Why Is Friction Uphill When a Ball Rolls Uphill?
In summary: NOT true (the frictional force is in the same direction for both a downhill and an uphill cylinder)2. is NOT the best way to think about it (the best way is to consider the direction of the acceleration, as I explained earlier)In summary, when considering the direction of friction force for a rolling object, it is important to look at the direction of the acceleration rather than the velocity of the point of contact. For an external applied force, such as gravity, the direction of friction is opposite the acceleration, but for an internal force, such as from an engine, it is in the same direction as the acceleration. Therefore, the direction of friction for a downhill and uphill rolling cylinder is the same, contrary to
azizlwl
1,066
If the ball were rolling uphill, the force of friction would still be
directed uphill as in FJg. 1O.19b. Can you see why'?
http://img252.imageshack.us/img252/4516/rollingm.jpg
I always assume the friction is always in opposite direction of the motion.
if the ball is rolling down then
a(cm)=(mg sinβ - f)/m and Iα=fr
and since a=rα
(mgsinβ - f)/m=fr^2/I
f is positive from here so when it is rolling down f is upward opposing the motion of centre of mass.
if it is rolling up then
a(cm)=(f - mgsinβ)/m and Iα=-fr
so (f - mgsinβ)/m=-fr^2/I
from here too it is upward.
thank you.
hi azizlwl! :wink:
we can always take moments about the centre of mass
let's do so … the ball in the diagram is accelerating anticlockwise no matter whether it's rolling downhill or uphill …
since the only external torque about the centre of mass is the friction, that must also be anticlockwise in both cases! :smile:
tiny-tim said:
hi azizlwl! :wink:
My assumption is that going downhill the rotation is anti clockwise and uphill the rotation will be clockwise. So the friction must reversed its direction.
By your explanation, it means we have another inclined plane on the left side, where the ball keep rolling up with same rotational direction from right position of the inclined plane..
yes, the rotation will be clockwise, but the angular acceleration will be anti-clockwise
(because this is a freely rolling ball)
so the friction will be in the same direction, whatever the direction of rotation
Sorry i didn't read properly.
It's the rotational acceleration that remains the same uphill or downhill although the direction changes.
Analogy of throwing an object upward, direction changes but acceleration remains.
Doing Physics mental experiment is really a tough for me. Thank you.
Problem with rolling.
Can i use different approach.
Assume No friction as in inclined plane. The instantaneous velocity in contact with the plane is downward so the friction upward. Thus produce torque clockwise.
For the problem https://www.physicsforums.com/showthread.php?t=603360.
Assuming no friction, the instantaneous velocity in contact with the ground is opposite of the force. Thus the friction is in direction of the force.
For uphill, the rotation will be clockwise or uphill thus instantaneous velocity in contact with the plane is downward giving friction in opposite direction that is uphill.
hi azizlwl! :smile:
i'm not sure what you're saying, or what force you're assuming
it doesn't look right, because you're concentrating on the velocity of the point of contact, when the primary consideration is the direction of the acceleration (either linear or angular)
by force, are you still referring to gravity, or is this an extra applied force?
for an "external" applied force, such as a rope or gravity, the direction of friction is opposite the acceleration, but for an "internal" force such as from the engine, it is in the same direction as the acceleration
I just try to find out the direction of friction force which to me it's very confusing.
For instance, a cylinder rolling downhill the friction direction is uphill
For cylinder rolling uphill, frictional force direction also uphill. You have given me the acceleration point view.
For a wound cylinder, the friction is in direction of the force pulling the string (as in https://www.physicsforums.com/showthread.php?t=603360).
Yes I'm concentrating on the velocity of the point of contact so that i will get direction of the friction which is in opposite direction of the motion(i guess it's always true).
but that wound cylinder isn't rolling (on the table), and there's no friction …
azizlwl said:
The frictional force between table and cylinder is negligible.
:confused:
Sorry about the wound cylinder question.
It was second question(repeat problem 11.70 if the frictional force between table and cylinder is negligible.)
11.70
The rope shown is wound around a cylinder of mass 4.0 kg. and I=0.020kg.m2, about the cylinder axis. If the cylinder rolls without slipping, what is the linear acceleration of its center of mass? What is the frictional force? Use an axis along the cylinder axis for your computation?
Solution
Choose left and ccw as positive. Write F=ma=20 +f=4a with f being the friction force at the floor. From τ=Iα=(20-f)(0.01)=0.02(s/0.10) =>a=6.7m/s2 and f=6.8
From the solution given frictional force f is direction of the 20N force. Intuitively it should be opposite of the cylinder motion.
So here i have to figure out how to determine the direction of the frictional force.
Thank you
hi azizlwl! :smile:
no, you have a decimal point wrong somewhere :redface:
20 + f = 4a
20 - f = 20a :wink:
What is rotational motion?
Rotational motion is the movement of an object around an axis or center point. This type of motion can be seen in the spinning of a top, the rotation of a planet around its sun, or the movement of a wheel on an axle.
What is the difference between rotational motion and linear motion?
Linear motion is the movement of an object in a straight line, while rotational motion involves the movement of an object around an axis. In linear motion, all parts of the object move the same distance in the same direction, while in rotational motion, different parts of the object have different velocities and distances from the axis.
What is angular velocity?
Angular velocity is the rate of change of angular displacement, or how quickly an object is rotating around an axis. It is measured in radians per second (rad/s) or degrees per second (deg/s).
What factors affect the rotational motion of an object?
The rotational motion of an object can be affected by several factors, including the object's mass and shape, the force applied, and the object's distance from the axis of rotation. Friction, air resistance, and the presence of other objects can also impact an object's rotational motion.
How is rotational motion related to torque?
Torque is a measure of the force that causes an object to rotate around an axis. It is directly related to rotational motion, as a greater torque will result in a faster rotation, and a smaller torque will result in a slower rotation.
  • Mechanics
  • Classical Physics
35K
