Solving Stopping Potential for Electrons Ejected from Metal at 337nm Wavelength
In summary, our professor told us how to do this problem but it doesn't seem to be working. He then said the Kenetic Energy (KE) will turn equal to the Stopping Potential * electric charge of an electron. We need to find the Stopping Potential and then divide it by the charge of an electron to get the correct answer.
mr_coffee
1,629
Hello everyone! Our professor told us how to do this problem but it doesn't seem to be working. Here is what the problem says:
(a) If the work function for a certain metal is 1.5 eV, what is its stopping potential for electrons ejected from the metal when light of wavelength 337 nm shines on the metal?
Well he explained, the theory behind it, and it made sense. He then said, the Kenetic Engery (KE) will turn equal the Stopping Potential * electric charge of an electron.
THe KE is in electron volts, eV.
KE = (Stopping Potential)(Eelctric charge of electron);
We want the stopping potential so:
(stoppping Poential) = KE/1.602E-19;
We find KE by the following:
h = planks constant = 4.136E-15 eVs;
KE = h*f - work;
where f is the frequency;
We find f by:
f = c/wave length;
f = (3E8 m/s)/(337E-9m) = 8.902E14 s^-1
they give us the work, so all we need now is to solve for KE, then we have to divide KE by charge of an electoron and that should be the answer.
KE = (4.136E-15 eVs)( 8.902E14 s^-1) - 1.5eV;
KE = 2.1819 eV;
PE = 2.1819eV/1.602E-19;
PE = 1.36196E19;
Which is wrong. Someone got the answer right, but their answer was a lot smaller tahn mine. They got 2.302 somthing, had no E19. Any ideas where i messed up? Thanks!
they want the answer in Volts.
I submitted 1.3619 omitting the E19, and also tried putting E19, both don't work.
KE = h*f - work;
We find f by:
f = c/wave length;
KE = 2.1819 eV;
PE = 1.36196E19;
The stopping potential is the potential (energy / unit charge) measured in volts (joules/coulomb) that must be applied to stop the electrons from being ejected from the surface when the light is shone on it.
If the energy of the incident photon is greater than the work required to remove the electron from the surface plus the applied (-) potential, electrons will leave the surface with some kinetic energy. The stopping potential is the applied potential that makes this KE = 0.
So the stopping potential is given by:
[tex]q_eV_s = E_{photon} - q_e\phi[/tex]
[tex] V_s = h\nu/q_e - \phi[/tex]
where [itex]V_s[/itex] is the stopping potential and [itex]\phi[/itex] is the work function (Joules/coulomb).
I think you understand this. Your problem may be just in math. To avoid confusion, work out the solution algebraically and the plug in numbers at the end.
In SI units:
[tex]h\nu/q_e = hc/\lambda q_e = 6.63e-34 * 3e8/337e-9*1.6e-19 = 3.69 [/tex] Volts.
So V_s = 3.69 - 1.5 = 2.29 V.
AM
Thank you for the explanation, it makes senes to me. It seems to be algebra like you said. But i submitted your answer and it still didn't like it. 2.29V. I'm wondering why you used 6.663eE-34 J Hz, instead of 4.136x10^-15 eVs? I plugged in 4.136E-15 instead of 6.63E-34 and got my orginal answer whichi is also wrong. But i don't see why its saying yours is wrong. :bugeye:
He used that value because he is working in SI unites (kg, meter, second). I think it is just a simple mistake in the last step...3.69-1.5 gives 2.19, not 2.29 volt.
Whoops! you are correct again! your a machine hah, thanks again!
How did you know (that I am a machine)? I am actually 200 Pentium 4 connected in parallel.
:rofl:
1. What is the significance of 337nm wavelength in this experiment?
The 337nm wavelength corresponds to the ultraviolet range of the electromagnetic spectrum. This specific wavelength is commonly used in experiments involving photoelectric effect, as it is able to efficiently eject electrons from metal surfaces.
2. How is the stopping potential for electrons determined in this experiment?
The stopping potential is determined by gradually increasing the voltage applied to the metal surface until no current is detected. This voltage is then measured and recorded as the stopping potential for the ejected electrons.
3. What factors can affect the accuracy of the stopping potential measurement?
Several factors can affect the accuracy of the stopping potential measurement, such as the intensity of the incident light, the cleanliness of the metal surface, and the temperature of the metal. It is important to control these variables as much as possible to obtain reliable results.
4. How does the energy of the ejected electrons relate to the stopping potential?
The stopping potential is directly proportional to the maximum kinetic energy of the ejected electrons. This means that a higher stopping potential will result in electrons with a higher energy, and vice versa.
5. What are the applications of this experiment?
This experiment has various applications, including studying the properties of different metals, determining the work function of a metal, and understanding the relationship between light intensity and stopping potential. It also has practical applications in the development of solar cells and other photovoltaic devices.
