Exploring the Concept of Charge: A Physics Undergrad's Perspective
  • Thread starter The_Cat
  • Tags
    Charge
In summary: Are you talking about electric charge being the source/sink of the electromagnetic field? In summary, charge is a fundamental property of particles, similar to mass and momentum. It is not an emergent property and is unique to each particle, such as the charge of an electron being opposite to that of a proton. Charge can be described and measured in different ways, such as in coulombs in electrical circuits, and its theoretical foundation is still unknown. It is the tendency of particles to produce electric fields and can be affected by relative motion between the observer and the charged particle. Charge is also conserved over time and can be derived from the arrangement of charge and currents.
The_Cat
I know the question sounds ridiculously simple, but I haven't been able to form an answer. What is charge? Why do particles have an electrical charge and where does it come from? Is it just a basic property of particles or is there a mechanism?
For your information: I'm a third year undergrad in physics, so I have a basic grasp of most branches of physics.
It's a fluid.
Not really though ;-) It's just an intrinsic property of a particle. Like mass or momentum. It's not an emergent property such as density or pressure. It's fundamental. You can't really define it in terms of simpler things.
It's also a rather unique entity like dark energy (the cosmological constant) that is always measured at the same value regardless of reference frame...unlike, for example, all forms of energy.
Oddly the charge of an electron, a fundamental particle, is opposite that of a proton which is composed of other particles...quarks...where some combination produces "charge"
Charge in an electrical circuit is of course in coulombs...q = it...
Maybe charge flows from the Higgs field (standard model theory) as does particle mass...nobody knows. (That's purse speculation)
In string theory, charge flows from the vibrational pattern of the string...
There is no theoretical foundation for why the fundamental value of charge is what it is...it's an experimentally determined constant...
I don't know that we can ever say what something 'is'. we can only try to model it and say how it behaves. the question becomes 'what is it like'? it behaves 'as if what'?
charge is the tendency of particles to produce electric fields. so the answer to your question will depend on what conceptual model you use to describe particles and fields.
Likes cshao
This is generally true currently, yet the unification of the strong/weak/electromagnetic forces can offer some mathematical insights... Weinberg/Salam/Glashow found a common source for the three in an electroweak unification...the three forces appear as one when energies are high enough...so the electromagnetic field and resulting "charge" is another result of symmetry breaking as the universe underwent a phase transition from high energy and instability to the lower energy more stable environment we now observe...yea, still rather vague, I know...
"we know much, we understand little"
Likes cshao
It occurred to me there is yet another "weird" aspect of electric charge: if you observe a stationary electric charge and you are in the same coordinate system at rest, you'll observe an electric field only; if there is relative motion between you and the charge, the electric field disappears and all you see is a magnetic field!
actually I don't think that the electric field of the charge will ever disappear.
you will always see a charge and charges always have fields.
Indeed, the electrical field doesn't dissapear. It will become weaker along the line of motion, and stronger in the plane perpendicular to it if you get to high enough velocities, but it won't go away.
you guys are right...I must have gotten carried away...only the magnetic field pops in and out of "existence"..
Actually, the electric field can disappear as well as the magnetic. In a rest frame with current in a superconducting loop, the is a magnetic field but no electric field.
Either one can disappear and reappear with reference frames.
Claude
soorry...this really has nothign to do with the question...but how the heck do you post a thread or a question to ask?? I am soo confused..thanks in advance
When you're looking at the list of threads in a forum, click the "New Topic" button at the top or bottom of the list.
By the way, I've deleted your other post with the same question, in the "Classical Physics" forum.
Also, I'm leaving your post and my response in this thread until you see them, even though they're very off-topic for this thread. Normally I'd send a private message (PM), but you might not know yet how to read your PMs.
In the future, please use the "Forum Feedback and Announcements" or "General Discussion" forum (at the bottom of the list of forums) for questions about how to use the forums.
When you see this, post a reply, then I'll know you've seen it and I can delete these posts.
Naively, charge is the divergence of the electric field. The electric field can be expressed as the curl of an arbitrary, C^2 vector field over spacetime—curved or flat. That the divergence (charge) is conserved over time, is a direct result of the local Lorentz metric.
Any vector field on spacetime has a conserved charge.
(Edit: The charge minus the current out is conserved.)
But experimentally, charge is always attached to mass. So the usually way of thinking about these things is significantly different. From an arrangement of charge and currents, you derive the associated fields, where the equal sign in Gauss’ law is not taken as a statement of equivalence but a directional assignment from charge to field.
Charge is the source/sink of the photon.
?? What photon?
FAQ: Exploring the Concept of Charge: A Physics Undergrad's Perspective
1. What exactly is charge?
Charge is a fundamental physical property of matter that causes particles to experience an electric force. It can be either positive or negative, and it is measured in units of coulombs (C).
2. How is charge different from mass?
While mass is a measure of the amount of matter an object contains, charge is a measure of the electric force an object can experience. Mass is always positive, whereas charge can be positive or negative.
3. What creates charge?
Charge is created by the presence of subatomic particles, such as protons and electrons. Protons have a positive charge, while electrons have a negative charge. The amount of charge an object has is determined by the number and arrangement of these particles.
4. Can charge be transferred from one object to another?
Yes, charge can be transferred from one object to another through processes such as rubbing or contact. When two objects have different amounts of charge, they can experience an electric force between them.
5. Is charge the same as electricity?
No, charge and electricity are not the same thing. Charge is a fundamental property of matter, while electricity refers to the flow of charged particles, typically electrons, through a conductor. However, charge is essential for the existence of electricity.
