Does this function have a name?
  • Thread starter guysensei1
  • Tags
    Function
In summary, the function f(x) where f(x) is the length of the curve from 0 to x cannot be expressed in algebraic form or any other form in general. It is known as the rectification or arc length function and there are closed form solutions for some simple curves such as straight lines and circles, but not for most others. Additionally, there does not exist a function that gives itself when the length of the curve function is applied.
guysensei1
31
A function f(x) where f(x)=length of the graph curve/line from 0 to x
Can this function be expressed in algebraic form or some other form?
Does it have a name?
Mathematics news on Phys.org
You are talking about a particular way of getting a function, not a specific function so, no, it does not have a name. As one learns in Calculus, the length of the graph of y= f(x), from 0 to x is given by [itex]\int_0^x \sqrt{1+ (f'(t))^2} dt[/itex].
It's without a doubt a specific function, one whose domain is the Cartesian product of x and the function space. I don't think that this is a good reason for it to not have a name.
Not in general, but the solutions for a straight line and for a circle should be fairly obvious. Closed form solutions do exist for a few more complex curves e.g. parabola, catenery and cycloid but not for most others, even the humble ellipse.
The calculation of the length of a curve between two points is called rectification, or simply calculating arc length.
What I was looking for is a function that gives itself when the length of curve function is applied.
Try looking for this function. Clearly f(0) = 0. Let y = f(1). The length of the arc between (0, 0) and (1, y) is given by ## \sqrt{1 + y^2} ## so we have ## y = \sqrt{1 + y^2} ## or ## y^2 = 1 + y^2 ## which has no solution - the function you are looking for does not exist (over any non-zero domain).
Why is that? That surely just gives the length of the straight line from (0, 0) to (1, y). The curve you are looking for is not going to be of that form.
No, but its length has to be strictly greater than the length of the straight line between the two points.
Oh, I thought one thing and wrote something slightly different, let's try again.
Try looking for this function. Clearly f(0) = 0. Let y = f(1). The shortest arc between (0, 0) and (1, y) is simply the diagonal of length ## \sqrt{1 + y^2} ##, and so y must be at least as large as that. So we have ## y \ge \sqrt{1 + y^2} ## or ## y^2 \ge 1 + y^2 ## which has no real solution. The function you are looking for does not exist (over any non-zero domain).
1. What is the purpose of naming a function?
Naming a function allows us to easily identify and refer to it in our code. It also helps make our code more organized and readable.
2. How do I choose a name for a function?
When choosing a name for a function, it is important to use descriptive and meaningful words that accurately convey the purpose of the function. It is also good practice to follow naming conventions and avoid using reserved keywords.
3. Can a function have the same name as a variable?
Yes, a function can have the same name as a variable, but it is generally not recommended as it can cause confusion and conflicts in your code.
4. Is there a limit to the length of a function name?
There is no specific limit to the length of a function name, but it is best to keep it concise and not overly complicated.
5. Can I change the name of a function after it has been declared?
Yes, you can change the name of a function after it has been declared, but it is not recommended as it can cause errors and confusion in your code. It is best to choose a suitable name for a function from the beginning.
  • General Math
