Discuss events which are simultaneous in one frame?
In summary, the idea of simultaneity is often discussed in relation to the theory of relativity, specifically in the context of how events can be perceived differently by observers in different frames of reference. There are two main types of simultaneity - reception simultaneity, where two events are perceived as happening at the same time by an observer, and transmission simultaneity, where the events were actually released at the same time but may not be perceived as simultaneous due to the time it takes for light to travel. The concept of simultaneity is important in understanding how time is perceived in different frames of reference, and it is often discussed in relation to the Lorentz invariance of the fundamental laws of physics.
  • #71
neopolitan said:
If, for any reason, the clocks are not synchronised in their shared rest frame (the rocket's frame, or Barney's frame), then moving them to the centre of the rocket in the manner described will not make them synchronised.
Correct
neopolitan said:
However, the extent to which they are not synchronised will not be affected either.
Correct
neopolitan said:
The question I must have then is, does acceleration of a rest frame - relative to an outside observer - cause synchronised clocks in that rest frame to lose synchronisation?
I doubt that it does, since each clock will be accelerated equally (since otherwise the clocks don't share a rest frame). All effects will be equal and synchronisation in that rest frame will be maintained.
Yet again, I stand ready to be corrected.
cheers,
neopolitan
This is a bit more tricky. While the rocket is accelerating it is length contracting according to Fred. The nose and tail therefore can not have the same velocity at all times according to Fred because the tail is catching up to the nose.
The tail is going faster at all times until the rocket starts cruising. The tail clock is time dilated more than the nose clock. When the clocks are syncronised in Barney's frame the nose clock should be showing a lesser time according to Fred using the formula [itex]-L_o v/c^2[/itex]. The time dilation that occurs during the acceleration phase is doing exactly the opposite and is not self syncronising.
When the clocks are brought together in the centre, the tail clock is time dilated even more making the situation worse.
  • #72
neopolitan said:
kev,
As far as I can tell it was not until #63 that you introduced tamper proof clocks which you claim would lose synchronicity after acceleration - specifically, you claim that the clocks lose synchronicity in the rest frame due to acceleration:
In post #47 I introduced the decaying isotope clocks:
kev said:
Now say I get 3 lumps of radioactive material that decay in a consistant and predictable manner at the same rate. The half life of the material is defined as the time it takes for half the remaining atoms of isotope1 to convert to isotope2. These lumps provide a fundamental clock that cannot be arbitarily advanced, retarded or syncronised with respect to each other when they are at rest wrt each other.
"Tamper proof clocks" is my new shorthand name for the decaying isotope clocks. (Sorry, I should have made that clearer) Although if you tried really hard you could tamper with them, the rules for the thought experiment that I introduced is that we do not syncronise, advance or retard the isotope clocks. (Sorry, if I did not make that clear either). For that purpose we can imagine that the decaying isotope clocks are sealed to prevent tampering and all that is visible is a digital display of the time they record (or a display of the ratio of decayed atoms to undecayed atoms). They provide a reference clock to the conventional clocks that are syncronised when the rocket reaches its cruising speed. Each conventional clock has a tamper proof isotope clock next to it at all times for comparison.
  • #73
kev said:
When the radiactive lumps are being brought together by the inpartial robots, the rear lump is moving even faster (relative to the one and only sentient observer) than the nose lump that is transported "backwards" from the nose to the centre and so the rear lump experiences even more time dilation relative to the front lump from the point of view of the only observer.
You asked to point out where you made the typo (it is more like an error). See above.
The difference in the speed of lumps in the frame external to the roicket is irrelevant. You are using the differences in speeds in the observer frame in order to justify a difference in time dilation. This is incorrect: if the lumps were synchronized prior to slow transport, they will remain synchronized after slow transport, the difference in speeds between the fore and aft lump in the external observer frame is irrelevant as long as the rules of slow transport were obeyed in the rocket frame (slow and equal speeds in the rocket frame).
  • #74
In post #63 I said this:
kev said:
We are agreed that two clocks that are syncronised [according to Barney] will still be syncronised when they are transported to the centre of the rocket.
How does that differ from the underlined part of your post?
I also said this:
kev said:
In the example I gave the two tamper proof radioactive decay clocks are not syncronised after the acceleration phase of the rocket [as far as Barney is concerned] and they will still not be syncronised when transported to the centre ...
I'll say it again. "The radioactive lumps are not syncronised prior to the slow transport."
I can only assume that you also missed or skipped over the prior 2 posts (#71 and #72).
"if the lumps were synchronized prior to slow transport, they will remain synchronized after slow transport"
The point is that the lumps are not syncronised prior to the slow transport. Post #72 makes it clear that lumps are not syncronised after the rocket has accelerated from the Fred's rest frame and according to the rules of the thought experiment (post #72) the radioactive lumps are sealed or "tamper proof" and we are not allowed to to syncronise the radioactive lumps. THAT is the point of the radioctive lumps. There are conventional clock paired with each radiactive lump that can be syncronised.
So to sum up the last dozen posts where we have been repeating ourselves and making out that we are disagreeing when we are not:
1) Two clocks that are syncronised prior to slow transport will remain syncronised after slow transport.
2) Two clocks that are not syncronised prior to slow transport will not be syncronised after slow transport.
3) The radioactive lumps are not syncronised prior to slow transport (So point 2 applies)
4) The radioactive lumps are sealed in tamper proof containers and according to the rules no one is allowed to adjust, advance, retard or syncronise the radioactive lumps once the rocket has launched.
This is where me and neopolitan were at about half a dozen posts ago. The only thing neopolitan is not sure about is whether or not the the radioactive lumps will remain self syncronised during the acceleration of the rocket and after the rocket has stabilised to its cruising speed. I can assure you that the radioactive lumps will not remain syncronised after the acceleration phase.
  • #75
I thought about one thing a little late last night, when I should have been asleep. I think the replies which have appeared since then answer the question, but I want to make sure.
I have assumed that the rocket is rigid and that we are not talking about a real world situation here where there would be a lag between the commencement of acceleration along the length of the rocket. If we were assuming a (semi) real world rocket, then the motor would be in the tail and the whole length would contract physically, within its own frame. This is not how I have thought about the mind experiment. The whole frame accelerates together, if it accelerates at all.
I think that kev has considered the rocket to be rigid as well, but I am not totally sure. If the rocket according to kev is not rigid, then yes there will be a loss of synchronicity in the nominal rest frame (since motions would be created by the frame's acceleration, it would no longer really be a rest frame).
I think this is wrong. I think I can understand what you are saying - if it relates to length contraction - but I am pretty sure there is something wrong with the conceptualisation.
I will have to ponder it a bit more though and read the comments of other contributors.
cheers,
neopolitan
  • #76
I also said this:
U asked me to point the exact error in your post, so I did. I can only go by what you wrote in the respective post. If you intended to write something else, go ahead and correct it. :-)
  • #77
neopolitan said:
I was further trying to say, perhaps not sufficiently clearly, that the unequal time dilation effects observed in another frame should explain how the clocks end up being synchronous in that other frame when they weren't initially.
This is correct, although the easiest way to show it is not directly through time dilation (because there are also synchronization issues), but through the spacetime interval as follows.
The rocket has proper length L and is moving at v in the (unprimed) observer frame. Without loss of generality the origin of both frames is taken to be the event, A, when the rear clock starts moving at u in the rocket frame. The event B is when the front clock starts moving at -u in the rocket frame. The event C is when the clocks meet.
A' = (0,0) --> A = (0,0)
B' = (0,L) --> B = (γLv/c, γL)
C' = (c L/(2u),L/2) --> C = (γL(c²+uv)/(2cu), γL(u+v)/(2u))
If the clocks are initially synchronized in the rocket frame then at A/A' and B/B' the clocks read 0. The spacetime interval |C-A|=L²(c²-u²)/(4u²), so at C the rear clock reads sqrt(L²(c²-u²)/(4u²))/c. The spacetime interval |C-B|=L²(c²-u²)/(4u²), so at C the front clock also reads sqrt(L²(c²-u²)/(4u²))/c.
So, basically, in the observer's frame, the rear clock moves for longer at a higher velocity (more time dilation) which balance out to have them synchronized at their meeting.
Note that, if the clocks are initially de-synchronized in the rocket frame by an amount dt, then they will be desynchronized by dt in all frames at their meeting.
  • #78
DaleSpam,
Can you confirm that acceleration does not cause a loss of synchonisation between two synchronised but non-collocated clocks in shared rest frame?
This is kev's claim, not mine, my rebuttal is at post #75 (admittedly not with any hard data to back it up).
cheers,
neopolitan
  • #79
Kev is correct. Whether clocks maintain synchronization during acceleration depends on how they are accelerated.
  • #80
There is no error in my original statement. It is simply the point of view of the unaccelerated observer external to the accelerated rocket.
In the case of two clocks that are syncronised from the point of view of an observer on the rocket the clocks will read the same time when slow transported to the centre. The two clocks at the nose and tail of the rocket that appear syncronised to the onboard observer are not syncronised according to the unaccelerated external observer and the difference in time dilation during the slow transport accounts for why the external observer see the two clocks as syncronised by the time they are co-located at the centre of the rocket. Both internal and external observers agree that clocks are syncronised when they are are co-located. If the clocks were not syncronised according to the onboard observer prior to the slow transport, then both observers will agree they are not syncronised when they meet at the centre.
  • #81
Can you check the conditions stated in the thread then, and see whether they qualify.
  • #82
I agree with this. This is either not what you originally wrote, or not what I initially read.
In any event, this I can agree with.
I no longer understand why you need acceleration though, since the in-frame, non-collocated synchronised clocks will not be sychronised according to an external observer (not at rest relative to the clocks) irrespective of whether they undergo acceleration or not.
You might want to review post #71
cheers,
neopolitan
  • #83
It is true that "the in-frame, non-collocated synchronised clocks will not be sychronised according to an external observer (not at rest relative to the clocks) irrespective of whether they undergo acceleration or not." However they will be out of sync in different ways according to the external observer. If the clocks are syncronised by someone onboard the rocket then the nose clock will show less elapsed time than the tail clock according to the external observer. If the clocks are not syncronised after the acceleration then the nose clock will show more elapsed time than the tail clock.
Basically I introduced acceleration to support your view that "the nose clock is in the future of the tail clock".
When the clocks on the rocket are syncronised according to an oboard observer (A) then to an external unaccelerated observer (B) the nose clock reads less than than the tail clock. If the rocket is 16 light seconds long and going at 0.5c relative to observer A then A will see the nose clock reading 8 seconds less than the tail clock. This is not supportive of your view that the "the nose clock is in the future of the tail clock".
When the clocks on the rocket are syncronised according to an onboard observer (A then obviously the nose clock and the tail clock will be showing the same time simultaneously as far as observer A is concerned. This is not supportive of your view that "the nose clock is in the future of the tail clock" either.
However if we place syncronised clocks on the rocket and then accelerate it, an unaccerated external observer will see that the nose clock IS in the future of the tail clock, if the onboard observer does not re-syncronise the clocks after the acceleration. The onboard observer and the external unaccelerated observer will both agree that the nose clock has aged more than the tail clock.
To give an extreme example. We place identical twin babies on a very long rocket. One twin baby is at the nose and the other at the tail of the rocket. The rocket is accelerated very hard for a very long time and then allowed to cruise for long enough to allow stresses and strains to stabilise. We bring the twins together at the centre of the rocket and we see that the nose twin is an old guy with a long white beard while the tail twin is still a baby. Since they are both co-located no observer can disagree that the nose twin is in the future of the tail twin.
By the way I am talking about a traditional rocket with a single rocket at the rear and the rocket is allowed to undergo natural length contraction.
Now if instead of accelerating the rocket that has the twins onboard, we get another rocket and accelerate away in that. We turn around and fly past the the rocket with the twins onboard and they appear to be ageing differently by our observations. Finally we land next to the twin's rocket and the twins come to meet at at the centre of their rocket. In this case we note the twins did not really age differentially. They are both older and it is us that have aged less. I am trying to show that Lorentz transformations result in real physical changes and that what may appear to be symetrical situations are not really symetrical when you take acceleration into account.
  • #84
As Doc Al mentioned the answer depends on the details of the motion, which I don't think have been unambiguously defined here. So instead of directly answering I will refer you to
http://www.mathpages.com/home/kmath422/kmath422.htm
Which gives a more detailed treatment of Born-rigid acceleration than I could. I am sure that you could find other pages describing other acceleration schemes.
  • #85
If I have this right, which is by no means a given, this theoretical effect is due to a rigidity which is not actually physically possible. One consequence is that the tail of the rocket will have to travel faster than the nose to mainain this impossible rigidity - according to an external observer - within the "rest frame" the tail will now not be at rest relative to the nose, but will have a velocity in the direction of motion as perceived by the the external observer.
That, to me, would explain why a tail observer would be younger than the nose observer.
I suspect that in reality other effects prevent this from happening.
Standing by to be corrected :)
cheers,
neopolitan
  • #86
See earlier post on acceleration, I don't think that this is what I had in mind since, as DaleSpam pointed out, we have not sufficiently defined the scenario. When I wanted a rocket that didn't compress due to the acceleration, I didn't mean that I somehow wanted to do away with length contraction. The reasoning behind this is that the rocket will compress mechanically if the motor is at the tail (if the rocket is pushed) and stretch mechanically if the motor is at the nose (if the rocket is somehow pulled) and I wanted to eliminate the differences involved.
First, thanks for coming out in support. I do appreciate that.
The problem, however, is that we have a disagreement about the meaning of "the nose clock is in the future of the tail clock". I explained what I meant to JesseM in post #42.
If you read that post, you can hopefully see why I think that, in the scenario you describe above, the nose clock is in the future of the tail clock.
cheers,
neopolitan
  • #87
Hi neopolitan,
Essentially the method of acceleration i was describing is born-rigid acceleration as described in the link. I was totally ignoring Newtonian compression forces under acceleration and that is why I mention allowing time for the rocket to settle to its natural length contracted time. For example a fast accelerating rear wheel drive car will get shorter (or a front wheel drive car get longer) for reasons that have nothing to do with relativity. The impossibility of ideal born-rigid motion is due to consideration of those Newtonian compression and tension effects under acceleration. Ideal born rigid acceleration would require each particle of the rocket to have its own rocket motor. However, we can ignore those petty details if we allow the rocket to cruise for a while after acceleration to settle down.
Dalespam correctly points out that how the clocks go out of sync during acceleration depends on the acceleration scheme that is employed. However, I have been looking at acceleration methods in relation to this topic and I have come to this conclusion:
There is no acceleration scheme that can be applied to two clocks (in flat space) (that are spatially separated by a non zero distance along the x axis) that will keep the clocks syncronised as viewed by an observer co-moving with the clocks when the clocks have reached a constant and equal (non zero) velocity along the x axis, relative to the initial frame.
  • #88
It is indeed impossible to have a perfectly rigid object, but it is theoretically possible to have perfectly rigid motion. If you read more about Born rigidity you will notice that it is always used to describe motion rather than objects.
If you look at the diagram on the page I linked to such a motion is possible, but each particle would require it's own "engine".
  • #89
Would not then each particle in the engine require an engine, and so on. Which makes it sort of impossible?
cheers,
neopolitan
  • #90
Sure, it is practically impossible, but not logically or theoretically impossible. Additionally, it still makes sense to understand Born rigid motion as a close approximation to easily achievable situations, e.g. a short stiff rocket with gentle thrust.
On the other hand a perfectly rigid object is not even theoretically possible and inherently leads to logical contradictions. Such an idea is generally not useful even as an approximation.
  • #91
Dalespam is right that that gentle acceleration of a short rocket is a good aproximation to born rigid motion. We could also achieve a very close aproximation by accelerating some particles in a particle accelerator with precisely timed dynamically changing electromagnetic fields. On a larger scale we could accelerate two unconnected clocks, each with their own rocket so that the clocks maintain constant proper separation. If we ignore the rockets then the two clocks would be undergoing close to ideal born rigid motion. Gravity acts on an object so as to accelerate each particle of an object individually so that is close to the ideal of having a little hypothetical rocket for each particle. Unfortunately the tidal effects of gravity tend to stretch an object so the motion of a falling object is probably not born rigid motion.
  • #92
Given that we seem to have come to a reasonable conclusion on the acceleration strand, can we return to the situation which I raised a while ago in which there is no acceleration, just two inertial frames.
Is there still dissent about what I mean with "the nose clock will be in the future relative to the tail clock"?
Note that post #42 applies.
cheers,
neopolitan
  • #93
cheers,
neopolitan
To be honest, I do not agree or disagree with you on the grounds that I am not clear on what you are getting at. Could you try explaining again?
Do you mean a situation where a rocket is going past you and you observe the nose clock when it is level with you and later the tail clock as it passes your location?
  • #94
Why would we go back to that discussion? Was there something unclear or wrong about the diagrams in post 39? If not then all further discussion is purely semantics, which I am not interested in arguing.
  • #95
There is nothing wrong or unclear with your arguments or diagrams in post #39. Your viewpoint is clear. I am just not clear what neopolitan's viewpoint is, but you are probably right that is just semantics that is causing the problem.
  • #96
This is the relevant section from #42.
neopolitan said:
To try to clarify again, in a now moment in the observer's frame (all now moments are relative, since "now" changes all the time), the observer may observe the tail clock reading 10s and the nose clock reading 2s. IF the clocks are synchonised relative to their rest frame - noting that the observer can work this out from the relative velocity of the clocks and their apparent separation from each other - THEN the observer can further deduce that the nose clock he sees "now" is a younger version of the nose clock and an older version of the tail clock (the observed nose clock manifests earlier in the clocks's rest frame than the observed tail clock - in our example 8s earlier). The nose clock, if you like, has reached the observer's "now" before the tail clock has.
I am sorry to have to do this, but I hope I can justify it. Let's introduce a third clock - on the rocket, in the midpoint between the nose and the tail. That clock will read a midpoint value. Without thinking too deeply about the specifics, I suspect it is 6s (midway between 10s and 2s) but the acutal reading is immaterial - what is important is that it is more than 2s and less than 10s.
If the observer not at rest relative to the clocks observes a reading of 6s on the midpoint clock, 2s on the nose clock and 10s on the tail clock - and knows from his deductions that in their own rest frame the clocks are synchonised then he can say, taking the midpoint clock as his reference, that the nose clock he "should" (see since the clocks are synchronised) is in the future and the tail clock he "should" see is in the past. Whose past and whose future? the past and future of the observer.
What that observer sees, as you point out (I think), is a past version of the nose clock, relative to the midpoint clock, and a future version of the tail clock, relative to the midpoint clock.
You don't really need the third clock, since the same logic applies with only two points, but hopefully the temporary introduction of a third clock makes it easier to understand.
DaleSpam is most probably right, we are probably arguing over semantics.
The situation described is equivalent to that illustrated in the first diagram in #39. I doubt the validity of the second diagram to be honest, since the perspectives are a bit screwy. In diagram one there is the perspective of the external observer observing the rocket and the perspective of the rocket. In diagram two there seem to be "corrected" perspecitives and I wonder if that is valid (since if there were a rocket in each frame, pointed in opposite directions, they would both, in my scenario, consider that other's nose clock is in the future. It is not so that one frame's observer would think that the second frame's nose clock is in the future and the second frame's observer would think that the first frame's nose clock is in the past).
I do want to go further, but I would like to get over this question of whether a clock that reads less is in the future or in the past, from an external observer's frame. Is it at all possible to go from what I have written in the quoted text above?
If necessary I can try to rephrase it, if it is not sufficiently clear.
cheers,
neopolitan
  • #97
The second diagram is the rocket's rest frame where v=0. The solid outline in the second diagram shows the position of the rocket at a given instant in the rest frame.
The first diagram is the observer's frame where v=.6c. The solid outline in the first diagram shows the position of the rocket at a given instant in the observer's frame.
The dashed outline in each diagram is the solid outline from the other diagram, so the dashed outline in the first diagram shows the rocket's perspective and the dashed outline in the second diagram shows the external observer's perspective. The two diagrams show the same two things in different frames.
What specifically do you think is wrong with the second diagram?
  • #98
If a rocket is moving relative to us and an explosion occurs at the nose and tail of the rocket simultaneously in the rocket frame, then we would see the tail explode first and then at a later time we would see the nose explode. From the time we saw the tail explode to the time we see the nose explode are we not seeing a past version of the nose that has not yet exploded?
  • #99
We specified earlier that we took into account travel times for photons from each clock.
cheers,
neopolitan
  • #100
I may have it wrong but in the second diagram it seems you are saying "if the nose and the tail of the rocket are simultaneous in the external observer's frame, this is what happens in the rocket's frame" - the clocks in the rocket's frame will not be synchronous, and being synchronous in the rocket's frame was inherent in the scenario.
cheers,
neopolitan
  • #101
Yes, that is the dashed outline in the rocket frame diagram.
The rocket clocks are synchronous in the rocket frame, that is the solid outline in the rocket frame diagram. The clocks on the rocket read the corresponding t' value. So you can see that in the rocket frame diagram the clocks are synchronized (solid outline) at t'=2, while in the observer's frame the rocket clocks are not syncronized (solid outline) with the nose reading approximately t'=0.5 and the tail reading approximately t'=3
  • #102
Ok. Happy with that, DaleSpam. Putting that aside, since there is no dissention, I will restate what I had a couple of posts ago, with the hope that we can go further.
cheers,
neopolitan
  • #103
When you talk about future or past it is a comparison between two events. So which two events are you referring to?
My guess is that you are referring to two spacelike separated events in which case the distinction between future or past is frame-variant.
  • #104
Any two simultaneous events at the nose and the tail of the rocket, where the clocks are, which are described as simultaneous in the rocket's frame - in which case two simultaneous events are neither in the past nor the future relative to each other. The point of the synchronised clocks is that, when a simultaneous reading is taken in the rocket's frame, they read the same.
When two simultaneous events are observed from the external observer's frame, the clocks do not read the same. However, with knowledge of the frame's relative velocity, the external observer can figure out that the clocks are indeed synchronous, in their own rest frame.
Then, thinking a little more, the external observer can figure out that he simultaneously sees one clock which is - figuratively - transported through time, by the effects of relativity, into the future relative to the other clock.
Let's think about two time travellers, just for the purposes of nutting out which clock is in the future. Both hold clocks which are initially synchronised. Both of them travel through time at different rates and compare clocks when they meet again. Which one gets to the future "first"? (relative to an external observer - remember I really wanted to only have one observer to get around problems with people wanting to swap observation points around?) Specifically, which could be said to be in the future - the time traveller who ends up with 2s on his clock, or the time traveller with 10s on his clock?
Clearly the one who has 2s on his clock is in the future, if the other clock reads 10s.
This is what I mean. On the rocket, the nose clock reads less than the tail clock. The nose clock is in the future relative to the tail clock.
Is that any clearer?
cheers,
neopolitan
PS Since this seems to just go round and round, I may move on to my next point anyway. Not tonight though.
  • #105
cheers,
neopolitan
I always take light travel times into account except on accasions where we are expliicitly talking about optical illusions as for example in Penrose-Terrell rotation.
In the example I gave you have to imagine you have a whole grid of clones all at rest with respect to each other and all with clocks syncronised to each other. When the explosion occurs at the tail and nose of rocket (simultaneously as far as observers on the rocket are concerned) one of your clones is standing right next to the tail when it explodes and another is standing right next to the nose when it explodes. Light travel times are not required. The clone that was standing next to the tail of the passing rocket when it exploded says the tail exploded at 3 PM. The clone that was standing next to the nose of the passing rocket when it exploded says it exploded at 3.30 PM.
