
Cosmic rays are high-energy particles that originate from sources outside of our solar system. When these particles collide with Earth's atmosphere, they produce secondary particles that can be studied by scientists. By analyzing the properties of these particles, scientists can gain a deeper understanding of unknown physical processes and potentially discover new particles or interactions.
3. Can cosmic rays provide evidence for the existence of dark matter?
Yes, cosmic rays can provide evidence for the existence of dark matter. The detection of an excess of high-energy cosmic rays, especially antimatter particles, could potentially indicate the annihilation of dark matter in our galaxy. This would provide valuable information about the properties and distribution of dark matter, which is a major area of research in particle physics.
4. How does the study of cosmic rays complement other methods of particle physics research?
The study of cosmic rays complements other methods of particle physics research, such as colliders like the LHC, by providing a different perspective on high-energy phenomena. While colliders allow scientists to create and study particles in a controlled environment, cosmic rays offer a natural and continuous source of high-energy particles that cannot be replicated in a laboratory. Therefore, combining data from both approaches can provide a more complete understanding of the fundamental laws of nature.
5. What are the challenges of studying "Beyond LHC without a machine"?
One of the main challenges of studying "Beyond LHC without a machine" is the low event rate of high-energy cosmic rays. This means that scientists must analyze a large amount of data in order to detect rare events, making the research process time-consuming and resource-intensive. Additionally, the detection and identification of cosmic ray particles can be complex and require sophisticated equipment and techniques. However, advancements in technology and data analysis methods have made the study of cosmic rays a promising area for new physics research.
  • Beyond the Standard Models
