Hubble's Constant with coincident galaxies
In summary, the value of the Hubble constant varies inversely with time in a non-accelerating universe. At half the age of the universe, the Hubble parameter would be twice its current value, or 2H0.
astrofunk21
29
The value of the Hubble constant is around 70 km s-1 Mpc-1. Consider two galaxies moving with the Hubble flow of the Universe that are currently separated by 1 Mpc and assume that the rate of expansion of the Universe is constant with time.
A. At what time in the past were the galaxies coincident? This is presumably the origin of the Universe.
B. In this non-accelerating Universe, how does the Hubble constant vary as a function of time? What was the Hubble constant when the Universe was half its current age?
This should be an easy question, but I am having some trouble with it. I feel that (A) should just be Hubble Time right? If you guys could lead me in the right direction or give some hints that would be great.
Welcome to PF astrofunk21,
If you had posted in the right section using the template provided, you would notice that one of the things the template asks you to write down is any "Relevant Equations." In this case that's Hubble's Law. Let's start there. Write down Hubble's Law. As the question implies, if the universe is to expand at a constant rate, the Hubble parameter cannot remain at the constant value H0. It has to change with time. Do you see why?
EDIT: You are correct that for this non-accelerating universe, the age of the universe (a.k.a. the amount of time since the galaxies were coincident) is equal to the Hubble time 1/H0, but you need to show this.
v=H0*D
Sorry about the post.
Yea I see that H0 would change if v is constant. So now in terms of part (A), wouldn't it just be when "D" is 0? And for (B), is it just a matter of switching the velocity to a distance over time?
astrofunk21 said:
v=H0*D
Well, yes, if speed is constant, then speed = distance/time, which allows you to solve for d vs. t, which tells you how the separation varies with time.
So, if you write down Hubble's Law, you're writing:
v0 = H0d0
where v0 is the recession velocity of two galaxies today and d0 is their separation today. But a Hubble's law applies at any time in the past.
v = Hd
where v is the recessional speed at some time in the past, and d is the separation of the two galaxies at that time. The tricky thing is that H, which is called the Hubble parameter, does not necessarily have the same value at this time in the past as it does today. (The value today, H0, is called the Hubble constant). In general, H changes with time.
So, if v = v0 = constant, then what you're saying is that Hd = constant. Since you already know d vs. t, you can get H vs. t from this relation.
Yes I know a function haha, my issue is interpreting the questions and understanding what to do. Now for part (B) my guess would be to get time into the function of course so I got this:
H(t) = vt/d
Is there any truth to that?
EDIT: Okay that was completely wrong. Scratch that
H(t) = vt/d
Oh okay. Yeah I edited out the part where I asked you about functions, I guess I should have left it. Anyway...
We already know that d(t) = v0t, since v(t) = v0 = constant, right?
v(t) = H(t)*d(t)
H(t) = v0/d(t)
Can you take it from here?
Yea I understand all that. I guess I'm just missing the connection. Never really derived formulas ever.
It would be better for me to figure it out rather than you tell it to me though. Don't want you to give me the answer even though to most you probably already have.
I mean all I see is that it's almost the inverse of time.
H(t) = 1/t
H(t) = 1/t
That's correct. You got the answer. (H(t) = v0/d(t) = v0/(v0t) = 1/t). The Hubble parameter varies inversely with time in the case of a constant expansion rate. This is the answer to the question of part B, "How does the Hubble constant vary as a function of time?" Ans: inversely.
So now it should be trivial to answer second part of that question: what was the value of the Hubble parameter at half the age of the universe? If H(now) = H0, what does H(now/2) equal?
Oh wow okay, maybe I tried making this a little harder than it really should have been. Thanks for the help/patience, sorry if I was a little ill prepared.
What is Hubble's Constant?
Hubble's Constant is a measurement that describes the rate at which the universe is expanding. It is named after astronomer Edwin Hubble, who first discovered evidence of the universe's expansion in the 1920s.
How is Hubble's Constant calculated?
Hubble's Constant is calculated by measuring the redshift of distant galaxies and using the relationship between their distance and velocity to determine the rate of expansion. This is known as the Hubble-Lemaître law.
What is the significance of coincident galaxies in relation to Hubble's Constant?
Coincident galaxies are galaxies that are close enough to each other to affect each other's motion through gravity. These galaxies can provide valuable data for calculating Hubble's Constant, as their interactions can help refine our understanding of the expansion of the universe.
How has our understanding of Hubble's Constant changed over time?
Hubble's Constant has been refined and updated over time as new observations and technology have become available. In the past, it was believed to have a constant value, but more recent measurements have shown that it may vary slightly depending on the age of the universe and the amount of dark energy present.
What are the implications of Hubble's Constant for the future of the universe?
Based on current measurements, it is believed that the universe will continue to expand at an accelerating rate due to the presence of dark energy. This means that in the distant future, galaxies will become increasingly isolated from each other and the universe will become colder and darker.
  • Astronomy and Astrophysics
  • Cosmology
