Constant Acceleration Equation - physicist please
In summary: To watch for the units when they do equations. If the units don't match, then either the equation is wrong or the answer is wrong. 2. To keep track of the units when they do manipulations.3. To be very careful because a simple change of units can lead to very wrong answers.This is physics, not algebra. If you choose to ignore the units, you are not doing physics. Zz.Edit: By the way, I'm sorry, but I'm afraid I don't understand the potato analogy.
  • #71
From my perspective, I believe the confusion has been one of definitions and lack of consistency. Gregor seems to have been seeking a "formula" for converting from one unit to another. In essence, it is as he said, he was after a formula for the dimensionless numerical value of g. The problem was that for him the values of the variables meant something else than what they traditionally mean, and he did not define precisely what they meant to him in terms that mean anything to other people.
On the other hand, those who did understand what he was trying to do considered it a triviality (it is, but only if you know basic algebra properly) and did not respond in terms of Gregor's formula, but with a direct answer which is "obvious" -- it is, but not to Gregor, I guess.
Here, I'll attempt to meet Gregor halfway.
Let us define 1 m' (a "new" meter) = 9.8 m (a "regular" meter)
Solving this for m we get 1 m = 1/9.8 m'
1 g = 9.8 m/s^2 = 9.8 (1 m)/(1 s)^2 = 9.8 (1/9.8 m')/(1 s)^2 = (1 m')/(1 s)^2 = 1 m'/s^2
Ok, that was a little too explicit, perhaps, but better safe than sorry.
And essentially the same for converting any value into any other unit, just replace 1 s with your new unit and simplify. There is no "formula" because it's "trivial," which means that you shouldn't think of formulas as numerical "plug'n'chug machines," but as relations between variables, which can be evaluated numerically if need be. Separating a number from its unit is bound for confusion, as has been shown, so don't do it.
The "best" way to convert between units is this way, by substituting the value of a unit in terms of another.
Ok, just to make sure it is even clearer I'll do a "general" case by including variables for the conversion factors.
Let L' and T' be the numerical conversion factors between m and m', and s and s'
1 g = 9.8 m/s^2 = 9.8 (L' m')/(T' s')^2 = 9.8 (L'/T'^2) m'/s'^2
For instance, in the earlier example we would have:
1 m = 1/9.8 m' = L' m'
So, if we set G to the -numerical- value of g in the units of m/s^2, G = 9.8, and G' to the -numerical- value of g in the units of m'/s'^2, then from the above equation we get G' = G*L'/T'^2, but realize that this is getting needlessly out of the way.
Well, since I'm half-asleep and seem bent on rambling I'll just finish it off with another one of your examples.
1 m = 10^6 um (let's just assume that u is a greek mu, for micrometer)
1 s = 10^3 ms
1 g = 9.8 m/s^2 = 9.8 (10^6 um)/(10^3 ms)^2 = 9.8 10^6/10^6 um/ms^2 = 9.8 um/ms^2
In this case the -numerical- value is the same because both conversion factors cancel out.
Hopefully it should be clear how to do this by now.
P.S.: There is no physics in this, by the way. Even if mathematicians don't usually work with units that doesn't mean that they aren't consistent with them when they do work with units.
  • #72
You are trying to go to the local drug store by going all the way around the beltway.
  • #73
But then N,Z, and I have NOTHING to do AT ALL with gravity, time or distance, and therefore you CAN NOT use\relate it in terms of those variables.
true,
however this is just a conversion formula
yes, the units must always be consistent throughout the expression,
in my demonstrations I've used prefixed units for simplicity,
however these units are consistant throughout each expression
  • #74
Yes, it is a conversion formula for N, Z and I (Whatever N, Z and I are), PROVIDED that they follow the relationship N = Z*I²
g, m, and s DO NOT FOLLOW THE RELATIONSHIP g= a*s²
How many times do I have to tell you that?
  • #75
I think this would be a very funny analogy, if only I understood what it meant :confused:
I should tell you that English is not my first language (ich bin Deutscher)
so sometimes things get lost in the translation %-/
I know a drug store is what we call an Apotheke
  • #76
That was not for you, that was for Vey2000, and it was not supposed to be funny.
  • #77
I realize this
the only importance for the formula is that it produces the correct numerical value for 1 g in revised units
and the forumula does this perfectly
as I have demonstrated several times
(to the annoyance of every physicist in the forums)
  • #78
Dammit, NO!, it does not.
You do NOT realize it.
Look, 3 + 2 = 5 right?
does 3(apples) + 2(oranges) = 5 (apples)
No. Do you see my point? The math is right, the logic is WRONG!
  • #79
I see you're getting angry now :-(
yes, I've seen the point all along
however it's my point that is being missed
9.80665 (Z) * 0.001 (I) * 0.001 (I) = 0.00000980665 (N)
there are no apples, oranges, or any physical entities here
just numbers to be computed.
the result (N) just happens to be equal to g when m = 1 meter
and s = 0.001 second
the result is always "numerically equal" to g
it's just a convenient coincidence that the formula provides the correct numeric value, there is no direct connexion to physical dimensions involved.
  • #80
Ok, fine, SO WHAT? What good does it do if you lucked out and got the same numerical value, but your units are completely WRONG?
  • #81
how are they wrong?
the only difference between
9.80665 * 0.001 * 0.001 = 0.00000980665
and
9.80665 m * 0.001 s * 0.001 s = 0.00000980665 m/0.001 s/0.001s
is that the units are added in the last expression
this does not make them "wrong", but simply "included" or "not included".
the value for g is correct for these units none-the-less
since 1 g does = 0.00000980665 m/0.001 s/0.001s
  • #82
Dammit are you blind?
does [tex] ms^2 = \frac{m} {s^2}[/tex] to you?
  • #83
I'm aware of that -- I said so myself: "...this is getting needlessly out of the way." However, it's my biased opinion as a student that if you can't see the proper way, the beltway is better than no way. You can't build up a mathematical intuition for how to get from A to B quickly if you don't know how to get from A to B at all.
Unfortunately, it may be the case that despite taking the beltway I still got nowhere since Gregor is still confused.
Gregor said:
how are they wrong?
and
No, there is another difference, ignoring the the fact that the dimensions are wrong -- the right hand side of the second "equality" (it's not equal at all) has two additional divisors that are not in the right hand side of the first equality.
Allow me to take a stab at "fixing" your first equation. What you really have is the following:
9.8 m/s^2 * 0.001 (s/s') * 0.001 (s/s') = 9.8x10^-6 m/s'^2
Notice how there are indeed units in there? Notice how s cancels out with s in the left hand side and you are left with s' instead?
Now I'll take a stab at interpreting your second "equation." The two "0.001 s" divisors are in fact the new s' units. Replace it in the right hand side of my proposed equation and you'll recover the right hand side of your second "equation."
So the problem clearly lies in the left hand side. What you are doing by multiplying on the left side by "time" is actually in fact multiplying by the time unit conversion factors -- 0.001 s/s'. This relates to my previous post where I went out of my way to explicitly show you the conversion factors as variables.
The other problem is that on the left hand side you have "assigned" 9.8 the unit of m, whereas it is m/s^2.
So, your "formula" is g' = g * T'^2, where g' is just g in the new units of m/s'^2, and T' is the conversion factor with units of s/s'. -This- is mathematically consistent.
You have to realize that just because things work out in your mind does not mean that what comes out into paper works out the way you write it. As I said, in my opinion the problem was one of definitions.
  • #84
I think we've given this inane thread way more time than it deserved.
Closed.
14K
