Schwarzschild Radius Explanation?
In summary: This is because as an object is compressed, its gravity increases, warping space-time so much that objects inside the Schwarzschild radius cannot escape. This is why the escape speed also increases with density. The 1/r^2 relationship between gravity and distance plays a key role in this process, as it allows for the continuous increase in gravitational field strength as an object is compressed to smaller and smaller sizes. This ultimately leads to the formation of a black hole, even with a fixed amount of mass.
  • #36
stevendaryl said:
The notion of "propagate" that is appropriate for talking about whether an effect inside a black hole can propagate outside is in terms of disturbances. If I make a tiny change to the distribution of mass inside a black hole (or distribution of charge), is that change visible from outside? The answer is "no".
The mass distribution is demanded to be spherically symmetric, the thing is that a change(increase) in mass inside the horizon can be theoretically detected outside the horizon, so the notion of propagation you highlight is also realized,
  • #37
Let us say we have a super-massive black hole that is being orbited by a number of satellites. Far away a star is on a course towards the SMBH but not on a direct collision course. On route it collapses to form a small black hole. After becoming a black hole, a relic of its gravity field is left outside the black hole event horizon which might be thought of as a distortion in spacetime. This distortion has an existence that is independent of the black hole and is not 'generated' by the mass of the black hole. On passing near the SMBH the mass of the black hole and the relic field are captured by the gravity of the SMBH and go into orbit around it. As a result the trajectories of the other bodies are disturbed by the either the relic field or the mass of the small black hole. In turn the trajectory of the small black hole is also disturbed by its interactions with the other bodies. Is it just coincidence that the complicated evolving trajectory of the black hole mass is identical to the trajectory of the relic gravitational field and that there is no causal connection between the two?
P.S. Here is an alternative thought experiment I just thought of. Imagine an object is in stable orbit around a black hole at an orbital radius of R. The black hole evaporates due to Hawking radiation. Eventually all the radiated energy and matter of the Hawking radiation is in a shell with a radius greater than R. It is well known that with a uniform shell the spacetime and gravitational curvature is flat. However, if the relic field of the black hole is independent of the mass of the black hole that created it, the relic field should still be there (as it has no need of the mass) and the body should continue orbiting at a radius of R from the position of the original black hole, even though there is no mass or energy within the orbital radius. Does this not cause a problem with energy balance of the universe?
  • #38
The mass of an isolated source is not independent of its external gravitational field, in fact it is defined in terms of the distant field. This is true regardless of whether the source is a star or a black hole. It is also true regardless of which of the several definitions of mass you refer to.
It is a complete mistake to think of the gravitational field of a mass as something that has to continuously "propagate out" from the source, presumably faster than light. The reason being that it must have been there already! You cannot change the mass of an isolated source without changing the distant field. The distant field defines the mass. To change it, either additional mass has to fall in from infinity (in the form of particles or waves), or some of the mass has to emerge and travel to infinity. In either case there is no superluminal propagation.
  • #39
The first part of that is not true--a collapsing star does not need to be spherically symmetric in order for it to collapse into a black hole.
The second part I can't really make sense of. The mass of a black hole increases by something falling into the black hole. The external gravitational field changes long before the mass crosses the event horizon (infinitely long before, in the coordinate system of a distant observer), so it's certainly not an example of something propagating out of the event horizon.
  • #40
Bill_K said:
It is a complete mistake to think of mass as something that has to "propagate out" from the source, presumably faster than light, the reason being that it must have been there already! You cannot change the mass of an isolated source without changing the distant field. The distant field defines the mass. To change it, either additional mass has to fall in from infinity (in the form of particles or waves), or some of the mass has to emerge and travel to infinity. In either case there is no superluminal propagation.
That's what I've been getting at. People might be thinking in terms of: Suppose a massive object suddenly appears. How much time does it take for the gravity due to the object to propagate to a distant star?
But the premise makes no sense, in terms of GR. Mass can't suddenly appear at a spot in the universe, it can only come from other parts of the universe. (I'm not sure how the suggestion Peter made about the possibility of wormholes affects this.)
  • #41
GR uses different language than Newtonian gravity, and of course is more general. But despite that, many questions about GR can be answered quite simply by thinking of the Newtonian case, which GR must agree with in the weak field limit. Just because we have an interest in GR does not mean we should abandon our Newtonian intuition.
Take this example. At any time the expanding shell of Hawking radiation is at some large radius R0. Outside R0 the gravitational field is undisturbed and still corresponds to the same original mass M. Inside R0 the field is zero and planets travel in straight lines.
  • #42
stevendaryl said:
So based on this formula, there would seem to be a special radius [itex]R[/itex] such that even light can't escape:If [itex]R < 2GM/c^2[/itex], where [itex]c[/itex] is the speed of light, then [itex]v_{escape}> c[/itex] and so not even light could escape.
if you use Einstein's theory instead, you get exactly the same answer: If the mass of a star or planet is squeezed down to a radius [itex]R[/itex] where [itex]R < 2GM/c^2[/itex], then it becomes a "black hole" where nothing, not even light, can escape.
Could anyone explain these points:
- can a neutron star emit light, since there are not electrons in orbits to "reflect" incoming light?
- if we do not consider escape velocity,
rs (2Gm/c2) just says that PE around mass is roughly 1020. If a photon had energy 1034 hv, wouldn't it emerge from the BH with enough energy to be visible light?
- Planck unit of mass Mp is derived by Lp multiplying it by G/c2, is it incorrect by a factor of 2 or is rs wrong?
  • #43
Yes, a neutron star can and does emit light (but neutronium would be rather shiny and reflective). The neutron matter though neutral is polarizable (they way magnets are without us having a magnetic charge) and thus can create electromagnetic waves.
Don't confuse potential energy with gravitational potential. In a given gravitational potential the potential energy of an object is its mass times the grav. potential. As to the photon business I don't follow your reasoning. You may if you like calculate the red shift for a photon climbing out of a gravity well, or the blue shift for photon falling in... but the event horizon does not itself "emit" photons. (Hawking radiation is a quantum phenomenon occurring over a spatial volume outside the horizon).
The Planck scale is an order of magnitude, not a precise value... we may do unit conversion and so obtain a Plank mass, time, energy, momentum, or distance. But it isn't --in-and-of-itself-- a physical constant per se... as in a directly measurable or ratio of measurable quantities. The Planck scale defines the scale that when approached renders invalid assumptions of only classical effects... near the Planck scale we cannot ignore quantum phenomena. In such a statement a factor of 2 is not significant.
  • #44
jambaugh said:
, not a precise value... we may do unit conversion and so obtain a Plank mass,.
I was referring to the way Planck derived his unit of mass and length , do you anything about it?
  • #45
jambaugh said:
...neutronium would be rather shiny and reflective.
In ordinary matter light is reflected by electrons jumping up and down the orbits, how can matter without orbits reflect light?
We are not doing conversion.
It was Planck that established that Lp = G/c2 * Mp
  • #46
I recall reading somewhere that a lot of a neutron stars light is made up of the photons that were captured during the initial collapse and are slowly making their way to the surface and 'leaking' from the neutron star.
  • #47
This isn't necessarily true; electrons transferring between energy levels in atoms is only one of a number of available degrees of freedom that can exchange energy with EM waves. Others include: free electrons that aren't bound to individual atoms (e.g., in metals); thermal vibrations of entire atoms/molecules (or whatever particles compose the object); collective vibrational modes involving many atoms/molecules (or whatever particles compose the object). The latter two, at least, are available in neutron stars, with neutrons playing the role of the atoms/molecules.
  • #48
Ha neat distinction. Between fields and propagating, though how is it not all consicered propagating?
If I measure a bodys gravitational field and see its a perfect sphere, will its gravitaional field still be a perfect sphere if I measure while zooming by at near c? I thought it too would be contracted.
  • Cosmology
