Strange geodesic in Schwartzschild metric
In summary: There is a convention that many authors of advanced texts use, as well as choosing units of distance and time such that c=1, they also choose units of mass such that G=1. It can cause confusion to persons unfamiliar with it.There is a convention that many authors of advanced texts use, as well as choosing units of distance and time such that c=1, they also choose units of mass such that G=1. It can cause confusion to persons unfamiliar with it.
paweld
255
The following curve is geodesic in Schwardschild metric:
[tex] \tau \mapsto [(1-2m/r_0)^{-1/2}\tau,r_0,0,0][/tex].
The tangent vector is: [tex] [(1-2m/r_0)^{-1/2},0,0,0] [/tex], its length is 1 and its
product with killing vector [tex]\partial_t [/tex] is equal: [tex] (1-2m/r_0)^{1/2} = \textrm{const}[/tex]. So the body lays at rest in gravitational field - why it's possible??
In Newtonian limit it's impossible - the body which does not rotate around a star cannot
have constant radious.
Constant energy is necessary for a geodesic, not sufficient. Plug this tangent vector in the equation of motion, you'll get [itex]\ddot r \neq 0[/itex].
Btw., it's Schwarzschild.
This not a geodesic. If
[tex]\mathbf{u} = \left( u^t , u^r, u^\theta, u^\phi, \right) = \left( \left( 1 - \frac{2m}{r_0} \right)^{-\frac{1}{2}}, 0, 0, 0 \right),
[/tex]
then the 4-acceleration is given by
[tex]
\begin{equation*}
\begin{split}
\mathbf{a} &= \nabla_{\mathbf{u}} \mathbf{u} \\
&= u^\alpha \nabla_{\partial_\alpha} \left( u^\beta \partial_\beta \right) \\
&= u^\alpha \left( \nabla_{\partial_\alpha} \left( u^\beta \right) \partial_\beta + u^\beta \nabla_{\partial_\alpha} \left( \partial_\beta \right) \right) \\
&= \left( u^t \right)^2 \Gamma^\mu {}_{tt} \partial_\mu
\end{split}
\end{equation*}
[/tex]
which is non-zero.
George Jones said:
[tex]
\begin{equation*}
\begin{split}
\end{split}
\end{equation*}
[/tex]
I was waiting for comments before finishing this off.
Using
[tex]0 = \Gamma^t {}_{tt} = \Gamma^\theta {}_{tt} = \Gamma^\phi {}_{tt}[/tex]
and
[tex]\Gamma^r {}_{tt} = \left( 1 - \frac{2m}{r_0} \right) \frac{m}{r_0^2}[/tex]
gives
[tex]\mathbf{a} = \left( 0, \frac{m}{r_0^2}, 0, 0 \right)[/tex]
with magnitude
[tex]a = \left( 1 - \frac{2m}{r_0} \right)^{-\frac{1}{2}} \frac{m}{r_0^2}[/tex]
Taking [itex]r_0[/itex] to be much larger that the Schwarzschild radius, and restoring [itex]c[/itex] and [itex]G[/itex] gives
[tex]a = \frac{Gm}{r_0^2}[/tex].
Consequently, such a hovering observer experiences normal Newtonian weight.
George, that's very instructive, thank you. I'm still reading Lee's book and I've bookmarked this thread.
Using
and
gives
with magnitude
A very confusing thing here is the use of [tex]m[/tex] to denote both half of the Schwarzschild redius and the mass of gravitating body! I think in textbooks whose authers prefer using the notation [tex]2m[/tex] instead of [tex]r_s[/tex] to symbolize the Schwarzschild redius, they later use
[tex]m=GM/c^2,[/tex]
where [tex]M[/tex] is the mass of mass of gravitating body. But I respect George's style and accept it as another alternative.:wink:
AB
AB
But you didn't notice that George put a G in the last equation which means the convention that I probably seem to have forgotten leads to
[tex]m=GM.[/tex]
AB
Related to Strange geodesic in Schwartzschild metric
What is a geodesic in the Schwartzschild metric?
A geodesic in the Schwartzschild metric is a path that follows the shortest distance between two points in the curved space-time around a non-rotating black hole, as described by Einstein's theory of general relativity.
Why is it called a "strange" geodesic?
The geodesic in the Schwartzschild metric is often referred to as "strange" because it has some unusual properties, such as being a closed loop instead of a straight line, and appearing to cross over itself when viewed from certain angles.
How does the Schwartzschild metric affect the motion of objects?
The Schwartzschild metric describes the curvature of space-time around a massive object, such as a black hole. This curvature affects the motion of objects by altering their trajectories, causing them to follow geodesics instead of straight lines.
What are the applications of studying strange geodesics in the Schwartzschild metric?
Studying strange geodesics in the Schwartzschild metric can help us better understand the effects of gravity on the motion of objects in the universe. It also allows us to make predictions about the behavior of objects near black holes and other massive objects.
Are there any real-world examples of strange geodesics in the Schwartzschild metric?
Yes, there have been observations of strange geodesics in the Schwartzschild metric around black holes. For example, the bending of light around a black hole is due to the curvature of space-time described by the Schwartzschild metric.
