ZuzaMagda
- 7
How to calculate 1) binomial coefficients and 2) binomial distribution on a Casio fx-9860G calculator?
The Casio fx-9860G is a scientific calculator designed for advanced mathematical calculations, including binomial coefficients and binomial distribution.
Binomial coefficients are mathematical expressions used to calculate the number of ways to choose a subset of objects from a larger set, without regard to the order in which the objects are chosen. They are represented by the symbol "n choose k" or "nCk".
To calculate binomial coefficients on the Casio fx-9860G, you can use the combination function (nCr) located in the PROB menu. Simply input the values for n and k, and the calculator will give you the result.
Binomial distribution is a probability distribution that describes the likelihood of a certain number of successes in a series of independent trials, where each trial has only two possible outcomes (e.g. heads or tails, success or failure).
Yes, the Casio fx-9860G has a built-in binomial distribution function (binompdf) in the PROB menu. You can input the values for the number of trials, probability of success, and number of successes, and the calculator will give you the probability of obtaining that specific number of successes in the given number of trials.
