blazerman
- 4
How do we Calculate Temperature & Time of Heating Element
Heating Wire having the following Data :
SWG 16(1.63mm)
Specific Resistivity = 1.45 ohms-mm-3
Density = 7.1 gm-cm-3
Resistance = 0.685 ohms/Meter
Weight = 15 Gram/Meter
(a)In order to Build Heating Element using the above wire for Making 2.5 KiloWatt heating Element
(b)In Order to Build Heating Element using the above wire for Making 3.5 KiloWatt heating Element
Take ambient & room temperature as 35 degree Centrigrade.
How to Calculate the following :
(a)Formula for Calculating Temperature Raised in 1 hour ?
or alternately What would be temperature of heating element after Heating Element heated for 1 Hour?
(b)Formula for Calculating, How Many Calories of Heat in generated in 1 hour?
(c)Say if the Temperature is raised till (i)800 degree Centigrade what would be the Kilowatt generated & in what time this Temperature would be raised?
(c)Say if the Temperature is raised till (ii)1000 degree Centigrade what would be the Kilowatt generated & in what time this Temperature would be raised?
Please state the explanation using formulas.
SWG 16(1.63mm)
