Why do different nuclei need different neutron speed for neutron capture?
In summary, different nuclei require different neutron speeds to achieve fission. U-235 requires a thermal neutron while Pu-239 requires a fast neutron. The strong nuclear force is responsible for capturing passing neutrons, and the difference in likelihood of capturing fast neutrons between the two nuclei is due to the compound nucleus formed and its binding energy. While thermal neutron fission is more likely for U-235 and Pu-239, fast neutron fission is also possible.
marklimmage
Why do different nuclei need different neutron speed to achieve fission??
My understanding is that U-235 requires a thermal neutron in order to be likely to cause a fission reaction, however Pu-239 requires the additional energy of a fast neutron in order to cause the nucleus to undergo fission rather than just absorbing the neutron and becoming Pu-240.
I also think that a U-235 nucleus is unlikely to absorb a fast neutron. (is this true?)
Is it true that the strong nuclear force in the vicinity of the nucleons is responsible for the "capture" of a passing neutron? If so why should U-235 and Pu-239 be so different in terms of the likelihood of them capturing fast neutrons?
Also, if a U-235 nucleus did absorb a fast neutron, would it be likely to split?
Thanks for any help.
Did you find values for the cross-section of fast neutrons at U-235 and Pu-239? Maybe they are not so different, and the cross-section for thermal neutrons at U-235 is just larger.
This is true.
Thermal neutron fission is observed for some even-odd nuclei such as U235 and Pu239. The compound nucleus formed is even-even, which has greater binding energy, and therefore there's plenty of excess energy available to cause instability and result in fission.
Fast neutron fission is observed in some even-even nuclei like U238. In this case the compound nucleus is even-odd and has less binding energy. Meaning at least a certain amount of excitation energy must be supplied by the incoming neutron for fission to occur.
Your statement that Pu239 requires fast neutrons is incorrect.
Is fast neutron fission possible or just as likely as thermal neutron fission in the even-odd nuclei like U235 and Pu239?
From what I can see for thermal neutrons the cross-sections for fission for the two nuclei are:
U235 - 346 barns
Pu239 - 695 barns
And for fast neutrons the the cross-sections are
U235 - 1.8 barns
Pu239 - 1.7 barns
So could I conclude from these that both nuclei are much more likely to encounter, and therefore undergo fission as a result of a thermal neutron than a fast one?
Why should the speed of the neutron effect the likelihood of a collision? Is this related to the nuclear force?
Yes - fast fission is possible. That's how bombs work. Thermal fission is for reactors.
1. Why do different nuclei need different neutron speed for neutron capture?
Each nucleus has a unique structure and energy level, and therefore requires a specific amount of energy to undergo neutron capture. This energy is provided by the speed of the neutron, which must match the energy level of the nucleus in order for the capture to occur.
2. How does the speed of a neutron affect its ability to be captured by a nucleus?
Neutrons with higher speeds have more kinetic energy, which allows them to overcome the repulsion between their positive charge and the positive charge of the nucleus. If the neutron is traveling too slowly, it will not have enough energy to be captured by the nucleus.
3. Can the speed of a neutron be manipulated to increase its chances of being captured by a specific nucleus?
Yes, the speed of a neutron can be changed through processes such as moderation or acceleration. By adjusting the speed of the neutron, it is possible to match it to the energy level of a particular nucleus and increase the chances of neutron capture.
4. Are there any factors other than neutron speed that affect the likelihood of neutron capture?
Yes, the likelihood of neutron capture also depends on the stability of the nucleus and the availability of energy states for the neutron to be captured into. Additionally, the presence of other particles and their interactions with the nucleus can also affect the capture process.
5. What are the practical applications of understanding the relationship between neutron speed and neutron capture?
Understanding the relationship between neutron speed and neutron capture is crucial in various fields, including nuclear energy, nuclear medicine, and astrophysics. It allows scientists to control and manipulate nuclear reactions for energy production and medical treatments, as well as to gain insights into the formation and evolution of stars and galaxies.
  • Nuclear Engineering
10K
